Test Drive
Steve
Platinum
Catherine and I test drove a new Mini Cooper 'S' yesterday. What a great little car! Not able to take it on any twisty bits, not many of those around here, but it was fun to drive, and Catherine, whos car it will be, was most impressed, and is talking of one in red with white roof. Yes!!!!!!!!!!!!!!
T TR2/3/3A 4th Test drive Triumph 12
RickB 1980 MGB on test drive suddenly loses electrics and dies - what to look at? Spridgets 46
A test drive and oil pressure Triumph 8
drooartz Progress: test drive! Spridgets 11
sail Test Drive I Don't Wanna Mess it Up Triumph 4
6 test drive after 2 years Triumph 4
RickB 1.5 M test drive really had me laughing out loud!! Spridgets 14
LastDeadLast Finally!! Test drive HVDA 5-speed install. Triumph 13
zimmy yesterdays drive test results Spridgets 0
Bret Zed 4 test drive! Other Cars 5
jlaird Test drive Spridgets 7
Baz Test drive.....problems......what now? Spridgets 5
B short test drive? Triumph 6
A XK150 FHC Test Drive Jaguar 1
B Hot Drive Test--Results Austin Healey 2
petnatcar Compression Test Record Form Austin Healey 0
kodpkd Compression Test Results Austin Healey 1
M Overdrive Pressure Test Austin Healey 2
RJS General TR Oil Pressure Gauge - Test Triumph 11
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
PAUL161 T-Series 5 Speed Road Test MG 25
Rob Glasgow First Test Austin Healey 6
K TR2/3/3A Test Triumph 0
glemon Test FORUM Navigation Questions 4
AUSMHLY HD8 drop test time in seconds Austin Healey 3
AUSMHLY Compression test results Austin Healey 17
HealeyPassion EFI AH Initial Test Day... Austin Healey 6
Michael Oritt Every ride is a test ride Austin Healey 9
roscoe Leakdown test [long read] Austin Healey 11
Y Passing the smog test MG 17
KVH General TR Overdrive Pressure Test Triumph 17
Jeepster BJ8 Servo/ brake booster test Austin Healey 1
D Test image post FORUM Navigation Questions 1
D Lilly test runs Austin Healey 4
F TR2/3/3A Compression Test Triumph 13
M Carb emission test Austin Healey 5
RJS General TR Head Gasket Test Fit Triumph 5
Tinkerman TR2/3/3A SU H6 Rebuild Bench Test Triumph 3
KVH General Tech Leak Down Test Triumph 17
T TR2/3/3A How do I test overdrive relay diode jumper? Triumph 2
T TR2/3/3A SU Piston Drop Test Triumph 4
Steve1970 TR6 Carb air piston test, still results in stall even when adjusted rich Triumph 11
toysrrus TR2/3/3A How to test fuel gauge & sending unit? Triumph 10
S TR4/4A How to test Overdrive out of the car Triumph 45
P TR6 Latest compression test Triumph 11
gbtr6 TR6 Test starter system with engine out? Triumph 16
NutmegCT Memory test Other Cars 9
J TR6 Test 75 TR6 Hazard Switch? Triumph 12
S TR2/3/3A Test an overdrive trans. Triumph 6
T TR6 TR6 compression test Triumph 12
