1500 UK vs Usa specs
JoeV
Member
Does anyone know the differences in engine specs for the 1500? Is there more than the twin Su's
Are the cams and such the same? It appears there is 7hp difference could that just be in the carbs?
could I use a spitfire setup pre single Zenith if I could find one in a wrecking yard?
thanks
Joe
77 1500
tony barnhill
Great Pumpkin - R.I.P
1500 Midget/Spitfire engine is totally different from Midget 1275 engines if that's what you're asking....nothing off the 2 will interchange - well, nothing of any importance!
aeronca65t
The 1500 Euro/Canadian Spit-Midget engine have 9:1 compression. Almost all the USA 1500 BL models of those engines have 7.5:1
I think the cam is a diferent part number too.
And, of course there's no cat-convertor on the Euro/Canadian models.
Mark Jones
<blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr>Originally posted by JoeV:
thanks
Joe
77 1500
<hr></blockquote>
The twin SU HS2 setup off a Mk III Spitfire will fit on the 1500 engine I believe. I would suggest though that you look at the price of an HS4 setup from someone like TSI. You wll also see the HS4 setup on Ebay every so often. I put and HS4 setup on my 1500, which I purchased from James Paddock on the UK. The car feels a lot more powerful with the twin SU's compared to the single Stromberg.
Mark Beiser
Well, one good thing about the US spec engine.
It came from the factory already set up with the low compression pistons and mild camshaft that make it great for adding a supercharger to.
78Z
<blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr>Originally posted by aeronca65t:
<hr></blockquote>
the Canadian models are different? So I'd have the 9:1 CR but the single ZS carb? How would that affect power?
spritenut
Back in 74 when my 73 Spitfire 1500 dropped a main bearing, I stuck a 1296 Spitfire in it. It had twin 1.25 SUs where the 1500 had a Stromberg.
What a difference a smaller engine made!
The 1296 and 1500 have the same bore, just different compression ratios. Not sure about the cam.
But if you find a 1296 spit engine at the junk yard, grab the whole engine. It's worth it and will fit the midget.
The 1500, had a longer stroke. Right? That is where the extra CC were gained?
78Z
<blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr>Originally posted by Trevor Jessie:
The 1500, had a longer stroke. Right? That is where the extra CC were gained?<hr></blockquote>
yes - a stroked 1296
Thor Lowering 1500 where to purchase parts in USA ? Spridgets 7
C LCB header with 1500 single carb inlet manifold Spridgets 1
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
G Spitfire Spitfire 1500 differential whining Triumph 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
G T-Series 1955 mgtf 1500 lites MG 5
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
G 79 Midget 1500 overheating Spridgets 2
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
M Spitfire 1500 LH Door Triumph Classifieds 0
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
R Spitfire Spitfire 1500 Triumph 3
B MGA Solution! 1600 harness in a 1500 MG 1
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
R Spitfire 1500 gearbox question Triumph 1
R 1500 gearbox question Spridgets 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
A 76 Midget 1500 Oil filter Spridgets 6
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
M Rocker feed kit for 1500 from Victoria British Spridgets 0
sparkydave 1500 battery cable colors Spridgets 1
GS67 1500 Operating Temperature Spridgets 2
doc50 Nash Metro w/MGA 1500 discrepancy... Other British Cars 2
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
B 1500 head studs Spridgets 3
DrEntropy For Sale MGA intake manifold [1500] MG Classifieds 0
busybrit For Sale 1960 MGA 1500 Restoration Project for sale. MG Classifieds 2
sparkydave 1500 clutch master Spridgets 4
Steve P. 1500 radiator in an earlier 1275 cross flow Midget? Spridgets 2
P Pristine MG TF 1500 Spotted 0
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
aseriesspares What Gearbox are you using. Midget 1500 Spridgets 5
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
AN5Sprite T-Series 1955 TF 1500 For Sale This Spring MG 3
JPSmit 1500 slave cylinder question Spridgets 0
bigjones Vacuum advance on a 1500 Spridgets 13
Rut 1500 gas pedal for sale Spridgets 7
dklawson Spitfire Spitfire 1500 Block Decking Following Boring ??? Triumph 4
dklawson Spitfire Spitfire 1500 - Front Pulley Nut Removal? Triumph 2
DanLewis Two midgets available: '79 is free [no engine, trans], running '77 $1500 [NFI] Spridgets 1
