Engine rebuild books
John Loftus
Figured this would be the best forum to ask...
Anyone have experience with rebuilding motors and can suggest good reference books? I found the following book at Amazon which sounds good:
The Step-By-Step Guide to Engine Blueprinting: Practical Methods for Racing and Rebuilding by Rick Voegelin
John (Austin Healey - BJ7)
Scott Brunkhurst
John,
I take it you have a good copy of the factory manual. But if not, you need to get one. I have a Chiltons manual for MG's which has an engine and engine rebuilding section. I found it very useful. Maybe they have one for Healeys. This not to say that the book you found is not an excellent reference source. But you might want to add something British to your library.
SB
John Loftus
John Loftus
Hi Scott,
I have the Factory workshop manual and a Haynes manual. Both have an engine rebuilding section .. priceless for the specific Healey motor info but I'm looking for more theory, detail and hand holding to do this job right. Can't have too many books, eh
John
John Turney
John,
You might want to spend some time at a large book shop (Barnes & Noble comes to mind) and look though their books. I'm not familiar with the one you mentioned (The Step-By-Step Guide to Engine Blueprinting: Practical Methods for Racing and Rebuilding by Rick Voegelin), but they are usually how to work on a Chevy V-8. You'll learn more by talking to a good machine shop and reading your Haynes manual. For getting more power out of your Healey, the following are recommended:
- Going to vintage races and talking with a Healey racer.
- There is a book "Vintage Racing British Sports Cars" that's out of print, but can be found on in the out-of-print sections of the major web booksellers. This will give you some ideas.
- Check with some of the Healey racers on the web: Team Healey Texas, Cape International (UK) and Denis Welch (UK). Most of my engine mods are as a result of talking with Denis Welch. Denis supplied major parts to the fastest of the Austin-engined Healeys at Tahoe. We couldn't top the Nasty Boys, but I'ld rather sound like a Healey.
John
piman
Hello John,
Blueprinting, whilst being very interesting, is much more than you will need for a general engine rebuild. It involves a lot of time in measuring and weighing all the components then machining to make everything as identical as posible and ensure that all the tolerances are as fine as possible. Expensive and poor value for money except for serious racers.
Have you thought of looking for a text book as used by automotive technicians?
Another thought, find a scrap engine and take it to bits then re-assemble to familiarise yourself with how things work, and where you find certain operations difficult.
Alec
John Loftus
John Loftus
Thanks for all the suggestions. I did order the blueprint book along with another general overhaul guide. My intention is to rebuild with motor with an eye towards performance but don't want to hinder normal street driving. The motor already has a roller rocker arm assembly and tubular header exhaust. The BJ8 cam profile, lighter flywheel and BJ8 carbs should add some more Hp and quicker response.
John Turney, what mod's have you made?
John
BJ7
KVH General Tech More Engine Rebuild Questions Triumph 15
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
J Engine rebuild Austin Healey 4
classicmechanic Amazon engine rebuild pics Other Cars 6
M 948 Engine Rebuild Question Spridgets 0
M engine stutter of rebuild BT7 engine [tri-carb] above 2500 rpm Austin Healey 27
60TR3A Cost to Rebuild a Healey 3000 Engine [And Recommendations About Who to Do It] Austin Healey 14
M E Type 4.2 engine rebuild Jaguar 4
Got_All_4 TR6 TR6 engine rebuild. Too tight? Triumph 23
Healey Nut Engine rebuild Austin Healey 17
Got_All_4 TR6 What engine bearings to use in my rebuild? Triumph 9
R BT7 engine gallery plug replacement during rebuild Austin Healey 3
RAC68 What's with all the Engine Rebuild Failures? Austin Healey 42
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
G Failure on Initial Engine Start After Rebuild Austin Healey 176
HighAltitudeTR3 TR2/3/3A Any feedback on this? Rimmer Bros engine rebuild Triumph 6
KVH General Tech Engine Rebuild: Failed at Cam Break-in Triumph 11
simon1966 A few shots from the 100 engine rebuild Austin Healey 18
JimLaney Engine rebuild - how critical is rust? Spridgets 3
G TR4/4A A couple of engine rebuild questions... Triumph 8
N Engine rebuild ??? Spridgets 4
Csarneson BN4 Engine Rebuild Questions Austin Healey 8
Csarneson Engine Rebuild Disaster - Cylinder Crack Austin Healey 20
D Engine rebuild questions. Austin Healey 18
M Need Advice On 948 Engine Rebuild Spridgets 7
W TR2/3/3A Novice TR3 Engine Rebuild Triumph 47
W TR2/3/3A Engine rebuild - looking for preliminary advice Triumph 7
T TR4/4A What is trickiest part of engine rebuild? Triumph 15
D MGB 1963 MGB engine rebuild MG 4
H Off Topic Nifty Time-Lapse Video of Spitfire Engine Rebuild Triumph 2
gbtr6 TR6 Engine Rebuild kit Triumph 12
gbtr6 TR6 TR 6 Engine rebuild/freshen Triumph 21
Rut TR4/4A Performance engine rebuild Triumph 3
me61ic Timelapse '63 BJ7 engine rebuild Austin Healey 5
Rut MGB Engine rebuild, then... MG 29
mcmillal TR4/4A Engine / Transmission Rebuild Triumph 1
JPSmit Engine Rebuild question Restoration & Tools 10
S TR2/3/3A Engine rebuild Triumph 9
TexasSprite Engine Rebuild Video Spridgets 1
Healey Nut Engine rebuild Austin Healey 9
mt10flyer TR2/3/3A 1959 TR3 engine rebuild problems Triumph 14
PatGalvin The fun just won't stop [engine rebuild questions] Triumph 53
Tim Tucker TR4/4A TR4 Engine rebuild Triumph 4
J TR4/4A Engine rebuild on a TR4 Triumph 19
MGTF1250Dave XPAG Engine Rebuild MG 0
B Engine Rebuild MG 1
Johnny Spitfire How to rebuild a Spitfire 4 cyl engine in 45 sec. Triumph 2
Sarastro Here's the REAL way to rebuild a Triumph engine! Triumph 1
luke44 Spitfire Spitfire Engine Rebuild- Great Video Triumph 2
