Sealing exhaust leak - help!
autoheart
Installed a new stainless exhaust system on my '67 TR4A IRS. It has the single transverse muffler. I can't seem to get the joints in the pipes to stop leaking - especially the one between the muffler and the pipe it connects with. Anybody have any tips/tricks to help me out? - Joel
tomgt6
Out here is farm country we use spit and bailing wire. I am sure Andy has a better idea then I but maybe someone else will come along with one better then mine.
A
autoheart
The tin can (I used Budweiser) trick worked on my brother's MGB, but not on the TR4. I used a different brand of sealer, but maybe I should try the Permatex - their stuff is usually better in general.
M_Pied_Lourd
Joel,
You can buy wide exhaust band clamps to go right over the joint. The clamps can be "stepped" as well to allow for the pipe overlap. Failing that, you could buy two of the narrower band clamps and use them side by side, one on each side of the join. If you still have a leak after using the narrower clamps, you can always try some exhaust "putty" that hardens/cures with the heatof the exhaust.
I know that Don had a pictured posted on the installation of the band clamps on his TR8.
Cheers,
M. Pied Lourd
PeterK
I used muffler putty on the center joint of my 3A Falcon exhaust. Lasts for a couple of years.
DNK
They're not band clamps ,but stepped they are.
I have a leak on the muffler side of the joint. I don't think that the stock TR8 pipes are a true 2" male fitting.
hondo402000
Hey DNK where did you get those, I cannot find anything that looks like those at the usual auto parts stores
DNK
Which things?I got the connectors at Summit
Is the TR6 a 1 7/8's" diameter?
Smallest I can find is the 2"
PeterK
At my local FLAPS, the band clamps are hanging flat - not put together.
Maybe past them you walked. But stepped they are not. (Yoda speak)
A
autoheart
One time...at band clamp....
Sorry, couldn't resist. This looks like it might work - but up here in the frozen north I don't know where to look. Where's Summit? And what's FLAPS?
Twosheds
Summit's at the top and FLAPS are on the wing trailing edge.
Sorry, I couldn't resist.
Summit sells high performance parts. Don't know where it is, but they send a catalog. Look on line.
Friendly Local Auto Parts Store.
I had the hardest time with that one because, being somewhat of a worldly man, I thought I know what F stood for, only to find that I was wrong.
PeterK
VIP has 'em.
dklawson
This may not be the answer you wanted (and those clamps above look great), but for slip joints on the muffler and rear piping, I've had very good luck using the copper colored RTV. No, it's not rated for exhaust use, but it is high-temperature RTV and it will seal the joint but allow you to pry stuff apart later. When I used to use muffler putty, I always found it brittle. If there was any play in the joint, the stuff would crack and fall out. The RTV remains relatively pliable for years... staying in place and maintaining a seal even when the pipes flex.
A
autoheart
Thanks everyone - good suggestion. I'll try 'em all. And thanks for the tip on VIP Peter; I usually only go there for nice smelling little pine trees for the rear view mirror....
PeterK
I used to use the high temp copper RTV on my 2-stroke racing exhaust right where the pipe meets the exhaust manifold donut.
It worked for a while then tended to blow out all at once. You're right about the exhaust putty hardening too. Both would work as a maintenance item - meaning, you'll need to revisit the leak every couple of years.
Of course when I used it, it was subject to a lot of vibration and bouncing around. This engine normally ran around 8-9Krpm and EGT was around 1280F.
trfourtune
IMHO,
just go to a muffler shop and have all the joints welded up.
Rob
dklawson
Welding is great, but welding is permanent. There are those occasions where it is necessary to take some of the pipes apart for other maintenance tasks.
Nelson Sealing exhaust pipe junction Spridgets 14
B Steering Column Wiring/Sealing Austin Healey 1
D TR2/3/3A sealing master cylinder pocket Triumph 8
dbenichou289 TR2/3/3A Carb Sealing Ring Triumph 6
T TR6 TR6 Carb Gasket Sealing Triumph 1
G TR4/4A Rear Oil Galley Plug Sealing Triumph 21
nichola TR6 Classic Technologies front sealing block Triumph 7
D TR2/3/3A Hints on sealing the sump gasket. Triumph 28
BoyRacer Fuel tank sealing rubber is too thick Austin Healey 3
BN6_2197 Sealing my legroom Austin Healey 11
G TR2/3/3A sealing body seams? Triumph 12
B General Tech Wire wheel sealing bands? MG 4
T TR4/4A Replacing in situ oils sealing gearbox and rear axle Triumph 18
M TR6 Front sealing block Triumph 11
KVH General Tech Sealing Fuel Line at the Pump: TR4 Triumph 12
D TR2/3/3A Sealing Fo8's and Wet Liners Triumph 6
NutmegCT Gasoline resistant sealing tape? Restoration & Tools 3
T TR2/3/3A TR-4 Sealing Block Triumph 2
Tinkerman TR2/3/3A Sealing fender to body 1960 TR3A Triumph 15
S TR2/3/3A Wire Wheels Sealing Triumph 17
N Spitfire Spitfire sheetmetal prep and sealing suggestions wanted Triumph 2
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
R removing black seam sealing Austin Healey 3
C Sealing Healey clutch fitting on brake reservoiur Austin Healey 13
TRMark Being my own DPO, stripped front sealing block Triumph 6
KVH TR4/4A TR4 Front Sealing Block Triumph 2
I Sealing new outer panels on BN1 Austin Healey 10
T sealing oil leaks in a horizontal joint Spridgets 6
O TR2/3/3A TR3 Winshield Sealing Triumph 9
hondo402000 TR6 TR6 Gas tank Sealing Triumph 5
S sealing shim pack Triumph 2
Brosky Sealing blocks are available again Triumph 5
LastDeadLast Brosky - Front sealing block info? Triumph 15
I Bugeye gas tank sealing ring help Spridgets 2
MTribe special bolt for copper washer on sealing block? Triumph 2
Brosky Sealing of Saddle Block in front of engine Triumph 7
steveg Rear Engine Plate sealing question Austin Healey 8
B Sealing block and good thrust washers Triumph 5
J What kind of compound to use as wing2body sealing Triumph 6
A Vent window & waist moulding sealing correct BJ8? Austin Healey 6
PATR8 Windshield sealing Triumph 2
Nunyas Sealing a vented oil fill cap MG 6
Ed_K Sealing the gear carrier to the rear axle case ? Austin Healey 8
G Sealing Block Triumph 6
cdsmith "sealing" gas tank sending unit Spridgets 8
Hegg Engine Rebuild Advice: Painting, Sealing, Assembly Triumph 7
tr6web Sealing, lubes, etc. Triumph 8
J TR4/4A Exhaust a tad too loud... Triumph 6
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
