Using inner tubes in radial tires
yelsink
Member
Just rec'd my Kumho tires, 165-80-15, to mount on wire wheels. The tire side wall says tubeless tire. Is there a problem using tubes in a tubeless tire?
Geo Hahn
Some tire shops (at least in my area) are squirrely about putting tubes in tubeless tires so you may have to ask around for someone to do this.
Try to get the oldest guy in the shop and not some bored teenager who has never seen wire wheels and seldom mounted with a tube.
Hopefully you have someone reliable to balance the wheels as wire wheels may or may not require a special fitting to be balanced on the usual machine.
In case this is new to you, a couple of other thoughts: If there are labels stuck inside the tire (can't recall if Kuhmo does that) they should be removed. A dose of talc/baby powder in the tire is good. The way I was shown was to get it all (rim tube & tire) together, inflate the tube, then deflate the tube, then inflate it again. Look at the rubber-like bands around the inside of your rims, they should be in good condition (they protect the tubes from the ends of the spokes). Replacements are available though some just use duct tape.
Platinum
Duct tape goes dry and brittle in time. If you can't find or don't have the inner bands, use an old innertube, cut to the width of the rim's channel for the spoke attachment and use the rubber cement from a bicycle patch kit to glue it end-to-end if you have to cut it to make it smaller in diameter.
And everything Andy and George have said, too.
TR3driver
Great Pumpkin - R.I.P
It's not necessarily "squirrely"; most tire makers say specifically not to do it. If a tire shop puts a tube in a tire not rated for use with a tube, they could become liable if the tire fails. For example, Pirelli says: "Under no circumstances are tubes to be used in Pirelli tires marked
tubeless."
https://www.tirerack.com/images/pdf/warranty/PIR1.pdf
There is some logic in this, although I don't think it applies to Triumphs in general. Problem is that a tire's load and speed rating is limited primarily by the buildup of heat within the tire when operated under those conditions. A tube adds more friction, which means more heat, which means the tire can no longer handle it's rated load and speed.
billspit
You may want to schedule a road trip to Hendrix Wire Wheel in Greensboro, NC. He could mount and balance the tires, as well as provide the correct tube.
ichthos
The tire shop I go to said that one of the reasons that tires went tubless is because tubless tires have better control when punctured. Tires with tubes tend to blow out quickly or deflate more quickly. That was one reason I blasted and painted my rims.
Kevin
martx-5
Well, I don't know about that. I ran over a 5/16" bolt in my Miata, and the tire went done within seconds! I believe they went to tubeless tires because rim and tire technology allowed it, thus saving the expense of the tube and the extra labor to install it.
TR3driver
"within seconds" is slow compared to what a tube can do. Tubes sometimes pop like a balloon (hence the phrase "blow out"). First time it happened to me (not on a LBC), I literally thought someone took a shot at me!
Of course tubeless tires don't entirely solve the problem; I once managed to punch a golf-ball size hole in the sidewall by running over a broken curb. But they do help, IMO.
OTOH, I feel we simply have to accept that these vintage sports cars are not as "safe" as modern cars are required to be. A reasonably competant driver should have no trouble handling a TR after a blowout, so the risk of using tubes seems acceptably low to me. I never did plan on living forever, anyway.
bgbassplyr
Seems to me that even if the tube blows out, and assuming that the tire remains attached to the rim which it should because with the spokes sealed the tire can be run tubeless, it would react as a slow to fast leak as air escapes through the spokes.
The biggest problem with tubes in radials on wire wheels was pintching or abraiding of the tube by exposed spoke nipples and/or shifting of the tube by radial side wall movement.
Just use a tube rated for radials and be sure the spoke nipples are sealed-taped. Big 3 offers a PVC tape for this. Don't use duct tape.
Anything I'm missing?
Jim
TR3driver
Say for example the incident where I punched a hole in the sidewall with the corner of a curb. With a tube, the initial injury likely would not have punctured the tube and the tire would still hold air. But immediately afterwards, the tube would form a bubble outside the tire and then burst suddenly. Something similar would happen if the tire carcass failed due to old age or whatever, a tubeless tire would leak slowly while a tube would hold air until it had a big enough bubble to pop.
I remember years ago seeing people driving with a bubble of tube protruding; I used to yell at them (but it never did any good).
And there is still that problem with extra heat that I mentioned before. Perhaps not an issue for those of you in more temperate climes, but the Mojave gets darn hot in the summertime and I'm usually in a hurry to get through it ...
Lou Metelko
Jim:
Only thing missing is the mention of the plastic sleeve that goes between the wire wheel and the tube stem. Without the sleeve the stem will eventually be "sawed off" by the minute movement of the stem on the wheel. Now if you want to see how quick a tire can go down then loose a tube stem some day! Ask me how I know!
Lou Metelko
Auburn, Indiana
Platinum
Amen, Randy!!
We get what we get. It's basically what's called: "Taking Responsibility" for ones' self.
Live wifit. :smirk:
Moseso
Andrew Mace said:
Think of the irony of someone getting far too close to said TR3 in an attempt to read the words.... :devilgrin:
Ewwwwwwwww!
TR3driver
Doesn't matter, they pull up until they can't see my brake lights anyway!
Geo Hahn
Related to the original topic, did you Randall (or someone else) once say they had the tire changer offered by Harbor Freight? Possibly this one:
https://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=34542
They also offer assorted tire tools and attachments for the above such as:
https://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=36133
Is this really a futile thing to attempt with low-priced equipment?
I assume the ad copy "No expensive 220V power hookups or pneumatic lines" really means you provide the power via upper body strength?
MGTF1250Dave
Aloha Geo,
Many years ago, in the '70s I bought a pair of tire irons from Moss and have used them to change many tires on wire wheels. One is a spoon type and the other is a lever to move the bead over the rim of the wheel. The lever ends have a small bend to catch and hold the lever over the rim. It isn't that hard to do. Art's method works well.
K TR2/3/3A Centering the brake rotors(disk)s in the front brake calipers using the shims? Triumph 5
T Looking for recommendations re using a Seacan for vehicle storage Spridgets 7
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
Oldi.Tec Spare Part Re-Manufacturing using 3D-Printing Restoration & Tools 5
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
L TR2/3/3A Who's using what to treat rusty stuff TR3 Triumph 21
Patrick67BJ8 Special Tuning using AF Equipment by Innovative Motorsports Austin Healey 27
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
CJD General Tech Boeing using Lucas parts? Triumph 7
TRMark General Tech Anybody Using Star Tron Triumph 2
Martinld123 Problem Using LED lights with Existing Brake Lamps Austin Healey 20
G TR4/4A Using existing fuel line Triumph 5
D Wanted How to locate my father's past Austin Healey1963 3000 Mark III using its Vin # Austin Healey Classifieds 5
B TR6 Timing using a vacuum gauge Triumph 13
Gerald_Gordon TR4/4A Attaching badges without using a badge bar Triumph 5
M TR2/3/3A What Lead Substitute + Octane Boosters is everyone using in there gas tanks? Triumph 14
Basil Admin Note Using FREE BCF Classifieds Triumph Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Spridgets Classified 0
Basil Admin Note Using FREE BCF Classifieds MG Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Jaguar Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Other British Classifieds 0
Basil Admin Note Using FREE BCF Classifieds Austin Healey Classifieds 0
Basil Admn Note Using Prefixes to filter threads of interest Triumph 5
KVH TR4/4A Using Drill to Spin Oil Pump Shaft Triumph 10
J Bypassing battery cutoff switch, using is as anti-theft only? Austin Healey 20
KVH TR4/4A Using the Engine Stand Triumph 3
K TR2/3/3A Clutch bleed using"gravity bleed" method? Triumph 4
KVH General TR Using an Old Fuel Pump Triumph 3
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
aseriesspares What Gearbox are you using. Midget 1500 Spridgets 5
J BJ8 carb sync using a Uni-Syn, can you actually use it? Austin Healey 42
Rut 5 speed conversion using the Datsun clutch assembly Spridgets 10
bthompson Using the brakes kills the engine! Any ideas why? Spridgets 17
K TR2/3/3A Using Moss front end alignment gauge? Triumph 6
M Healey Overdrive Accumulator Piston using O-Ring Seal Up-date Feedback Austin Healey 4
J Does a texas cooler make a real difference ? I now am using an a moss flex fan ! Austin Healey 24
drambuie Anyone using flame thrower Electronic distributor Austin Healey 6
Q TR2/3/3A Using DOT 5 Brake Fluid On TR3A Triumph 34
F Using 12 point ARP style rod and main bolts Spridgets 9
Nelson Using timing light Spridgets 17
M Anyone using a MaxJax on a BN2 ? Austin Healey 9
58Custom A14/A15 engine users: What yall using for headers? Spridgets 11
S TR2/3/3A Using a timing light for setting TR3 Timing Triumph 4
justin_mercier TR6 "new" steering rack for TR6 ? Anyone using one ? Triumph 5
T Using Midget Suspension parts on Nash Metropolitan MG 10
A Wedge Using TR7 Main Bearing Studs on a TR6: how to note Triumph 7
K Paging Martx-5...What valve gap are you using? Triumph 0
T using UNI-SYN tool Triumph 46
B Using an MG properly MG 7
