Engine is finally back from the rebuild
MoPho
finally came back from the rebuild (took 8 months) on Saturday. It was dyno'd and put out 171hp 150 lb/ft torque! should be sufficiently scary in a 1400lb car /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
Now to put it back in the car and do all the other little stuff that was planned. Hopefully it won't take as long.
Doc, you must have got their ears ringing because I got the call the very next day after our shed discussion /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
Deleted member 3577
Oooh......Hope you have a nice new set of stickies /bcforum/images/%%GRAEMLIN_URL%%/driving.gif /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
MoPho
MoPho
That's next, but having trouble finding tires that fit
Platinum
Glad to learn it's back home! Now you're "traction limited" fer sure. /bcforum/images/%%GRAEMLIN_URL%%/wink.gif YEEHAW!
Diff output shafts the "bigger" ones? IIRC you didn't have plans to flare the wheel arches. That means some tire searching. I thought Sumitomo had a 145 or 155/70 which would *just* fit in those wheel wells. Gotta be extra careful as it'll chew up outer front arches on full lock and a bump... guess how I know that. /bcforum/images/%%GRAEMLIN_URL%%/frown.gif
MoPho
MoPho
Oh, I have plans for some kind of flared wheel arches (26r style) just don't have the money.
Already have the proper output shafts and everything.
Already have 165/65's that fit fine, looking to go to a 175. Sumitomo makes a 175/50 that may fit, but not sure.
Deleted member 3577
I ran a set of those once...Not bad except the sidewall flex was ridiculous.
(And my car is about the same weight as yours)
If ya get them....Try 36 in the front and 38 PSI in the rear.
Running vintage Hoosiers now.....Much better!
Platinum
175/50 on a 4.5" rim may be pushin' it a bit. At least YOU'RE runnun' point. /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif I'll know what NOT to try when the time comes. /bcforum/images/%%GRAEMLIN_URL%%/jester.gif
Deleted member 3577
Shave em puppies & it will help a bit....
Otherwise you'll look like a frightened kitten on a hardwood floor. /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
Platinum
Nice mental image, Dave. /bcforum/images/%%GRAEMLIN_URL%%/shocked.gif
5.5" mebbe. +2 rims are that wide.
MoPho
MoPho
I was hoping to get the Yokohama A032 but apparently they don't make them in 13" anymore /bcforum/images/%%GRAEMLIN_URL%%/frown.gif
Platinum
yeah, our 'choices' are getting ever more restricted. Some of the makers will hopefully notice and start a 'niche' line of rubber.
Deleted member 3577
Check out the section width on the 185/60ZR13 Toyo Proxy RA1s here...
https://www.sascosports.com/products/index.php
My recommendation....If they fit.
Or you could use Formula Ford slicks.
Probably one of my most interesting experiences in the rain. /bcforum/images/%%GRAEMLIN_URL%%/jester.gif
(Driving a 'hair-trigger' car on 6" wide slicks)
BTW...The Sumitomo 175s bolt up great on 5" rims
MoPho
MoPho
Would love those, but I am pretty sure 185's will not fit without flares.
I may try the sumitomo, they are only $44 each so if they suck, it's not that big a deal. Shaving them would probably be good.
36/38 seems a lot of pressure though, I only run 25psi in my tires now
MoPho
MoPho
It exists! /bcforum/images/%%GRAEMLIN_URL%%/banana.gif
Platinum
That's lookin' mighty proper, Morgan! /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
When's it get slotted in?
MoPho
MoPho
Should be going in today and then over the next couple of weekends will get the ancillaries, some rewiring, etc.. I am hoping it is back on the road in time for Steve's Labor day drive
Nunyas
I look forward to seeing it there!
171HP in yer Elan ought to give Steve and his 'C' a run for his money in the twisties /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
G
Glad to hear it's back. 'bout time!
Now we want to hear how well it runs...
MoPho
MoPho
Unfortunately, there is a new setback. Upon investigating a sticky spot in my steering rack, it was discovered that it needs replacing or a rebuild. More time and money, ugh /bcforum/images/%%GRAEMLIN_URL%%/frown.gif
AngliaGT MGB FINALLY Got the Engine Out MG 5
Marvin Gruber Three rebuilt BJ8 engine- FINALLY! Austin Healey 17
PATR8 Finally rebuilding the 8 engine Triumph 4
T Finally got the engine out Triumph 18
TR6oldtimer Engine Compartment finally painted. Triumph 22
C My Engine [finally!] arrived! Lotus 6
JPSmit Finally - an engine Spridgets 13
B Finally - Engine and transmission installed Spridgets 22
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
R TR6 question re: Engine Oil Triumph 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
