Stewart
Run into a weird problem today. Finally got the 73 close to being dialed in (rear throttle return spring broke so I cant sync the carbs) and now that its running like a sports car should now when I rev the engine up in gear to 5k indicated the red ignition light comes on. Shift and it goes out however it did not come on while at that rpm in 4th (Dont ask how I know)I'm pretty sure the tach may be off as it's been funky since I got the car but would the ign light glow for an over volt or just undervolt condition? At idle its putting out a healthy 14.4.
The other gremlin I've run into is with the head lights the left one in particular. It hasn't burned out but it just glows weakly and the high beam indicator is dimly glowing. High beam is also weak. Right side is fine. Any ideas
