Single Carb 1275
aeronca65t
Occasionally, I get to drive another racing Spridget owned by my friend Pete. "#23" is a '63 quarter elliptic car with a 1275cc engine. After fooling around with the normal HS2 carbs for the last few years, he tried something different this year. He installed an MG Metro single carb manifold. This setup (which is Euro only) comes with an unusual-looking SU carb that has the float chamber under the main jet. It looks to be about 1.75" at the intake side. He's been real happy with it and will likely run it next year again. It works very well: I personally took this car up to a calculated 107 MPH at Summit Point.....about 10 MPH faster than my 1500 Spridget. Another 1275 Sprite racer was so impressed that he said he was going to troll e-Bay for a similar setup. If you're looking for a nice, simple carb setup for a 1275, this is worth considering.
Here's #23:
Here's the single carb 1275 MG Metro setup, in this case with the addition of the factory turbo (93 HP!).
aeronca65t
aeronca65t
Jeff:
You're correct...it's an HIF44 carb (and it is 1.75", according to Minimania). I'm not familiar with the HIF, but I like it's compact design.
They have the manifold for $225 and the carb for $200 (all USD). More than I would pay, but may be better than the popular Pierce/Weber combo, which costs twice that.
And I see that they have made some slight improvements to the Minimania website (it used to be He\\....now it's at least like Purgatory).
HIF44 SU carb
The manifold that minimania sells might not set the carb at the correct angle/height. This topic freq. appears on the UK mg spridget BBS https://www2.mgcars.org.uk . You can search the archive for more information
Xracer
A lot of Mini owners with 1275+ engines run the HS6 or the HIF6 (internal float) 1 3/4" carb. Works really well on the A and A+ block engines....especially if you have hotter-than-normal cam.
My Mini Cooper is running a 1293cc A+ block with a 940 cylinder head, 649 cam, and an HIF6 carb on a Torquemaster intake manifold. Works great!
aeronca65t
aeronca65t
<blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr>Originally posted by Trevor Jessie:
The manifold that minimania sells might not set the carb at the correct angle/height. This topic freq. appears on the UK mg spridget BBS https://www2.mgcars.org.uk . You can search the archive for more information<hr></blockquote>
He did have to make a "power bulge" in the hood to get this carb to fit. Not sure about any float angle problems....like I said, this one seems to work well.
spritenut
The ole HIF 44 or 1.75 SU. I have 2 of those set ups. I went back to a Weber DCOE.
I ran the single SU on the A40 (stock 1275) and upgraded to a Weber 40 with in a week.
I tried the 1.75 on my Sprite and took it off before the day was done.
I have since lent the SU set up to a racer for his Sprite, he quickly went back to the Weber too.
I keep hearing how people like this setup but have those people compared EACH setup?
2 different SUs, a bunch of different needles, and 2 different intakes, no difference in any combo on all 4.
R 1275 engine with SU HIF single carb Spridgets 9
T Single Weber Redline carb for stock Midget 1275 Spridgets 12
C LCB header with 1500 single carb inlet manifold Spridgets 1
M Carb Conv Kit, Weber Single Downdraft conversion Spridgets 15
Ofcalipka Zienith single carb problems. Spridgets 34
Ofcalipka Zenith single carb problems MG 62
mgbmedic Single Zenith Carb- Results MG 1
mgbmedic Single zenith carb is a joke... MG 19
J Spitfire Spitfire 1500, setup for single Weber carb Triumph 2
J Setup for single Weber carb Spridgets 4
pbraun Single HS2 on an 850 Mini Moke acting odd British Motor Corp 10
shadowfever Single SU on Spridget Spridgets 3
idlehands Wanted WTB GT6+ driver (LHD) window glass and a single rostyle wheel cover Triumph Classifieds 1
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
AUSMHLY 65 BJ8 Front Single Lamps Austin Healey 35
steveg Switching multi-wire wideband O2 sensors between single gauge Austin Healey 11
K WTD Single SU Manifold for AH Sprite Spridgets 0
SherpaPilot TR6 Single Spark Plug is Burned Triumph 12
drooartz Single stage vs base/clear Spridgets 29
M TR2/3/3A Single brake light modifcation Triumph 2
W Single Minator wheel available Spridgets 3
N DCOE double vs. single choke theory Spridgets 11
Foura TR4/4A TR4A Exhaust - Twin or single? Triumph 8
Scott_Hower 1500 single rail gearbox rebuild? Triumph 7
T Wedge The Wedge Shop Single Turbo TR7V8 build Triumph 3
T building a single tower Sprite storage lift? Spridgets 21
J Bugeye single piece top frame same as two-piece? Spridgets 4
B Spitfire big bearing snap rings on Spit single rail Triumph 0
B Spitfire That Spitfire single rail gearbox again Triumph 2
N Convert BJ8 exhaust to single silencer Austin Healey 6
B Spitfire Aftermarket synchros 1500 Spit single rail Triumph 2
G Spitfire Anyome here running a single DCOE on a Spit? Triumph 0
G Spitfire Anyone have a single DCOE mainfold for a 1500 Spit Triumph 0
bigjones Single HS4 on a 1500 Spridgets 25
Stinger Stag TR4A Paint BRG #25 Single Stage or Base Coat Clear Triumph 13
L Two screw or single bolt side view mirrors? Austin Healey 8
dklawson Single HS4 Conversion Troubleshooting Triumph 6
C Single HS4 vs pair of HS2 on a 1275? Spridgets 21
T Triumph Spifire - single rail gearbox sychro Triumph 0
M Help with single SU on midget Spridgets 19
bighealeysource single 12 volt battery conversion on a 1954 BN1 Austin Healey 9
germanmichel Capillary tube of oil/temp.-gauge as single part ? Austin Healey 8
dklawson Spitfire Spitfire - Single-Rail Gearbox Frustration !!! Triumph 20
dklawson Spitfire Spitfire Gearbox Swap - 3-Rail to Single [Parts?] Triumph 2
J Electric choke-MG Midget 1978 Single Weber Spridgets 4
58Custom Anybody have schematic for single transistor tach? Spridgets 6
B single stage PPGpaint for Healey Austin Healey 15
beaulieu XK 120 Batteries - single 12v or pair of 6v ? Jaguar 7
T Single rail transmission Triumph 1
DART Huffaker "single hoop" MGB Racing 1
