Coolant to use.
2wrench
I have in the garage a new bottle of Prestone "Any Color,"
coolant and want to know if there would be any problems
using the stuff. What might you recommend?
Don Elliott
Water is reputed to be a better heat transfer agent than antifreeze and since I don't drive my TR3A during our frozen winter seasons, I use about 25% antifreeze and 75% water. I use de-ionized water that I buy at my local drugstore or I use the water that I collect from my de-humidifier. This helps ensure that there are no hard calcium or other undesirable unknowns in the water. The antifreeze is only there to prevent the water rusting the cast iron interior cooling passages in the engine block.
It'll soon be time to drain it all and re-fill the system again for about the third time in the last 18 years (100,000 miles) and I have had a bottle of Water Wetter on the shelf for abbout three years that I won as a door prize somewhere, so I was thinking I'd dump that in as well.
2wrench
2wrench
My radiator shop guy shared with me a trade secret, which I will pass
on to the Forum. He said to me: Put one cup of soluble oil into this
radiator (just rodded and flushed) and I dare say that I will never see you back to my shop again.
Wow! I bought the soluable oil and intended to add it to my radiator mix
along with the antifreeze. Now I'm thinking just to go with water and
soluable only. Any thoughts?
By the way, the raditor guy is a huge Vintage Car Resto buff. He has
a few such cars in his garage as well, but no LBC's.
Snake oil or True Value soluable oil...which do you think it is?
TR3driver
Great Pumpkin - R.I.P
Might do OK at protecting the radiator against corrosion, but I sure don't think it will do anything for the aluminum thermostat housing bolted to a cast iron head, not to mention the aluminum plug in the top of the head.
Antifreeze has chemicals to prevent dissimilar metal corrosion, which soluble oil cannot do.
Also, the oil eventually forms a coating on surfaces, which isn't going to help cooling any.
Mkutz
Sherman was on the board a month or so ago and mentioned a Toyota coolant, red in color I think, that was produced for cars a few years old, worked really well. Sherman, which one were you talking about?
Brosky
I asked him if there was a part number for that, but I don't think that he replied. It would be nice to have to call ahead with.
DNK
The Toyota is recommended for the Wedge V8 motors as it is comfy with the Al. motors.
philman
I am going to use red pentosin, used by mercedes, bmw, saab, volvo, etc when I get all the bugs worked out. Just using water right now until I pull the radiator one last time. It's about $10/liter online.
DNK
Maybe it was Volvo or Saab
I remember it was RED in color
S Spitfire Cyl head coolant hose fitting Triumph 1
Patrick67BJ8 Coolant Overflow Tank Austin Healey 21
B TR6 Triumph tr6 coolant leak Triumph 4
B Oil (or Coolant) Leak Austin Healey 10
FlyingCat Spitfire Losing Coolant Triumph 12
M TR6 1973 TR6 Coolant Type? Triumph 5
R Coolant temperature gauge Spridgets 8
Govtslug TR6 Coolant Temp Q Triumph 4
T TR2/3/3A TR3 coolant hoses Triumph 2
K TR2/3/3A Hot day coolant overflow issue.... Triumph 1
nevets Coolant Temperature Austin Healey 13
L BMC A-series: Oil in coolant British Motor Corp 6
Got_All_4 TR6 Oil in the coolant in my TR250 Triumph 6
K TR2/3/3A Radiator coolant level? Triumph 5
M TR6 '72 TR6: Oil in Coolant Triumph 25
W TR2/3/3A location of the coolant drains on a tr3a Triumph 4
Got_All_4 Wedge Tapered coolant hose for a PI car. Triumph 3
Paulus TR4/4A Coolant pressure Triumph 5
D TR2/3/3A Coolant tap on TR3 block Triumph 3
gfholl Coolant Leak Spridgets 9
C TR4/4A TR4 coolant leak through aluminum plug in top side of head Triumph 6
M Coolant 'overflow' when not overheating.... what's up? Spridgets 34
S TR2/3/3A Replacement of Engine Coolant Drain Triumph 3
B All the coolant in the wrong place Spridgets 17
G TR4/4A Thoughts on my coolant Triumph 12
D TR2/3/3A TR3 Engine dumping Coolant out its rear end - HELP Triumph 5
D TR2/3/3A Block coolant passages plugged - pull the head? Triumph 46
JFS Wedge Low Coolant Light Triumph 7
Boink Waterless Coolant - thread from the AH forum Spridgets 18
PatGalvin TR2/3/3A Coolant System Hoses Slipping Triumph 5
RJS TR4/4A Head Leaking Coolant after Coolant Flush Triumph 15
Jim_Gruber Replacing Spridget Coolant Spridgets 21
T TR4/4A Coolant in the oil - again. Triumph 18
Jim_Gruber Coolant Bypass Nipple on 948 Welded Closed - Advice needed Spridgets 7
P Coolant level indicator wrong? Jaguar 4
sparkydave Coolant hoses Spridgets 5
T TR4/4A Oh crud - coolant in the oil Triumph 33
W Waterless Coolant Austin Healey 4
R TR2/3/3A Normal vs Max acceptable coolant temperature? Triumph 14
RAC68 Waterless Coolant Austin Healey 29
B TR2/3/3A coolant expelled Triumph 14
Keith_M 1275 burning coolant Spridgets 20
S Coolant Loss Spridgets 32
S Air/Fuel Mixture affect on Coolant Temperature? Spridgets 2
M oil in coolant Austin Healey 16
M TR4/4A Coolant. Triumph 7
mgedit TR2/3/3A Coolant spit out of overflow Triumph 20
Keoke Waterless Coolant Austin Healey 12
S TR6 waterless coolant Triumph 6
MY66AH Coolant Leak From Fill Neck Spridgets 3
