TR2/3/3A TR-3 SCUTTLE VENT ROD INSTALLATION?
Bob_Burt
While removing my '58 TR-3A dash rail for recovering, I inadvertenty pulled the vent rod all the way out (knob + rod). Anyone have any idea on how to reattach the wire to the vent control arm?
Thanks, Bob Burt
Geo Hahn
The wire is attached with a set screw -- sort of down low on the articulated arm.
You may have to undo the hinge pin on the arm and slip out the 2 springs to get the flap open far enough to work down there.
It's been several years since I had mine all apart so I do not remember for sure the assembly order but I think that wire would be the first thing you would hook up, then everything else.
B
Bob_Burt
That's good news. I had visions of removing a panel below the dash (including the heater) to get at it. I'll try it.
Thanks, Bob
MGTF1250Dave
Aloha Bob,
As Geo said the rod is secured with a set screw. Saying it is the easy part. Open the scuttle vent with your fingers if it isn't open already. There is a flat bar link that is attached to the scuttle (this end may be riveted) and the opening mechanism at the other end with a machine screw and nut. I find that if I disconnect this bar I can open the vent much wider and get better access to where the rod connects. The pull/push rod is insert through a a hole through a brass cylinder that goes across the bottom of the opening mechanism. There are additional piece added to mechanism to create a "Y" wide enough for the rod to pass between the legs of the "Y". The brass cylinder has a set screw at one end to clamp the rod to it and rod between the "Y" keeps the cylinder from falling out of the hole. The opening mechanism rotates around the brass cylinder as you open and close the scuttle. An off set screw driver and a small wrench are the tools needed, but a good flash light and a helper to fiddle with the knob would be helpful.
Deleted member 451
If you know any 3 year olds with small hands and good 'small motor skills' (My wife the kindergarten teacher taught me that term), that would sure help. I've had to reconnect that rod a couple of times. When you get it back together add some locktite or something to keep it from coming loose again.
B
Bob_Burt
Thank you all for the help. Dave, you were right on with your description. It took me about 2 hours(by myself) to figure out all the geometry and get the rod attached. I ended up:
1. Removing the spring (only one on my '58).
2. Unscrewing the vent hinge plates to get enough access.
3. Pulling the whole mechanism out to see how it worked.
4. Removing and cleaning up the cylinder.
5. Loosly reattached the hinge plates.
6. Feeding the rod back in, tighing everything up and reinstalling the spring.
The hardest part was to get the hole in the cylinder aligned with the rod. Look, try, turn it a little, try again, etc. GREAT PLEASURE when it went in!
The recovered dash rail (I used black everflex) is on and what an improvement! And the scuttle vent opens and closes!
gsalt57tr3
Couple months ago my 1 year old Moss Motors pull rod disintegrated, with me holding the knob and one part of the rod in one hand and the car holding the remainder of the rod neatly hidden away within the scuttle.
Not a high priority issue, so I wasn't too concerned. But the part came in the other day.
This thread was very fortuitous. (Yes, my son is studying for the SAT, how did you know?)
MGTF1250Dave
Depending upon were the knob separated from the rod, you may be able get it to reappear by opening the vent by lifting up on it. I've used super glue to reattach the knob to the rod in the past.
Crankshaft
Re-opening this thread to see if anyone may have a photo or part number of the "brass cylinder" needed to attach the rod.
Is the part even available or is it something I will need to try to make myself?
M_Pied_Lourd
Here is a photo of the mechanism ...
The part kind of reminds me of the stop that is on my TR6 hood opening cable....
https://trf.zeni.net/TR6-TR250GB/327.php
RFK 836
Cheers
Tush
Crankshaft
Thanks Tush. Does it seem to you that the size & configuration can be made to work ok?
2liter4cyl
Bronze
Let me try to describe the drawing I made: A 1/4" dia. X 5/16" long brass rod. With a # 36 drill, drill the length of the rod and tap with a 6-32 NF tap. Next , drill a 1/8" hole cross-wise in the center. Your rod goes thru the 1/8" hole and you need a 6-32X1/4 HEX HEAD screw to grip the rod. Hex head is a lot easier to tighten than a slot and screw driver arrangement. on the other end of the tapped hole put another short screw, good only as a means of keeping the bugger installed on the fork. Any help? Le
Crankshaft
Much help, thanks. I have several feet of 1/4 in. Brass rod from an old curtain rod that will give me plenty of
material to ruin several, as is my custom.
Thanks again LE & Tush
NutmegCT TR2/3/3A scuttle vent actuator rod - TR3A Triumph 3
B For Sale BaulyCars - Scuttle Vent Cover Triumph Classifieds 0
C TR2/3/3A scuttle vent Triumph 6
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
N TR2/3/3A TR3 Scuttle Vent Triumph 15
N TR3 scuttle vent FORUM Navigation Questions 1
D TR2/3/3A TR3 Scuttle Vent knob removal? Triumph 2
AHS TR2/3/3A Can someone please measure the scuttle vent door link length? Triumph 2
PatGalvin Scuttle Vent Rubber placement Triumph 4
M Sebring Scuttle Vent Austin Healey 3
luke44 TR2/3/3A TR3 Scuttle Vent Assembly Triumph 4
H TR2/3/3A TR3A-Scuttle Vent Ass,y - Parts Missing Triumph 3
luke44 TR2/3/3A TR3 Scuttle Vent Disassembly Problem Triumph 6
C scuttle vent linkage Triumph 4
H TR2/3/3A TR3 Scuttle Vent Questions Triumph 3
S TR6 76 TR6 Scuttle Vent Triumph 16
G Scuttle Vent Adjustment Triumph 1
Tinkerman TR2/3/3A Scuttle Vent Installation TR3A Triumph 4
TonyPanchot TR5/TR250 tr 4/ 250 scuttle vent gasket Triumph 7
71tr Scuttle Vent Removal Triumph 7
P TR2/3/3A TR-3a scuttle vent assembly question Triumph 2
T TR4/4A 4A Scuttle Vent Seal-Gasket Triumph 6
R TR6 TR6 scuttle vent style Triumph 10
G Scuttle vent conversion Triumph 1
harmsc Scuttle Vent Triumph 6
mctriumph For Sale Tr2/3 scuttle mechanism Triumph Classifieds 7
71TR6 TR2/3/3A TR3A Scuttle Rim Question Triumph 4
F TR2/3/3A starting scuttle repair Triumph 27
J TR2/3/3A Wooden piece under scuttle with dash Triumph 6
steveg Steering column steady brace and scuttle shake? Austin Healey 2
D TR2/3/3A Scuttle uneven on one side Triumph 12
Darwin Spitfire scuttle vents Triumph 0
M Scuttle shake. Austin Healey 16
D Scuttle shake and tyre pressures Austin Healey 2
R More Shroud to Scuttle install Austin Healey 4
L TR2/3/3A Scuttle / front fender attachment Triumph 9
C TR6 Scuttle lid spring? Triumph 6
P TR2/3/3A TR3A Scuttle/Windscreen Stanchion questions Triumph 12
B Scuttle shake finally sorted Austin Healey 23
PAUL161 T-Series Scuttle Shake/Vibration MG 6
B How do wipers mount to scuttle top on a 100-6? Austin Healey 16
J Door/scuttle rubber seals Austin Healey 2
S Scuttle Liner/ Footwell Cards Austin Healey 10
S Scuttle Shake Austin Healey 95
H clear coat question on scuttle Austin Healey 7
5 The scuttle shake mod- I can't decide Austin Healey 7
steveg Scuttle Seal installation article Austin Healey 2
O TR2/3/3A TR3 Windshield to Scuttle Mounting Triumph 1
D whats causing my SCUTTLE SHAKE !!!! Austin Healey 39
H Scuttle Seals Austin Healey 2
