End of week Body Shop progress
Brosky
So far, so good. Getting the major stuff done and getting ready for painting. The front panel was prepainted, cleared on the back and is ready for welding in place today or Monday.
The fenders are pretty much pre-fit and all of the powder coated bumper braces are on and the wiring has been run.
Both doors have the parking lot dings and my wife's battle scars between the grass rake and the deck lid has finally been healed.
Brosky
Brosky
Oh yeah, the inner fenders were cleaned and painted with two coats POR15 and the drain outlets from a 1966 Mustang 1/4 panels that I ordered from CA are on the way. More to follow on that drainage issue next week.
BobbyD
Paul.......... looking real good! You're tempting me to pull my fenders just to POR-15 the inner fender! I'm just afraid that it would mess up my paint more then it already is.
It looks like you got the radiator cap with the built in temp gauge?
Brosky
Brosky
Bobby,
Mr. Gasket radiator cap, with pressure gauge. Kinda neat!
Tom,
If I were filming them, I'd have to pat Screen Actors Guild scale and this is expensive enough.
TR4nut
Paul-
Looking real good. Could you talk a little more, or give a link to the drainage outlets you mention? I will be redoing baffles at some point on the TR4 and am looking for options.
Randy
Brosky
Brosky
Just for the record, as I was asked off line. Yes, I do have to pay for the little dings in the doors and the POR15 and drain work, but that's minor in the grand scheme of things. Hagerty was fair, so I'm not taking advantage. I was happy with the settlement and the extras are mine to pay.
TR6BILL
Paul, I have one word for you. <span style="font-size: 20pt">Ratco!
</span>
I know you would really like to jerk that beautiful body and slide a shiny new Ratco frame in there. Wouldn't that be sweet?
Bill
Brosky
Brosky
Bill,
My frame has been stripped to bare metal, prepped and painted completely with POR15 and then every attaching part has been blasted and powder coated, with all new bolts and bushings and reinstalled. It's like new under there already.
Tom,
He did the hood three years ago and is aware of the mirror look in the polished radiator shroud. Any mistakes show up twice with that thing installed.
Randy,
I'm going to install the rubber slotted one way drain vents that were used on the early Mustang quarter panels as a shield to run the line from the hose shown in pictures #1 & #2 to the inner splash shield, high enough above the tire spray to negate any possible water coming in.
I should have them early next week for a better look and posting of what we are going to do. https://www.americanpony.com/store.mv?p=597200
TR4nut
Paul-
Hadn't seen those before, I definitely would appreciate a photo of the installation. I don't like the other option often used of routing through the sill, mine are in questionable shape already.
Randy
toysrrus
Hi Paul,
All I can say; "Its looking really Grand"!!
Russ
Brosky
Brosky
I just checked with Mustangs Plus in CA and my little drain project rubber parts are due here on the 1st, so I post a separate thread for that.
BillW103 Week end car show Spridgets 2
kcbugeye1275 Week end driving Spridgets 23
kcbugeye1275 great weather for the week-end Spridgets 8
M Layshaft End Play Austin Healey 7
M T-Series MG TD 1st/2nd sliding hub end play MG 1
D ARP big end bolts. Spridgets 7
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
G MGB '71 MGB Front End Rebuild MG 2
AUSMHLY Synchromesh Hub End Float Austin Healey 1
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
X Front End Alignment Austin Healey 14
craigshealey3000 Front End Shake Austin Healey 31
B MGB Mgb crankshaft end play shims MG 2
AUSMHLY Lucas Generator C42 End Caps Austin Healey 3
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
B Bent frame rails near BE front end Spridgets 2
S Rear End Noises Spridgets 28
Walter74 Steering Box End Play Austin Healey 2
S Sway Bar End Links Austin Healey 15
K TR2/3/3A Removal of tie rod end? Triumph 7
roscoe Rear end crown and pinion gear swap. 4.11:1 to 3.54:1 [long read] Austin Healey 12
S TR2/3/3A Cutting the finish end on the windshield top rubber Triumph 4
B 2013 Nissan Frontier front end mystery Other Cars 7
K TR2/3/3A Front wheel bearing adjust and end float?? Triumph 10
J TR6 End Float Triumph 5
Jayplum TR2/3/3A Steering Box end play Triumph 6
J TR6 Top End Chatter Triumph 11
A TR2/3/3A Rear end locked up Triumph 6
drooartz MGB Talk to me about bottom end bearings MG 34
B BJ7 back end rebuild Austin Healey 1
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
R Connecting Rod Big End Specification Austin Healey 4
Michael Oritt Lube points on BN/BT7 front end Austin Healey 4
K TR2/3/3A Advise on previously botched front end lower fulcrum support bracket. Triumph 5
AUSMHLY BJ8 Front End Squeak Austin Healey 25
AUSMHLY 64 front end too high Austin Healey 14
John_Mc TR6 Twitchy rear end Triumph 18
T TR5/TR250 Wiper wheel box knurled end not tight on arm Triumph 9
J TR2/3/3A Hastings Piston Ring End Gap Issue Triumph 16
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
Rut TR4/4A Rear end questions Triumph 8
R TR2/3/3A Establishing distributor shaft end float Triumph 4
S TR2/3/3A steering bracket that fits under the dash for the end of the column Triumph 2
thibault BJ8 plus 55mph Front end shaking Austin Healey 100
vette Effects of Lowering the Front End Austin Healey 21
H For Sale Rear end bearing and seal set Austin Healey Classifieds 0
R TR2/3/3A Lube for steering box, transmission and rear end Triumph 6
E For Sale Tr3 rear axle, rear end Triumph Classifieds 6
TAS525 TR2/3/3A Missing zerk from inner tie rod end Triumph 7
T TR2/3/3A Drive end of speedo inner cable to large for pinion Triumph 2
