TR2/3/3A 1960 TR3 Post 60000 elec equipment
Tinkerman
I'm mounting such things as the control box, fuse block, flasher and starter solonoid and I have some questions. I think I know where it all goes except for the fuse block. Does anyone have a picture of where all of that should be mounted? A picture of the wiring harness showing where it comes through the fire wall would be great also.
Does the solonoid need to be isolated wirh rubber grommets? The mounting holes seem to be quite large, about 9/16" in fact.
I see some spire nuts on the firewall in the right spot for where the control box goes. A picture that I have shows what seems to be pan headed screws, anyone know what size?
Where does the horn relay go? I think I just answered my own question. The lucas horn manual shows a horen relay for the 6 volt but not the 12 volt system.
Thanks for any info anyone can provide, Tinkerman
Moseso
I harvested a lot of engine bay pics off of eBay while looking for parts and collecting information for my rebuild. This one is fairly clear, of a "1960 TR3."
The big holes for the solenoid and the voltage regulator take a push-in spire nut insert, and a #12 (i think) round head sheet metal screw.
TR3driver
Great Pumpkin - R.I.P
:iagree:
But the screws for the regulator aren't exactly "round head sheet metal screws". According to the Standard Hardware catalog, they were #10 "Mushroom head" "Parker Kalon J type" (whatever that means) and "For use with Simmonds Fix Nuts".
No horn relay originally, but IMO it's a good modification. Mine is mounted above the driver's left knee, where it's practically impossible to see unless you know to look there, but not too hard to service. I couldn't find a "horn" relay that would work without modification, so mine is modified to work with the stock wiring system.
Don Elliott
Dick - In the photo Moses attached, the Comm. No. plate is in the wrong place as well as the relay for the directional signals. It should look like the green TR3A (TS 81551 L) that we finished in 2006.
martx-5
Tink,
Here's a page from TeriAnn's site that has all of the bulkhead fittings and holes mapped out. It should help with the location of those electrical items as well as other stuff. I found it very helpful when assembling my TR. BTW, this is for post 60k cars.
Geo Hahn
Tinkerman said:
...Does the solonoid need to be isolated wirh rubber grommets?...
As noted, no. In fact I think that solenoid has to be grounded (mounted metal to metal) to work (though I could be worng about that).
martx-5
Geo, you are correct. The starter solenoid grounds through it's casing.
TR3driver
:iagree:If not grounded, it doesn't work.
Tinkerman
Tinkerman
Thanks all of you for your thoughts and pictures. Art, thanks for the link to Teri Ann's website. I doesn't get any bettwer than that diagram. WOW
Cheers, Tinkerman
bondo100b
Dick
I am enjoying your TRials and TRibulations as you work on your car. I have started on my project after taking it apart 17 years ago. I am in North Little Rock. I went to Webb School in Bell Buckle if you are near there.
Steve Bonds
Tinkerman
Tinkerman
Steve, I have sent you a PM re the above.
Cheers, tinkermam
mallard
I had no idea the starter solinoid was grounded in that way. Thanks
Tinkerman
Tinkerman
The BCF has been and is, an amazing source of info. Gotta love the forum!!!!!!!
Tinkerman
Tinkerman TR2/3/3A DOOR PANEL HELP NEEDED 1960 TR3 A post 60000 car Triumph 5
Pool Dad 1960 TR3 engine serial number Triumph 14
O For Sale New Member from NJ 1960 TR3 Triumph Classifieds 1
R TR3 1960 refurbish Triumph 14
B Wanted Wanted: Trailer hitch for 1960 TR3-A Triumph Classifieds 7
T TR2/3/3A Accelerator Say 1960 TR3 Triumph 11
B 1960 TR3 With rust in cylinders Triumph 7
Tinkerman TR2/3/3A 1960 TR3 A More body panel assembly questions. Triumph 5
Tinkerman TR2/3/3A TR3 A 1960 adjusting apron Triumph 4
pbraun TR2/3/3A 1960 TR3 photos Triumph 17
Tinkerman TR2/3/3A Bonnet stay rod 1960 tr3 a Triumph 11
Tinkerman TR2/3/3A Original wind screen 1960 TR3 A [free to a good home] Triumph 2
Tinkerman TR2/3/3A 1960 TR3 A Door Check Assembly Triumph 13
Tinkerman TR2/3/3A 1960 tr3 a to gasket or not to gasket Triumph 35
Tinkerman TR2/3/3A 1960 tr3 a petrol tank front millboard question Triumph 6
Tinkerman TR2/3/3A 1960 tr3 a upholstery question Triumph 2
Tinkerman TR2/3/3A 1960 TR3 A Hood stick mounting point? Triumph 11
Tinkerman TR2/3/3A Apron installation 1960 tr3 a Triumph 11
Tinkerman TR2/3/3A 1960 tr3 a carpeting the floor Triumph 8
Tinkerman TR2/3/3A 1960 TR3 A hood stick color? Triumph 2
Tinkerman TR2/3/3A Windshield glazing TR3 A 1960 Triumph 7
Tinkerman TR2/3/3A Wind scereen support bracket tr3 a 1960 Triumph 3
Tinkerman TR2/3/3A 1960 TR3 A Additional steering question Triumph 4
Tinkerman TR2/3/3A 1960 TR3 A Steering wheel play or Lash Triumph 2
Tinkerman TR2/3/3A Parts help needed 1960 tr3 a Triumph 5
Tinkerman TR2/3/3A 1960 tr3 a seat tack strips Triumph 19
R TR2/3/3A 1960 TR3 Restoration Triumph 8
O TR2/3/3A 1960 TR3 Front Brakes Triumph 2
boxofparts TR2/3/3A Dads TR3 way back in 1960 Triumph 16
J TR2/3/3A New Member 1960 TR3 Triumph 11
L TR2/3/3A 1960 TR3 cooling???? problem Triumph 9
W For Sale 1960 TR3A for sale Triumph Classifieds 0
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
dougie 1960 Austin Healey 3000 Works Lightweight vs. 1962 Ferrari GTO Austin Healey 6
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
5 Sold My 1960 Bugeye Spridgets 10
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
J Wanted 1960 Sprite Bonnet Spridgets Classified 3
KellyRob BMC GEARBOX 1960 British Motor Corp 2
Fanch00 My 1960 BT7 History Search Austin Healey 1
poolboy General TR LeMans 1960 Triumph 8
jlaird 1960 AH Sprite Spridgets 96
C 1960 BT7 Thoughts Austin Healey 14
L For Sale 1960 Austin Healey steel oem wheels Austin Healey Classifieds 0
F Installing AC in my 1960 Healey Austin Healey 14
G 1960 3000 BN7 Top Help Austin Healey 0
