Hello
Almost there now hopefully with getting the engine started. Have solved the fuel issue and have set the timing etc according to the workshop manual. When I turn the key the engine turns and fires once, then stops. As it stops a strange screeching sound can be heard coming from the bellhousing which I guess may be related to the clutch/starter or flywheel but we'll come to that problem later.
The carbs have been rebuilt professionally and are HS6's. I am figuring that the problem may lie here but I don't want to touch anything unless I make it worse. All the manuals I have talk about how to tune the carbs once they're running. So question is - what should I start to fiddle with first?
Thanks for your help.
Myles
Myles
