Spitfire 75 spitfire wood dash
Zer
Well I bought some veneer last week and with the help of a buddy we are in the middle of re-doing it. We used a heating gun to pull off the old stuff ( and a small blade ) We are looking for some STA-PUT It is really good stuff from what I hear. So as soon as we get it we will lay our the vaneer and cut and glue I think the whole thing will take about 2Hrs ( not including the staining ) then it is time to put all the stuff back together, new interior is waiting.
MDCanaday
Be very sure to use the UV resistant ureathane when you put on the finish, some were not ment to be outside with the top down at 70mph.........
MD(mad dog)
Z
Zer
Just wondering if anybody has tried to redo the chrome trim on the dash gauges???? Looking for what to use and what is the procedure????? Thanks folks for any info.
TR250
It may not be wisdom, but here's my two cents: Chome is chome, not paint. You either need to send them out, buy new, or just accept less than perfect.
Bugeye58
Z, I used Happich Simi-Chrome polish on the GT6 chrome bezels, and it worked nicely.
The only viable alternative, if you can't find new replacements, would be to remove them and have them restored at a plating shop. Kind of pricey I would imagine.
Jeff
screenprinter
May be a bit late to post on this thread, but here goes:
2 hrs. seems a bit optimistic an estimate - when I did the panels for my GT6+ it took me four hours just to carefully cut the guage holes, switch holes etc. out from the back of the panel with an x-acto knife. Even with new blades evry few cuts I found that the veneer likes to shred when you cut across the grain. Judicious sanding with very fine paper helped but it still looked a bit rough. The panels were okay, but after spending so long on the GT6 I opted for replacement panels. In my case I was fortunate enough to know a guy whose dad was a master kitchen cabinet maker. He took the old panels and duplicated them exactly in solid Honduras Mahoganey - Three or four coats of a marine sealer called Awlgrip, Allgrip, something like that, with wet sanding in between coats produced breathtaking results. I think he charged me about $100.00 - Which is still less than what Victoria and Moss get for their production line versions.
I might mention that for TR6's and other autos where the dash panel is one big piece solid wood is not really a good choice - The british bodies ( Particularly Convertibles) tend to twist a bit when you go on down the road, a thing known as "Scuttle Shake" and if the panel is screwed in too tightly it tends to break along the grain. I guess the way to attack one piece dash panels is to construct the panel out of premium grade plywood ( Which won't break when twisted ) and go the veneer route. That brings us full circle - I guess my summary would be: as Clint once said: "A man's Gotta know his limitations." - I'm a whole lot better at welding and turning wrenches than fine woodworking - so I opted to let a pro do this critical piece for me.
BritishCarMan Spitfire Wood Spitfire dash Triumph 5
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 0
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
3798j General TR Spitfire up in the Tree Triumph 2
E Spitfire '69 Spitfire hard top Triumph 2
D For Sale 1966 Spitfire 4 MK 2 for sale, Triumph Classifieds 1
R For Sale Spitfire MKIII projects Triumph Classifieds 0
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
G Spitfire Spitfire 1500 differential whining Triumph 6
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
A Spitfire Spitfire Fuel pump issues Triumph 5
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
Lairhead52 Wanted 78 Spitfire instrument panel lights / lenses Triumph Classifieds 3
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
R Spitfire Turn signal wiring Spitfire Triumph 5
S Spitfire Spitfire 1296 engines Triumph 1
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
C Spitfire 1967 Triumph Spitfire Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
T For Sale One Owner 1969 Spitfire for sale Triumph Classifieds 0
Dnickels Spitfire Spitfire lighting issues Triumph 4
SteveTheBrewer Spitfire Spitfire Rebuild Update Triumph 5
Basil Spitfire 74 Spitfire Barn Find Triumph 1
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
B Spitfire Mk3 seat rails Triumph Classifieds 0
M Spitfire 1500 LH Door Triumph Classifieds 0
P Spitfire Bits Triumph Classifieds 1
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
SteveTheBrewer Spitfire Triumph Spitfire Restoration Blog Triumph 22
R Spitfire Spitfire 1500 Triumph 3
T Spitfire Spitfire lights Triumph 7
Basil Spitfire How do I adjust SU carbs on my Spitfire? Triumph 5
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
glemon Spitfire Spitfire Questions Triumph 7
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
J For Sale 1974 Spitfire for sale Triumph Classifieds 0
F Spitfire Triumph Spitfire , what fuel to run Her on with no engine history? Triumph 11
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
eschneider Spitfire Float height - '64 spitfire w/ dual HS2 Triumph 1
S For Sale Triumph Spitfire Workshop Manual on CD/ROM - 1962 - 1978 Triumph Classifieds 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
