Shhhhh, I'm starting to enjoy electrical work
tdskip
Not sure exactly how this happened, but I find myself looking forward to dealing with electrical fixes and even trouble shooting...
For example, I just changed my master light switch on the '74 TR6, and sure I had to get upside down in the driver side foot well to connect everything, but it was a snap. While I was under there I say a couple dodgy connection, so I took care of that and so on. Fun!
Still need to tackle the horn, so plenty of room to decide I rather don't enjoy electrical stuff real soon.
Anyone else enjoying this sort of thing?
mallard
I think you have to much time on your hands.
Platinum
Actually, I'm kinda pleased to learn this! :smirk:
...It's like learnin' to function well even under duress.
Like when astronauts get training onna "Vomit Comet"!!
Well done, TD!!!
Humans can get used to about ANYTHING!! :wink:
TexasKnucklehead
Do you want to replace my light switch in my 74 TR6? I have a spare switch in the glove box (that checks ok with a meter). Perhaps I'm waiting for a dark raining night when I'm far from home to replace it. When I turn on the lights, I have to flash the high beams a few times before the headlamps actually turn on. I enjoy electrical work too, but only when it's not convenient.
Platinum
JodyFKerr said:
We call that the "Lotus Position."
Geez, Jody!! That's s'posed to be with legs 'n arms straight out for'ard, not downside-up!
Th' head down one is fer settin' valve clearances an' replacin' water pumps!! :jester:
DougF
Sounds like your light switch is good, but the dimmer switch contacts/connections might need cleaned....or something else is wrong with the it.
Deleted member 8987
Tool trucks always have the "latest and greatest" gadget.
I always resisted, until I had a chance to ponder the long-term usefulness (like, oh, phosphorescent green handled tools....).
One I bought is an "under-dash creeper".
Hourglasses near the top to clear seat and "A" pillar, pad for the noggin (and sleeping), and a fold-down set of legs on the other end to hold it level while under said dash.
Still use it.
angelfj1
Still use it.
are you kiddin? I need one of those. got a photo?
ekamm
After working under my dash considered making something similar. Heavy ply board and braced outside the car at the right height. Hadn't thought of a head rest but hey why not. I'm planning some out of sight tunes and that would be great.
tomgt6
:smile:
Don't you mean
"Lucas Position"
JodyFKerr
tomgt6 said:
:smile:
Don't you mean
"Lucas Position"
Only if you're doing it on the side of the road, at night, in the rain. :smile:
Brosky
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Anyone else enjoying this sort of thing?[/QUOTE]
Tom,
Give it time. Like a bad burrito, eventually this feeling too shall pass. :yesnod:
Platinum
I dunno, Paul... I seem to be immune to the effects. Partner would get dizzy to a point of nausea, I'd be like a ferret with a shiny-new toy. Just depends on the guy doin' the deed I s'pose.
Jag E-Types an' Rollies are no challenge, they have most all the 'lectrics accessible on boards with HINGES. :smirk:
Brosky
Doc,
I guess I'm just too old and too fat to want to go under the dash anymore. Under the hood is OK. I just bought a new 10 fuse ATO block that I'll replace along with my new tail lamp sockets this winter. It's that neck bending stuff that gets to me.
T
tdskip
Paul - I think the novelty of actually have some sense of what I'm going is what is making the under the dash stuff not a chore.
On a side note - I wired up the TR8 today so I could bring my Sirius/XM unit so I'll be styling on the event over the weekend!
71MKIV
Jeez, go away for a few days and I come back to find you lettin out all my secrets.
Spent 6 years of my life upside down and backwards in airplanes putting new radios and instruments in. Some of them miserable things it was 5 minutes to get from one side of the instrument panel to the other.
These little furrin' cars ain't nuttin. But it is very gratifying to turn the lights on for someone who hadn't a clue how.
Brosky
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]On a side note - I wired up the TR8 today so I could bring my Sirius/XM unit so I'll be styling on the event over the weekend[/QUOTE]
See what I mean? Now you're getting dangerous. I became a lot more comfortable with the whole electrical process when I learned to become patient enough to solder properly. That makes electrical work go a lot better and my mentor at the time was very fussy about the right and wrong way of doing a harness and that was before heat shrink tubing!!
BobbyD
Ah yes....... the infamous Lotus position! Courtesy of my wife :jester:
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
S TR2/3/3A TR3 Hard Starting Triumph 4
H MGB Starting Problems MG 3
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
angelfj1 TR5/TR250 Starting a TR250 that's been sitting for 10 years Triumph 12
T TR6 Continuous Starting and Ignition Issues Triumph 6
M TR6 Just starting out… Triumph 16
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
P Wedge Starting problems TR8 Triumph 3
K TR6 tr6 not starting Triumph 11
Jim_Stevens TR2/3/3A Intermittent starting Triumph 14
R TR2/3/3A Starting car for 1st time after rebuild. Triumph 13
F TR2/3/3A starting scuttle repair Triumph 27
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
R TR2/3/3A Starting TR-2 for first time after restoration Triumph 58
D Wanted TR3A starting handle Triumph Classifieds 0
D Starting After Carbs Rebuilt Austin Healey 30
Got_All_4 TR6 Starting my frame restoration Triumph 32
Jayplum TR2/3/3A Starting from scratch what color Triumph 25
sundown TR6 Starting Triumph 43
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
F TR2/3/3A 1960 TR3A starting chassis work Triumph 81
J TR2/3/3A Starting my TR3 A restoration Triumph 8
F TR2/3/3A Starting Triumph 4
N Hesitant starting Austin Healey 16
Got_All_4 TR6 Starting The Tear Down Of MY 1969 TR6 Triumph 6
G TR4/4A Starting without Transmission attached Triumph 9
P BN4 Hesitates on Starting Austin Healey 12
D Hard Starting Austin Healey 14
mgedit TR2/3/3A 56 TR3 Starting Issue Triumph 9
M Starting from cold Austin Healey 2
R Very Difficult cold weather starting problems! Austin Healey 21
R TR4/4A Starting TR4A after 30 years Triumph 12
R winter hard starting BJ7 Austin Healey 16
P Jump starting a positive ground BJ8 Austin Healey 4
W starting motor Jaguar 0
D TR2/3/3A Starting my Bodywork journey. Triumph 166
P TR6 Quick starting Triumph 2
Joe Reed General Tech Starting a screw in a tight location... MG 9
P TR6 TR6 hard starting Triumph 24
Q Just Starting Restoration Of 1967 E Type Jaguar OTS Jaguar 13
stretchit2 Starting Issue Austin Healey 6
M TR6 Intermittant starting problems Triumph 4
Willie_P TR4/4A Starting long dormant TR engine..start up procedures? Triumph 10
S Hard starting on Webers from cold Austin Healey 12
T TR4/4A Weird starting issue with my TR-4 Triumph 15
