Pin for lock cover on outside door handle
pmenhusen
I need to attach the lock cover to my door handle, but don't know what kind of fastener to use. The guy at the parts store was stumped, but thought it probably uses some kind of skinny spring clip. I tried a cotter pin, but there's no access to the back side of the hole. Please let me know who sells these.
DougR
A spiral pin (or roll pin) is most likely the method of attachment. As it springs open after installation, it serves as a "blind" fastener. A good auto parts store should have these.
MikeP
Actually, the lock covers are retained by sprial springs. At one end the wire points into the center and the other end it points out. These springs are handed and can't be replaced without removing the outer handle from the door. The most common reason for them to come off is if the pin on the cover breaks. Look at the end of the pin, it should have a slot with a small offset cut at the bottom in the top 1/8 inch or so of it.
P
pmenhusen
Yes, my part is as you describe. When I go to the parts store to buy a replacement pin, I get the famous blank look. I have a Series V parts car that I can salvage the complete door handle from (do you know if it inter-changes?). Otherwise, do you know of a supplier that might have such a pin? I've checked in three different Sunbeam parts catalogs and can't find it.
MikeP
Well, no one that I've ever seen reproduces them.
But, you can exchange door handles across the range. If you haven't already taken it apart there is a panhead screw under the weatherstrip at the back of the door that retains one end and a 5/16 nut on a stud inside the door to retain the other end. Once these are off the handle comes loose. To keep your original lock to match the key look at the back of the handle, the lock and push button are retained by a plate held in by two or three screws. Remove these and they drop right out. Put you originals in, I suggest you use the original push as well to keep from needing to play adjustment games, and screw the retaining plate back down. Install on the door.
BTY, make sure the door window is up before removing the window crank handle and inside panel, you can't reach the nut at the front of it's down.
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
Racer-X- Metalastik Lower wishbone bushings and upper fulcrum pin bushings Other British Cars 6
D Clutch Fork Pin Removal Austin Healey 4
KVH General Tech Tensioner Pin Triumph 15
KVH General Tech Removing Piston Wrist Pin Triumph 2
P Wishbone Pin Bushes Austin Healey 5
Hangtown Healey King Pin Bushings Grease Groove Austin Healey 8
S Removing Overdrive Shaft Lever Pin Austin Healey 7
W Frozen fulcrum pin Spridgets 7
T Wedge TR7 4 speed wheel cylinders on 5 speed (locating pin) Triumph 0
K Gearbox Throw-out pin and gasket question Austin Healey 8
Lin Bonnet Striker Pin Assembly Austin Healey 5
Jim_Gruber In need of 2 Fulcrum Pin Bolts - MOSS Has them on Back Order Spridgets 3
AUSMHLY Distributor cap center pin melted Austin Healey 5
T TR2/3/3A 30a 5 pin universal relay Triumph 12
C Wishbone arms cotter pin removal Austin Healey 5
R TR2/3/3A Pin Hole in gas tank Triumph 9
K TR2/3/3A Dismantling Speedometer...getting the odometer pin past the case??? Triumph 2
Raymond MGB Wire Wheel Cotter Pin MG 5
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
S TR4/4A Handbrake cable rubber boot at clevis pin end Triumph 1
KVH General Tech Clutch Fork and Broken Pin Triumph 8
Got_All_4 TR2/3/3A anti rattle pin Triumph 6
D TR4/4A shifter anti rattle pin Triumph 2
histerical Moss king pin reamer Spridgets 13
D TR4/4A broken trans fork pin Triumph 14
B TR5/TR250 Sheared fulcrum pin TR6 Reverse lever Triumph 1
B Kin Pin Kit - O-rings Austin Healey 1
S M Series Bonnet Striker Pin failures TVR 4
M MGA MGA Swivel Pin Replacement MG 7
R Not just another throw out bearing pin question Austin Healey 3
Lukens TR2/3/3A Clutch fork pin. Triumph 9
K TR2/3/3A Rear spring again....front pin "D" washer? Triumph 7
MY66AH King Pin Replacement Spridgets 14
M_Pied_Lourd TR2/3/3A Fulcrum Pin Triumph 4
K TR2/3/3A Leaf Spring height and front spring pin removal again? Triumph 1
T TR2/3/3A How many guide holes in TR3 flywheel for crank pin? Triumph 2
BN6_2197 Removing the Swivel Pin of BN6 Austin Healey 5
catfood Top trunnion pin removal. Austin Healey 4
K TR2/3/3A Distibutor drive dog pin removal? Triumph 8
S King Pin Bushings Austin Healey 1
dcoplan I've got a twisted camshaft-to-oil pump pin. How to fix?? Spridgets 1
T TR2/3/3A Rear spring front pin removal Triumph 28
J Rear spring front pin stuck Austin Healey 8
R King Pin kit Austin Healey 4
BN6_2197 Rmoving the King Pin [continued] Austin Healey 18
J TR2/3/3A Timing chain pin Triumph 1
BN6_2197 Removing king pin from stub axle of BN6 Austin Healey 11
AUSMHLY HD8 pin & spring assembly Austin Healey 6
K TR2/3/3A Trunnion spindle cotter pin hole non existent! Triumph 9
