MGB Question about ignition wiring unique to 1980 MGB
Naomi
In the last few weeks I've burnt up two coils in my 1980MGB. Now that the hubby has had time to reflect he has came up with some conclusions, some thoughts, and of of course some questions. He is thinking that the last coil burnt up because my Brothers were going by the Bentley "1978 & Later MGB" and the Haynes electrical diagrams -- both of which he is sure is not correct for an 80 MGB when they replaced a coil for me.
<span style="text-decoration: underline">
<span style="font-style: italic">Interesting Fact and quote from Moss:</span></span> "The original Lucas "Opus" electronic ignition used from 1975 to 1979 featured the ignition amplifier mounted on the distributor body. As this system proved unreliable, <span style="font-weight: bold">it was replaced in 1980 with the CEI system, which used a remote amplifier".</span>
<span style="font-style: italic">What The Hubby Thinks: </span> </span>
1. The green white wire from the starter solenoid does not come into play even though it was left over in the harness from the previous years. Not needed because the coil uses 12 volts all the time.
2. No distributor resistor comes into play.
3. The resistive ballast wire does not come in to play even though it was left over in the harness from the previous years.
4. The coil positive side is fed from the whit wire at the ignition and not the ignition relay. If it is fed from the ignition relay there is enough voltage feedback when the key is turned off that the engine will continue to run.
<span style="font-style: italic"><span style="text-decoration: underline">What The Hubby Knows :</span> </span>
1. The ignition circuit is completely different that that shown in the late MGB schematics.
2. There are only two wires feeding the electronic (amplifier) on the 80 and they are a white and a white/black wire.
3. The 80 model year can be distinguished very easy because it has a remote amplifier with the coil mounted on top of it.
4. There are two wires, a red and a green, which feed the distributor from the amplifier.
<span style="font-style: italic">Questions For You The Experts:</span></span> Is the hubby right with what he thinks and what he knows? Has anyone ever drawn a schematic to show correctly the ignition wiring of an 80 MGB? I hope this post makes sense and is not to long and boring.
Your turn :smile:
terriphill
OK, Naomi....having just fought this battle with our 1980 B...
WHen we got it the ignition had been bypassed and a push button start added...so....
we added an electronic ignition and new ignition switch. We pulled the entire harness because we thought it was the wrong one for our car...it just needed some tweaking.
The first picture is the solenoid...the red and black on the front are from the coil.
The black and white and green and white are from the starter.
We cut and taped off those other wires because they were no longer needed with the electronic igntion.
I don't know if ours is "right" for an 80 B, but when I trun the key it fires up. We played heck getting any pictures that resembled what we had underr our hood.
Maybe these will help
N
Naomi
Thank you so much for the pictures and message! It is odd how the 80MGB is wired and I do hope others will pipe in and we can see the different ways the 80 model are wired and if anyone has a period correct one. Thanks again :smile:
PAUL161
If this is it,
Hard to believe the cost is over $300.00
N
Naomi
Re: Question about ignition wiring unique to 1980
That doesn't look exactly like it. I have pictures but when I try to post them I get a message that they are to large and I don't know how to downsize them :frown:
Dave Richards
For what it's worth (IMHO):
We just went through this mess with a '78. Take that piece of junk out of your poor car and replace it with the older style 25D distributor. It's simpler and it works.
I wish someone had been bold enough to tell me this initially!
Call Jeff at Advanced Distributors. You'll be glad you did, <span style="text-decoration: underline">AND</span> it will cost you less than the replacement electronic module
Dave Richards
Use this, it's free and was recommended by a fellow BCF'er.
PixResizer
tony barnhill
Great Pumpkin - R.I.P
Hi, Na - glad to see you.....looks like you're getting lots of help...I don't have an '80 to take photos of but I can agree with contacting Jeff - or, as an option, install a new Pertronix distributor from Moss.
{Oh, for those of you who don't know Naomi...she's a Virginia mountain girl who drives the 'you know what' out of her MG's & who isn't afraid to get her hands dirty working on them...she's finally convinced Bill (who's retired & just wants to fish) to help her out with her cars....we need to help her solve the problem so she'll stay over here!}
Hi Naomi, you still have the Fiat, or did you manage to sell it?
jessebogan
Just a tip for those with the 80 style ignition. If the amp fails (rare) if you open it up, there is a GM (General Motors) HEI "chip" inside. A good parts store can cross over the number for you and the new GM part is cheap!! I am told, but have never verified, that the original GM chips are best, with the correct dwell.... The last one I bought was for a Jaguar, and was less than 50 bucks.
terriphill
Naomi,
After looking at that piece, I know that ours doesn't have one. so, I guess the pics aren't much help. It was such a mess when we got it that we pulled the harness and dash and steering column wiring and reworked it all by tracing wires with a wiring diagram, I guess I got lucky cause it may not be right, but it runs great!
Can't wait to get some wheels and rubber underneath so we can get it out of the garage...November will be one year and I generally like to say,"it only took us a year to get it running."
N
Naomi
Hey thanks a bunch folks and sorry I didn't introduce myself in the original post. Tony is right about one thing --- I do drive the daylights out of my B's and have just returned from a real Virginia mountain trip. Our B's are wonderful cars and I've owned em for decades --- well ever since I was sixteen.
Thanks again and I always know where to turn to for "expert advice and fun folks".
Oh, the Fiat is history -- sold it - and one of the most happy days of my life whe I saw it being driven away !!!! :smile: :smile:
cashs6t8mgc
This is an old thread but I just recently started to revive a 1980 rust-free barn find my son-in-law rescued. The car has been dormant for 8 years or so. So far I repaired the ignition switch wiring, that had been cut and poorly spliced, changed the oil and filter and spun the engine to 50 psi oil pressure. In checking the ignition, I found that the original 1980 only distributor has been replaced by a brand new points type distributor, It has apparently never actually worked. The interior of the dizzy is bright and shiny and the cam follower wiper is clean and oil free as is the shaft lubricator batting. All of this is to try to find the best way of making the retro distributor work. The PO apparently thought the enhanced spark amplifier should be connected to the neg post on the coil, so the neg post has two wires, one from the amplifier and one that goes to the points on the dizzy. After reading this thread, I've decided to disconnect the amplifier and give it a try. Any comments?
cashs6t8mgc
I removed the wiring between the coil and enhanced spark module. Achieved spark at the points.
Platinum
If you have trigger at the points, you should be good to go. Rig the coil and plug wires, static time the beast and go for a spin!
T Question on ignition switch wiring Triumph 10
G Ignition / Coil Wiring Question MG 12
SherpaPilot TR6 Ignition Switch Question Triumph 13
Lin Ignition timing question Spridgets 2
Lin 123 Ignition Question Austin Healey 0
catfood BN1 Ignition question. Austin Healey 14
charleyf TR6 distributor--ignition question Triumph 5
PatGalvin TR5/TR250 TR250 Ignition Key Question Triumph 4
longbridgehealey New Bugeye ignition switch question Spridgets 10
nevets BN6 ignition parts question Austin Healey 3
T TR4/4A TR4A ignition switch question Triumph 19
C Ignition coil question Triumph 4
T TR4/4A TR4a ignition switch question Triumph 5
G ignition key/lock switch question Spridgets 0
Monark192 Ignition Switch / Steering Lock Removal Question Spridgets 1
Ohiobugeye Pertronix Ignition Question Spridgets 7
Got_All_4 TR2/3/3A TR3A Ignition Problem / Question Triumph 11
RobT Pre-Ignition [Pinging] Question Triumph 21
G Ignition question. Triumph 5
T Ignition parts question Triumph 23
M Another Ignition Timing Question Austin Healey 8
tosoutherncars Crane ignition question Spridgets 15
Atrus Yes, another electronic ignition question Spridgets 2
Atrus Crane/Pertronix Ignition Question Spridgets 11
D Ignition Question [Ultimate Dummy Question] Spridgets 10
Morris 'nother ignition question Spridgets 2
F Re: crane xr 700 optic ignition system question MG 10
John_Mc Ignition question Triumph 6
TNMGB Steering wheel lock and ignition question... MG 11
N Ignition Opinion Question MG 21
A Rookie Ignition Timing Question - Micrometer Adj? Austin Healey 8
S Ignition question MG 5
txtr3 basic ignition timing question Triumph 3
EMGEBE MGB MGB Ignition question MG 9
philman Wedge ignition question tr7 Triumph 6
B Pertronix ignition question MG 12
DonC1948 TR6 A "CLASSIC" question. Triumph 6
71TR6 TR2/3/3A A TR3A wiring question Triumph 17
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
scottkilpatrick TR4/4A Gear oil and choke question Triumph 4
B TR2/3/3A TR3A Gearbox fluid capacity question Triumph 7
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
K TR2/3/3A Brand new brake caliper question... Triumph 8
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
R TR6 question re: Engine Oil Triumph 3
