Results 1 to 5 of 5
Thread: Adjusting valves on a TR-4
  1. #1
    Join Date
    Aug 2005
    Location
    South Carolina, USA
    Posts
    25
    Blog Entries
    3
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Have a '64 TR-4 with 50,000 miles and am 5000 miles off an engine rebuild (I did not do the rebuild). I attempted to adjust the valves, cold, took out the plugs, put trans in neutral, took off fan belt and could not turn the engine over by hand. Blipped the starter and it rotated ok. What is giving me all the resistance?
  2. #2
    Yoda Geo Hahn's Avatar
    Join Date
    Sep 2001
    Location
    Mt Lemmon, Arizona
    Posts
    9,370
    Thanks Thanks Given
    14
    Thanked in
    Re: Adjusting valves on a TR-4
    No idea -- even a tight engine (after a rebuild) should be able to be turned.
    FWIW. for valve adjustment I just put it in 4th and push on the left front tire to roll the car a bit and turn the engine. Less chance of scraping my knuckles on the radiator plus pushing on a tire gives you a 2:1 mechanical advantage.
  3. #3
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    19,482
    Thanks Thanks Given
    8
    135
    Thanked in
    Randall
  4. #4
    Jedi Knight TR4's Avatar
    Join Date
    Aug 2004
    Location
    N.W. Ohio
    Posts
    824
    Thanks Thanks Given
    Thanked in
    Just curious, how have you been trying to turn the engine over by hand?
    Phil
    1964 TR4 CT 36223 L
  5. #5
    Join Date
    Aug 2005
    Location
    South Carolina, USA
    Posts
    25
    Blog Entries
    3
    Thanks Thanks Given
    Thanked in
    I put a monkey wrench on the fan hub, but that is almost impossible to turn.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
