Whay type of Polisher should I get?????
Newkie
I am going to be polishing my new paint job in a few weeks. Should I go with a <span style="font-weight: bold">7" angle</span> polisher, or go with a <span style="font-weight: bold">10"</span> <span style="font-weight: bold">orbital</span> polisher? Or maybe a different size if you think?
Harbor freight has a 7" angle for 29.99 at the moment and Walley World has the 10" Orbital for 23.99. It would be nice to have variable and the Orbital doesnt (3200rpm). The 7" only comes in two speeds. I think (2400, 3400). Also is their a good polishing compound that you like?
Thanks
Newkie
vping
Bronze
I just picked up some Turtle wax Rubbing compound and it is really taking out the dullness and bringing out the shine. I am doing it by hand to prevent buring at the sharp edges but at this rate I'll be done some time in 2010.
Anything by 3M. I have some 3M marine compound (designed for use on fiberglass boats) that works like magic on badly oxidized paint.
Then back up the polishing with some meguires hard carnuba wax.
Steve_S
The question is regarding polishing tools. The best tool for the job is a dual-action rotary. Orbital buffers are nearly useless. In fact I'll sell one in new condition for pennies on the dollar. I never use it.
Scott_Hower
The Porter Cable 7424 is a universal favorite with many DIY detailers. I think I paid about $120.
I've tried just about every polish and wax on the market.
My favorite machine polish is 3M Finesse-It on a medium foam pad. For swirl marks, I follow it with 3M Perfect-It. Then several coats of Zaino. Mmmmm :smile:
EDIT: looks like Coastal Tool has if for $99. Good deal.
https://www.coastaltool.com/cgi-bin/SoftCart.exe/a/port/7424_car_buffer.htm?E+coastest
mccalebr
ronzi
I have had of the random orbital buffers from Griot's Garage for about two years, and have been well satisfied with it. Relatively expensive at about $125. Whether it's worth that much is I suppose a matter of opinion, but I don't regret getting it.
The foam pads are definately the hot setup.
Meguiars has pads the same size, so you aren't necessarily restricted to buying replacements from Griot's.
PAUL161
This is a Meguiars car. I use nothing else!
Steve_S
No. Wet sanding is not necessary before polishing. Clay bar followed by a mild cutting compound will result in a beautiful finish. Wax is then applied to protect the shine.
vping
Bronze
What is this clay bar I always here people reffering to? Is something that Autozone might carry?
Steve_S
It's literally a bar of clay, specifically designed to clean impurities from paint. You lubricate the paint surface with quick detailer, then rub the clay around on the paint. The results are amazing if the car hasn't had it done in a long time. Run your hand across a section before and after clay and you will realize how bad your paint surface was before. Polishing after clay will give even better results. Meguiar's and Mother's both sell good clay kits.
BOXoROCKS
...Steve S,...he stated that it is a new paint job...I am assuming he wants the nicest finish he can get, unless it was put on by Michaelanglo, it probably needs wet/color sanding...with a hard pad to achieve a flat matte surface.Then worked up from there...no wax for many weeks, it has to solvent dry. Is there some info concerning his paint that I am unaware of??
Steve_S
If the paint job was completed in the paint shop then no more sanding should be necessary. Of course if it wasn't sanded properly then it may be necessary to sand it further, but sanding is not part of the normal detailing process. It doesn't take Michaelangelo to paint a car and make it smooth! Should be that way already, needing only a polish and wax.
PC
Newkie said:
I am going to be polishing my new paint job in a few weeks. Should I go with ...
The choice of tool depends on the job at hand.
What are you trying to accomplish? Do you need to buff out sanding scratch? Is the finish already smooth and relatively shiny and you just need to bring up the gloss? Is there any oversrpay? Is it single stage or clearcoated?
Newkie said:
...Harbor freight has a 7" angle for 29.99 at the moment and Walley World has the 10" Orbital ...
I don’t think a 10” orbital has any value at all. They’re too slow and too low powered to accomplish significant defect correction. They’re too large/awkward for simple application of wipe-on products on passenger cars.
For light to moderate correction and general maintenance I’d go with a 6” dual-action machine like Porter-Cable’s 7424 (a.k.a. 7336, 7335, Meguiar’s G100 or simply <span style="font-style: italic">the PC</span>), Meguiar’s G110, Sonus’ UDM, Griots polisher, etc.
Heavy correction takes a rotary buffer (<span style="font-style: italic">and practice</span>).
Newkie said:
... The 7" only comes in two speeds. I think (2400, 3400). ...
Both are too fast. You want to stay below about 2000 rpm for rotary buffing. Besides, you really, <span style="font-style: italic">really</span> want variable speed control.
Horrible Freight does sell variable speed rotary buffers.
Newkie said:
... is their a good polishing compound that you like?...
Chemicals are like wrenches, some jobs can be done with lots of different ones, but there’s usually one that you find you’ll like best for a given job.
For machine buffing new paint I’d lean towards Meguiar’s M86 So1o compound system. But it all depends on level of correction needed and how the paint responds.
vping said:
... I am doing it by hand to prevent buring at the sharp edges but at this rate I'll be done some time in 2010.
You can use painters’ tape to mask off edges, power buff the flat areas and go over the edges by hand.
here’s an earlier BCF thread: <span style="font-weight: bold"> Proper Use of the Clay Bar</span>
Autozone should have Mothers and Meguiar’s clay bar kits. Any body shop supplier should also have clay.
PC.
vping
Bronze
Does a clay bar kit help with Oxidized paint at all or does it only work with a car that has had regular washes and waxes over the years?
vping
Bronze
OK I just picked up the Mcguires Clay kit from Autozone for about $20. I kneaded the clay, sprayed down the car with the supplied spray and started rubbing. The clay kinda just glides across the surface. When I wipe it off with the towel, it looks like the same dull paint. What am I doing wrong?
Steve_S
Clay won't shine the paint, it will only clean it. The surface should feel very smooth after clay, compared to before. To get the shine back in the paint you will need to use polish and a power tool.
H MK2 lover, but... what about an E type? Jaguar 5
D TR2/3/3A layout for lap type seat belt Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
71TR6 TR6 Type-J Overdrive identification Triumph 4
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
Editor_Reid V-12 E-Type Body Number Location Jaguar 3
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
K TR2/3/3A The Amco chrome tube type grille ....... Triumph 9
T TR2/3/3A A type overdrive hard engagement Triumph 36
S TR2/3/3A Wedge type and Dzus type side- curtains Triumph 1
R TR6 J-Type overdrive will not disengage when warm Triumph 8
6 E-Type brake light pressure switch location Jaguar 5
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
M General Tech J Type OD Stuck in OD - Fixed Triumph 2
ROARRR Is there any problem swopping in a 3.0 in place of the 2.5 L engine in my Jag X Type? Jaguar 0
M General TR Source for J Type O/D Solenoid Circlip Triumph 0
M Wanted Wanted: Inoperative J Type OD Solenoid! Triumph Classifieds 2
V vintage glue type for veneer? Sunbeam (Rootes) 13
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
Basil Remember the Royal Electric E-Type Electric Upgrades of All Sizes 0
S TR2/3/3A lifter type Triumph 3
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
M TR6 1973 TR6 Coolant Type? Triumph 5
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
S TR2/3/3A 187 NOS sleeved type thermostat Triumph 16
Basil The new Kia E-Type? Jaguar 6
H TR4/4A A-type overdrive pump Triumph 4
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
P Wanted E type spare tire bracket Jaguar Classifieds 2
P Wanted 62 E Type spare tire bracket Other British Classifieds 1
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
Got_All_4 TR5/TR250 Trying to figure out rear transmission mount with a J type tranny Triumph 9
I GT6 A type OD vs D type - engagement speed? Triumph 3
J For Sale Jaguar E Type and MK2 spares Jaguar Classifieds 0
VooDooDaddy63 Basic E-Type Question: Fasteners - Metric or SAE or ...? Jaguar 15
D TR2/3/3A Type A overdrive not engaging Triumph 0
D TR2/3/3A Type A overdrive not engaging Triumph 16
S For Sale Lotus Elan Factory Workshop Manual on CD/ROM - Type 26 - 1963 - 1965 Other British Classifieds 1
B Resistor type vs non-resistor type spark plugs for 100-6 Austin Healey 17
K TR4/4A TR4 Fuel Gauge'"light bulb socket" type? Triumph 11
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
AH67 Heat Shield finish 66 Type Jaguar 5
AUSMHLY Grease type for zerk fittings Austin Healey 7
M TR4/4A A type Overdrive Oil Leak Fix Triumph 3
M 5-speed, 1968, 4.2, E-Type, OTS Jaguar 3
