Engine code question
Jorgen
I us picked up an engine (looks like a spitfire engine to me) and was supposedly from a spitfire. The engine code is BE 97948 E which I can't find being a spitfire engine or any other car for tat matter. Anyone know what BE engines were out of?
Sorry if this is a stupid question, kind of new to the whole British car thing and can't seem to find this one on my own.
DNK
Maybe a Standard 10?
Between Jan and Oct. of57. Older than moi!
J
Jorgen
I found info on a standard being a possible option but didn't think this bugger was that old looking. Guess maybe so.
Andrew Mace
WE have a winner! BE 97948 E is indeed a 948cc Standard 10 or Triumph 10 single-carb engine. (Note that, unlike DNK, said engine is four years YOUNGER than yours truly...OUCH!) Nice little engines, actually...IF in a Triumph 10 or early Herald. :wink:
J
Jorgen
Andrew, Thanks for the confirmation on that one. Hmmm well that engine is of no use for me to keep around, would this thing be useful to anyone around here?
Andrew Mace
Sadly, they're worth little to nothing unless you can find someone with a Triumph 10 or early Herald and who really wants an original-type engine. It's almost certainly not worth shipping any great distance. You might try contacting someone in the Detroit Triumph Sportscar Club as well as offering it on the VTR web site (where they have free online classified ads).
I'd take it, but I'm in Eastern NY (see above re: shipping). :frown:
J
Jorgen
Thanx for the info. I will be poking around on this engine tonight to look over its condition a little closer after that if it is useable I willtry and find an owner before pursuing other options.
M MGB Help with engine code question. MG 5
doc50 MGA Decipher MGA engine Code MG 4
J Engine Error Code - Fuel 17 Jaguar 8
B Engine Code Help MG 1
JeffS looking for PPG engine green paint code.... HELP! Austin Healey 9
W Morris Green Engine Paint Code Spridgets 4
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
R TR6 question re: Engine Oil Triumph 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
kodpkd 1961 BT7 engine oil Austin Healey 31
S TR2/3/3A engine removal Triumph 12
R TR2/3/3A Engine stalling and backfiring Triumph 25
