TR250
This weekend I was surprised (I know I should have expected it!) to find an eraser sized hole in the frame while replacing my trailing arm bushings. I was cleaning off all the undercoating the PO had sprayed on to inspect and found a "blister" which revealed the hole. Poking and banging I find the weakened portion (that which would give under the force of a 5#ball peen)only extends to about a quarter sized patch.
Here's the question: Do you think a small repair plate bolted or welded to the side of the frame will last? I'm hoping this repair method would last about ten years. What do you think? Any experiences here? /ubbthreads/images/graemlins/confused.gif
