Need Some Advice on a BE Emergency Brake
mxp01
Gentlemen:
Last year we dismantled my 1960 BE for paint. We did so quickly and without complete note-taking of all the dismantled items.
Since we have re-assembled the car we have hooked up the E-brake but we do not have any tension on the cable. In other words, when we pull up the e-brake it does not squeeze the rear brakes at all.
I do not have a workshop manual and the cable does disappear into that transmission tunnel, so we can't easily see it. Can someone provide me directions on how to get this adjusted to work?
Mike Pennell
healeyboz
You have to adjust the "sleeve" on the cable to take up the slack. There are two nuts that can be adjusted.
Pythias
unfortunately, (or not) the starting point is when you do the rear brakes and have it all apart.. that's the time to loosen the adjuster and get everything "set". RIGHT after you finish your brake job, You can tighten it up. (its UNDER the car. If you crawl underneath and look at the steel arms that run on top of the rear axle into the brake drums, then look at the cable that attaches to it, you'll see how the adjustment works.....Try it without the brake job. IF, after turning the double nuts all the way tight you STILL don't have a hand brake, .... .. and WANT one.... gotta go back to square one on the brake job.. undo the adjuster all the way, do the rear brakes..
at least that's what i've heard.
JPSmit
did you get this sorted out? I can post pictures later today if you need them
let me know
M
mxp01
We haven't had the opportunity to get to this yet, perhaps this weekend. However, if you can post photos that would be very helpful.
Mike Pennell
JPSmit
OK here's the pic - background is dark and you're looking straight up from the bottom. To locate, the two rods going left and right go to the hubs and you can see the bottom of the diff to your left.
The adjustment takes place with the two nuts that hold the cable to the top of the flange. (where the cable shield is). It's real easy, just don't do what I did and adjust backwards. loosening on the flange tightens on the cable.
https://tinyurl.com/4egbda
hcallaway
1 Can anyone tell me by looking at the picture if this position of the emergency cable is at the beginning of the adjustment range?
2 Since I have to cut and extend my rods should they be completely relaxed without any drag on the drum (the leaver touching the backer plate) or have the leaver with slight tension.
3 I have 1/4 steel sleeves that I will weld in place. I am not threading as I have cheap dies so I have to get this right the first time. I am thinking if I have the cable at the beginning of the range of adjustment I should be able to tighten as needed.
JPSmit
I am thinking that the picture from JPSmit that this would show the cable at the maximum tightness?
I think it is my cable is a bit stretched.
hcallaway
JP
1 Did you put some drag on the brakes before you adjusted?
2 Was your emergency brake all the way released? (I understand for later model cable systems that you put it in the 3rd click position and adjust from there.)
Thanks for the quick response.
Holt
nomad
Agree that JP's cable is at maximum tightness adjustment. I would adjust the brakes correctly for the street and loosen the cable and go from there. There should be a little bit of give in the system one way or the other.
Kurt
JPSmit
JP
Holt
For a long time I just went with a slack ebrake - then I figured out that I hadn't thought about the location of the drums when I set up the ebrake.
So, I first adjusted the drums tight enough to hold the wheel - and then let them off just enough for the wheel to spin - this act alone tightened up the ebrake enough that I didn't worry to tighten the cable any more - it still isn't the third (or close) click position - it is closer to the end of the range but, it is good enough. IIRC a few years ago (at least 10) there was a long conversation about replacement cables not being as good as the originals - too stretchy - so, for now I just leave it and don't park on hills. :grin:
Hope that all makes sense.
M
mxp01
Wow, a 10 year old post reappeared! This was from my first BE, which is still operational and in the hands of an avid car collector in the Bahamas. Since that posting I moved to Nassau, Guadalajara, Kabul, Basrah, Jeddah, and next month Riyadh.
MXP
W Need advice on installing new side curtain glass Spridgets 1
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
N Need brake bleeding advice Spridgets 6
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
Jer Thinning the collection, need some advice on pricing parts including a hardtop Spridgets 8
Bayless Need wheel bearing advice please Spridgets 4
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
davester Just got my Sprite back [in pieces] after 42 years...need advice Spridgets 8
T Need advice for installing a Winner's Circle Panhard rod on a BE Spridgets 4
M Need Advice On 948 Engine Rebuild Spridgets 7
R Need Advice On Refinishing A Bugeye Hardtop Spridgets 15
D Need Some Advice on My 1967 BJ8 Austin Healey 8
M TR5/TR250 Need some advice on TR250 Triumph 22
Jim_Gruber Need advice on how to fix this one. Spridgets 7
Jim_Gruber Issue with removing front drums and spindles on BE- Need advice Spridgets 5
R TR4/4A Need Advice as to what to do regarding Engine Compression Problems Triumph 26
J MGB Need some Exhaust flange advice MGB< but really any of our old cars MG 0
Jim_Gruber Bugsy II - Planning Welding - I need some advice Spridgets 14
B Cylinder Head - Need advice Spridgets 5
drambuie Need advice How to Install a volt gauge properly Austin Healey 16
Parker MGB MGB Chrome trim strip installation... need advice! MG 10
M Need advice on fitting rear pillar interior trim.... British Motor Corp 2
Patrick67BJ8 Painting inside of block with Glyptal-need advice Austin Healey 10
I Need some advice on bugeye conversion Spridgets 8
R TR2/3/3A TR3 Seats - Need advice Triumph 9
A need advice on fuel pump Triumph 12
britlover TR5/TR250 Looking at TR250, has issues, need advice Triumph 9
tri_carb_healey need some advice Austin Healey 8
Coyote1 Overider Restoration - need advice Triumph 1
B TR2/3/3A Need advice TR3b inner sill replacement Triumph 16
T T-Series Need Advice - MGTF Steel Wheels Need Attention MG 2
T T-Series Need advice re MGTF rack and pinion removal MG 4
T Need exhaust header advice/source for Amos Triumph 49
J need advice renewing front lower A-arm Spridgets 31
W restoring a BN2 - need advice on sheet metal Austin Healey 10
Sprocket Barake drum locked up - need advice Austin Healey 7
R engine trouble, need advice Spridgets 16
B I need some advice/suggestions.... Triumph 10
L Need advice on this 1953 XK120M - HELP Jaguar 7
R smiths guage problem- need advice Austin Healey 4
bobmga62 MGA mga hardtop... need reconditioning advice MG 7
kyreb1862 Need Some Advice MG 2
H Need advice, Should I Wrap the Exhaust Pipes? Austin Healey 7
jackq O/D problem..need advice MG 8
M Pulled the Trigger...Now I Need Advice! Spridgets 20
B T-Series Need advice on a 53 TD MG 2
T Need advice on a 1275 Spridgets 6
PATR8 Need advice on a new project [Volvo 240] Other Cars 19
