Diff change instructions...
VelodromeRacer
I am pretty good with these cars...but this is something I have not ever done...
I am in need of some step by step instructions to changing the rear diff. I have changed the rear axels on the Bugeye to Winner's Circle and the double hubs...
Thanks,
Velo
ChrisS
Drain the oil out the plug on the bottom of the banjo.
Remove wheels, drums and axles as you did when you changed to the WC axles.
Remove the (4) bolts holding the drive shaft to the differentail.
Remove the bolt holding the Tee for the hard lines and flex line from the differential (some don't get rebolted over the years so this may not apply).
remove the (8) nuts securing the differential to the banjo.
Rock the differential to break the sealant, you may need a rubber mallet to help it along.
Clean the mating surface and install a new gasket (I don't use a gasket, just permatex #2 sealant - YMMV).
Install the new differential in the reverse order, reinstall axles and fill with gear oil. I don't top off the rear end fluid, I put in just enough so I can touch the level with mu pinky.
It isn't a bad job at all, just keep everything clean.
pbraun
Any difference if you're changing the diff from a 4.2 to a 3.9?
Michael Oritt
After step 6 of Chris's instructions I would add:
After removing the center section spray carb cleaner or the like into the axle tube from both ends and into the center housing, then pass a magnet around the drain hole to remove any metal bits.
Marvin Gruber T-Series TD diff change & wire wheels MG 9
RJS Fluid Change Interval - Trans and Diff? Triumph 8
K TR2/3/3A Tr3: Change in Diff=Change in Speedo reading? Triumph 7
Shinsen774 Rear Diff Gear Oil Change Interval MG 2
A Spitfire How to change diff oil on 78 Spit? Triumph 1
S Wanted WTB: 3.5 ratio diff/pumkin for '67 BJ8 Healey 3000 Austin Healey Classifieds 0
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
Darwin GT6 Diff Help Please Triumph 2
skystryd Trans and Diff Spridgets 7
M TR4/4A Diff comparisons Triumph 2
N TR6 Triumph Diff which model??? Triumph 1
pbraun Wanted 3.9 diff for sprite Spridgets Classified 5
steve00136 MGB Diff refurbish MG 6
Tr3aguy TR2/3/3A Been a while Diff question? Triumph 4
D For Sale Detroit Locker Diff, Servo and Springs BN4 100/6 Austin Healey Classifieds 0
M TR4/4A Diff Conversion Triumph 3
T Diff Ratio BJ7 Austin Healey 5
Zitch TR4/4A Diff Fluid - GL4 Triumph 7
Sarastro General TR How is the axle tube attached to the diff housing? Triumph 16
K TR2/3/3A 3.45 Diff ratio? Triumph 7
B best diff British Motor Corp 5
wangdango '67 XKE rear diff? Jaguar 2
Jim_Gruber Bugsy IV decided to leaked out almost a quart of diff fluid Spridgets 6
B diff ratio British Motor Corp 3
B TR6 Should the poly diff mounts be snug to the studs? Triumph 2
Jim_Gruber Speedi Sleeve Install and New Diff Gasket Spridgets 5
69MGC MGC Diff Oil MG 1
69MGC MGC Rear Diff Cover Bolts Torque? MG 5
drooartz Diff pinion nut Spridgets 10
K TR4/4A Stromberg..."coupler" that links vacuum outlet to diff vacuum line is N/A? Triumph 3
R TR2/3/3A Lockheed diff setup Triumph 6
Boink 3.9 diff and pinion seal Spridgets 2
Boink 5 speed vs. 3.9 diff - either or both? Spridgets 165
Michael Oritt 3.54 diff for sale Austin Healey 1
drooartz Diff pinion seal Spridgets 8
Rut Diff plug tool Spridgets 7
Geo Hahn General TR Diff Pinion Seal Triumph 5
Geo Hahn TR2/3/3A Paint Dab on Diff Cover Triumph 6
A TR4/4A Changing rear diff seals Triumph 15
K TR2/3/3A Lockheed Diff...why is it considered 'weak"... Triumph 3
Gordon_Dedrick TR2/3/3A Drippy Rear diff cover Triumph 6
JFS Wedge Diff Cover Gasket Adhesive Triumph 10
G Diff and trans oil Spridgets 8
C TR4/4A Diff gear wear Triumph 10
mgedit TR2/3/3A Lockheed Diff Oil Seal Replacement Triumph 10
K TR2/3/3A 4:1 Diff in a TR3? Triumph 3
steveg Limited Slip GM Healey Diff Austin Healey 4
DerekJ 11:39 Diff for sale. Austin Healey 0
H Noisy diff in BJ7 Austin Healey 2
K TR2/3/3A TR3 4:11 gears in rear Diff Triumph 6
