Awesome headlights
MrBlueSky
My wife and I both have new cars with the HID(High Intensity Discharge) headlights and I love it. So what to do about the old Triumphs? Well I noticed last week while I was in my local parts store that Sylvania now makes a "look of HID" headlight called Slverstar in the 7" round that fits our cars (part number H6024ST). These are not the cheep blue lights that you sometimes see but a true bright white light that is just about as bright as the HID. Just for comparison I installed just one light and turned them on and what a difference, it made my old light (which was almost new) look like it had some type of electrical problem. Night time driving is now a pleasure and much safer, I can see them and they can sure see me. These are not cheep at about $20 each but well worth it and should fit just about all Triumphs and MGs.
Jon12
I thought about putting some of these in my spitfire but I'm not sure how well the electrical system will hold up to the higher current draw. One of these days I'll get around to testing it out and keeping a fire extinguisher near /ubbthreads/images/graemlins/crazyeyes.gif
PC
Compared to the cost of real HID lamps (about $400) the cost of those Silverstars is cheap.
On the down side they get them bright by running them hot, about 4000K verses about 3100K for a standard Halogen lamp. They probably won't last as long as some other models. Sylvania's website says "We estimate the SilverStar halogen lights to have a life span of up to one year under average driving conditions." Whatever that means.
Jon12, to accommodate higher powered lights you can install separate, higher capacity wiring for the lights (as long as the alternator can keep up) and use a high current relay to switch them on.
PC.
Saff
According to Bentley, the stock bulbs are 60/45W, which means that a 12V system is delivering 5A for the 60W setting. Does anybody have an estimate of what the actual current requirement is for these HID lights?
Webb Sledge
So then the stock system and wiring should be able to handle the draw? $40 bucks really isn't all that bad (I don't think) for something that will make night driving a lot easier, even if they only last a year.
Are TRs supposed to have high beams and low beams? My 6 only has one setting. You flip the switch on the right side of the column down once and all turn signals some on, and then flip it down again and the lights come on. Is this wired right?
MrBlueSky
MrBlueSky
I turned on my headlights while in the basement and only after about 10-12 minutes did they begin to get very warm to the back of my hand. I also notice no extra power draw, I drive the triumph mostly at night this time of the year because it's just a little to hot and humid during the day down here.
Mark Jones
I've has a pair of these Silverstars in my Spitifre since spring and they are great. I've had no problem with the wiring so far.
Saff
Webb, I don't think that's wired right. The switch on the right side should be for high/low beams, or main/dip beams in the lingo. In Texas, you would need to have both headlight settings working to pass safety inspection. It's also safer with all available lighting working properly.
Bill Redd
Wait a minute... isn't the high beam "switch" the dip switch on the floor?
I hesitate answering because I bought my TR6 without working lights, and it's all in pieces right now!
PC
I got this data off Sylvania's website:
SYLVANIA Lamp Replacement Guide: TRIUMPH 1976 Spitfire
H6024ST Silverstar High Performance Halogen, 45W/55W rated life 150hrs/50hrs.
H6024XV XtraVision Halogen, 55W/65W, rated life 850hrs/200hrs.
H6024CB Cool Blue Halogen, 45W/55W rated life 200hrs/100hrs.
As a comparison, their Xenarc HID lamps draw 35W.
PC.
/ubbthreads/images/graemlins/hammer.gif
Stinky
I see on sylvania's website they list those headlights for the 1976 TR6,...but when I check on a 1971 TR6 they don't list the Silverstar. They only list halogen lights. Actually they list a separate "Low Beam" and a separate "High Beam".
Do you think the Silverstar's would be ok on an older TR6?
PC
[ QUOTE ]
[/ QUOTE ]
I don't know if the lights in a '71 are supposed to be different from a '76. If you can find some reference that lists them as the same it would suggest that Sylvania might have made a mistake.
I thought that all 6s come with standard 7" (PAR-56) round hi/lo lamps. The Sylvania listing for the '71 (H5006 - lo and H5001 - hi) is for dual 5.7" (PAR-46) lamps. That don't sound right to me.
PC.
Webb Sledge
Regarding the high and low beams, they are controlled by the "dip" switch in the floor, as mentioned. I checked this just now, and it does indeed have high and low beams.
I had always wondered what that was for... Now I know!
sammyb
Webb is making us all feel old ... most of us, on force of habit, still prod the floor with our left feet in our newer cars looking for the hi/lo beam dip. /ubbthreads/images/graemlins/tongue.gif
Stinky
I picked up a set of these SilverStar headlights yesterday.
I'm flying out to Texas Saturday morning to drive my newly purchased TR6 home to Maryland. I figured I will probably need to use the headlights somewhere along the way,...So I put the SilverStars in my suitcase. I'll post, and let everyone know how things work out
TR3cubka
I have a set of these in my corvette, my buddies both have them in their trucks.
we have all had them for about 2 years each... and only one of us burned a single headlight. all our cars are daily drivers, and we are all fairly active at night in our cars.
I would recommend them 100 fold
Oh and Hi everyone /ubbthreads/images/graemlins/smile.gif I hope i helped everyone a little with my first post here /ubbthreads/images/graemlins/cheers.gif
tinman58 General TR Dixon Show AWESOME! Triumph 5
J TR4/4A Making a '65 TR4 Run Awesome. Misfire, Ignition Tune Up, Carb Rebuilds. Help? Triumph 70
R Magnificent machines...Golden Age of B. Sports Cars AWESOME! Austin Healey 0
jfslenes June 30, 2011 Ebay Tiger = Awesome! Sunbeam (Rootes) 0
rlich8 THIS CAR IS AWESOME Triumph 23
Morris An awesome mother's day... Spridgets 1
T MythBusters - Crash Force - awesome test Other Cars 4
W Awesome custom Karmann-Ghia coupe Other Cars 5
C Whoa - 71 photos of one AWESOME MGB racecar Racing 1
angelfj1 Wedge Awesome Yellow Wedge Beasty - Mere, Wilts UK Triumph 1
T Awesome Morning Triumph 15
ve9aa Awesome Land Rover T-shirts ! ! Rover / Land Rover 2
Aldwyn Awesome Day for a Car Show! Triumph 1
AweMan One Totally Awesome Ride For us Car Nuts! Other Cars 13
nevets drove my Healey on Sunday and it was awesome Austin Healey 3
Sherlock Awesome picture site Other Cars 1
J New Zaino ZFX is awesome! Restoration & Tools 5
W TR6 Headlights Triumph 0
PAUL161 T-Series MGT 7 inch LED Headlights MG 1
B TR4/4A Headlights Blink Off Triumph 15
7 polishing headlights Restoration & Tools 5
K TR2/3/3A Headlights and their extreme current draw? Triumph 4
K 68 midget. No horn, headlights, turn signals Spridgets 9
Rob Glasgow Halogen Headlights Austin Healey 30
S TR2/3/3A Triumph TR3 Tail Light Issue when Headlights and Brakes are On Triumph 15
rgfrey 1959 Low Beam Headlights Not Working Austin Healey 5
K TR2/3/3A High beams seem to be stuck on when the headlights are turned on? Triumph 3
B TR6 LED Headlights Thouights? Triumph 14
T Ignition warning light remains on and headlights come on Austin Healey 8
JPSmit Green Mini - with halo headlights Spotted 0
P TR6 New headlights Triumph 24
Martinld123 Just installed LED headlights in BN2 Austin Healey 15
R TR2/3/3A Sealed-beam headlights Triumph 15
R Sealed-beam headlights Austin Healey 13
KVH TR4/4A No Headlights Triumph 4
S TR2/3/3A little caged nut headlights Triumph 2
S LED or Quartz-Iodine headlights for my '67 AH 3000 Austin Healey 22
P Porsche with 5 headlights Other Cars 5
Scotsman TR2/3/3A LED headlights Triumph 4
C TR2/3/3A How to wire headlights for TR3 Triumph 5
AUSMHLY LED headlights Austin Healey 36
rjc157 headlights Austin Healey 12
turbofrog Sprite Control Box - Headlights In-Op Spridgets 4
P Headlights and Turn Signal Light Grounding Spridgets 3
J TR2/3/3A Hooked up the Headlights and let the smoke out!!! Triumph 4
T TR2/3/3A Is there a good way to manage all those wires/connectors for headlights & park lights Triumph 9
T TR2/3/3A TR3 headlights Triumph 12
Parker MGB Headlights won't work after full repaint/restoration... what am I missing? MG 6
D BN2 headlights Austin Healey 3
RickB Lucas Headlights - Just got this from VB Spridgets 8
