clucking noise
bigbadbluetr6
Hey lbcer's
I was out in my TR6 and shifted and when I released the clutch it made a cluck noice like something in the rear end or trannsmission is broke or just loose. This same noice occurs when in any gear and you push on the gas and then let off it makes the same noice. Could this have been my overdrive or the rear end? just let me know b/c its something that needs to be fixed before I drive any distance. thanks guys and gals your all awesome.
Eric
73 TR6
ObiRichKanobi
Check the motor mounts and the transmission mount...since it seems to happen when the engine is torquing...
UltimateQuestion
Since it is a "clucking" noise, maybe you should remove the chickens from the boot! /ubbthreads/images/graemlins/lol.gif /ubbthreads/images/graemlins/lol.gif
Darwin
Bronze
Eric,
Just went through this on my spitfire. sounds very much like you have a universal joint that is letting go. Fix it quickly or you can do major damage if it breaks entirely. If yours are like mine have plenty of JB 80 on hand, a BIG hammer, a lot of patience, and an abundance of swear words. You will need all of them.
waltesefalcon
Darwin is right, I went through the same thing on my Spit about two years ago.
A Why is my car making this noise? Other Cars 5
Popeye TR4/4A Transmission noise - intermittent Triumph 22
AUSMHLY Transmission Noise Austin Healey 11
Gliderman8 TR6 Lever shock noise Triumph 18
LAW75 High-Pitched Noise Austin Healey 13
B High-Torque Starter Rattling Noise Austin Healey 3
nicko Strange Engine Noise Austin Healey 7
Sarastro TR4/4A Identifying the source of gear noise. Triumph 15
Martinld123 Steering Idler Noise Austin Healey 21
S TR2/3/3A Noise from clutch area? Triumph 20
P TR6 Clutch pedal click noise Triumph 2
I T-Series air cleaner/ noise suppressor MG 1
L TR2/3/3A Noise seemingly from Distributor drive gear Triumph 15
P TR6 Clutch pedal noise Triumph 2
P TR6 Clunking noise in rear continuing Triumph 39
R Clutch Throwout Bearing Noise? Austin Healey 2
Gliderman8 TR6 What's that knocking noise? Triumph 6
Kleykamp TR2/3/3A Engine noise Triumph 4
SherpaPilot Strange Noise While Cornering in TR6 Racing 3
G Rattling Noise while Clutch is Partially Engaged Clutch Austin Healey 20
H TR6 1974 TR6 clutch noise when pedal is depressed Triumph 3
F TR2/3/3A Strange Loud Noise Triumph 11
Michael Oritt Clutch-related noise Austin Healey 14
B An expensive sounding noise possibly the transmission Austin Healey 7
M TR2/3/3A Annoying Vibrating noise?? Triumph 11
M TR2/3/3A Grinding noise when trying to start sometimes? Triumph 10
johnrip Wedge TR7 had replaced rotors, now I have a noise and vibration-Wheel Bearing? Triumph 4
G Tappet Noise Austin Healey 8
TulsaFred Generator or water pump noise? Spridgets 20
S Disconcerting engine noise, please help if you can. Austin Healey 56
2billydavies TR2/3/3A rattling noise on TR3a Triumph 12
J MGB Project car done; front end clunk noise while braking MG 4
P MGB MGB overheating with a squealing noise from the engine MG 11
RAC68 Loud Trans Scrapping Noise Austin Healey 9
J Fan Type Noise on Ignition Switch in Accessory Austin Healey 9
K TR2/3/3A Gearbox noise.... Triumph 8
P TR6 Rear suspension noise Triumph 3
D Ticking noise when driving Austin Healey 8
bugedd Rear end noise [insert joke] Spridgets 11
Lukens TR2/3/3A Cog v-belt causing noise. Triumph 8
P TR6 Clunking noise in rear Triumph 2
busybrit MGB Slight starter motor noise MG 5
N BJ8 Noise when going from reverse to forward Austin Healey 2
J Funny noise in my mini British Motor Corp 12
P TR6 Thumping noise Triumph 15
Lukens TR2/3/3A Water pump bearings making noise... time to replace Triumph 9
Lutz Kramer Noise from the engine compartment Austin Healey 21
bighealeysource Okay, here's one with a strange noise from the engine Austin Healey 7
N TR6 Diagnose noise from clutch area Triumph 13
T TR2/3/3A TR3 Engine Noise trouble. New to Triumphs. Granfather's Car. Need Help. Triumph 43
