brake light
dwnuk
Need help. Have a 1958 MGA 1500 and while driving my brake lights remain on. After turning off ignition than turning on again the brake lights remain on without stepping on the brake. However the next day the brake lights work fine until after I drive and use the brakes. They once again remain on.
Thanks for any help
R
RonMacPherson
Okay, your problem is consistent with a failure in the brake light circuit, i.e. the switch.
Now I don't know which type your car uses, so I'll offer a generic troubleshooting for both the mechanical(on the pedal stop) and hydraulic.
First you need to id which type you have. Maybe a parts book or a friend, or just looking under the dash at your brake pedal.
If it's the mechanical type, they are usually mounted at the brake pedal stop, a bracket that the pedal rests up close to when the pedal is not depressed. You should see a small cylinder with a couple of wires on it. One is battery voltage and the other goes out to the brake lights.
If so, push in and out on the pedal a few times and see if the switch is being shut off completely, usually a small button inside threaded portion of the switch. A lot of times the switch can be adjusted by loosening the locking nut and turning the switch in(to shut off sooner) or out for desired pedal shut off(make sure you unhook the wires while turning the switch, then reinstall them).
If not this type, then out in the hydraulic circuits by the master cylinder(follow the piping from the master cylinder) you will find a little stubby switch with two electrical connectors on it. This is the hydraulic brake light switch. No adjustment, just replace.
Way to determine, is get a voltmeter or test light. Test the wires going to the switch(either type). One wire should have battery voltage to it whenever the fuse is energized(some cars you have to turn the key on, others it's on all the time). Then test the other wire, should be no light, or voltage, UNTIL you press on the brake pedal, then it should light up. Way to temporarily stop battery draw,if the light is staying on, is to unhook the output terminal of the switch. Sometimes easy to get too.
HTH
David_DuBois
The MGA uses a hydraulic brake light switch so the first thing I would look for is residual pressure in the brake lines. When you get the constant on brake lights the next time you are out, try cracking the bleader screw just a bit on all four corners and see if this turns the brake light out. If it does, then you need to start looking for the cause of the residual pressure on the brake lines. Start with the brake pedal - check that it is returning all the way up when released (is the pedal return spring still in place and not broken?). I don't know if the MGA has an adjustable actuating rod, but if it does (and even if it doesn't) check that the master cylinder piston is being allowed to return far enough to uncover the relief hole in the master cylinder.
If residual pressure is not the problem, then a new brake light switch is probably in order. Unless you get the switch from Ron Francis Wiring https://www.ronfrancis.com/showpage.php?page=main.htm the replacement switch (which is available from NAPA, Moss or Victoria British - all equally bad) will not last more than a couple of months unless you install a relay/arc suppression circuit athe same time you install the new switch. For information of making and installing the relay/arc suppression circuit, see my article, Installing a Brake Light Relay at: https://www.mgexperience.net/article/brake-light-relay.html
Cheers,
Platinum
and if residual pressure IS there, replace all three flex lines FIRST!
My money's on the flex lines. /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
ronzet
dwnuk,
Just to offer a suggestion...
Before you start the messy stuff, remove one of the two wires on the sensor, located on the right side frame adjacent to the starter.
Use your OHMS meter and check to see if the two posts are electrically shorted without pressure on the brake pedal.
If open, then ask someone to press on the pedal and see if the circuit changes state, that is goes from open to closed... do this several times to check for consistency. These pressure sensors are pretty bullet-proof but do get flaky once in a while...
Replacing one of these sensors is a quick and easy repair... /bcforum/images/%%GRAEMLIN_URL%%/smirk.gif
Just a less messy test before you start the hydraulic manipulations... /bcforum/images/%%GRAEMLIN_URL%%/cheers.gif
Platinum
I'll narrow my bet since there wasn't a mention of "pulling" left or right and say: My money's on the ~rear~ flex line. /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
...it'll turn out to be th' bloody master cylinder... /bcforum/images/%%GRAEMLIN_URL%%/smirk.gif
David_DuBois
"These pressure sensors are pretty bullet-proof but do get flaky once in a while... " I would ammend that to say the original pessure sensor is pretty bullet proof, but they do eventually wear out and the replacement sensors aren't even able to withstand a shot from a rubber band gun ( I had one fail in only two weeks).
Cheers,
ronzet
David,
My pressure sensor is, from what I can tell, the original 50+ year old one and it works fine...
Based on your, and others, experience with the replacements.. I just hope I don't need to replace it.. /bcforum/images/%%GRAEMLIN_URL%%/rolleyes.gif
Platinum
Dave has me scared, too. Time was I could count on NAPA for a Q&D switch source. Now it appears that's off th' list. RATS!
David_DuBois
It's not NAPAs fault, just lowest bidder. The switch that Ron Francis Wiring sells is rediculously expensive, but apparently it holds up well. On the other hand, for less than $10 worth of parst and about 15 minutes of time, one can make and install the relay/arc suppression circuit, which I'v had on our cars for close to 10 years and have not had a single switch failure, where prior to that I was going through switches in anywhere from two weeks to about three months.
Cheers,
Platinum
Yeah, "way of th' world" now. Who cares if an LBC shunts over brake failure or gets punted from behind by a Hummer.... "Durn'd things are too small anyhoo. Should be off th' road!"
The relay is a good answer. I thought at first you meant they came apart physically and got a sudden case of th' creeps over that idea.
David_DuBois
"I thought at first you meant they came apart physically and got a sudden case of th' creeps over that idea."
I just went back to see what I wrote and when sitting back in the chair, the i in fail looks like a l. No wonder it gave you a bad moment.
Cheers,
Platinum
We all have our "moments" apparently. /bcforum/images/%%GRAEMLIN_URL%%/smirk.gif
Still... gonna plan for a relay'd switch for when the -inevitable- occurs.
G Brake Light Switch Failure Austin Healey 24
Chrisc9 TR6 TR6 brake light Triumph 6
6 E-Type brake light pressure switch location Jaguar 5
K TR2/3/3A The two wires that go to the brake light stop switch junction......... Triumph 1
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
Hamish Racing TR2/3/3A Remote brake light switch Triumph 5
B Brake light weirdness Dodge Ram Other Cars 5
D TR2/3/3A Brake light switch. Triumph 22
Boink Brake Light Switch... Spridgets 4
RAC68 Third *[3rd] Brake Light Austin Healey 11
K TR2/3/3A 3rd brake light question Triumph 3
L TR2/3/3A Brake light switch location Triumph 9
edkap2002 TR6 stop light [brake light] swith Triumph 9
T Adding a third brake-light Spridgets 5
D extra stop/brake light Austin Healey 33
T 3rd brake light again! Austin Healey 29
T TR2/3/3A 3rd. brake light set up Triumph 12
Jim_Gruber Brake Light - Getting them working Spridgets 8
M TR2/3/3A Brake Light Switch Triumph 24
M_Pied_Lourd TR2/3/3A Brake Light Problem Triumph 9
maxwedge5281 third brake light ideas Austin Healey 34
Gerry M TR6 Brake warning light & oil pressure light stay on Triumph 2
M Brake Light Switch Austin Healey 14
7 brake warning light coming on Other Cars 5
Gerry M TR6 Brake Warning Light Stays On Triumph 3
AUSMHLY Watson Mechanical Brake Light Switch Austin Healey 13
J TR2/3/3A Add brake light to Rear turn signals Triumph 12
wkilleffer MGB MGB brake light switches lately MG 1
wkilleffer MGB brake light switches of late Restoration & Tools 3
Crankshaft TR2/3/3A Brake light wiring? Triumph 6
I TR6 Brake light on -reasons? Triumph 6
M TR2/3/3A Single brake light modifcation Triumph 2
D TR6 Brake light Triumph 3
N Brake light switch??? Spridgets 9
J MGB Electrical issue- turn signals dim and cause the brake warning light to flash MG 8
T 3rd brake light or LED's Austin Healey 28
alanjohnturner TR4/4A intermittent brake-light switch Triumph 11
mgedit TR2/3/3A Brake Light Switch 56 TR3 Triumph 3
J MGB Question on the brake warning light for 78 MGB MG 6
T TR2/3/3A What is thread size on TR3 brake light switch? Triumph 5
P Brake light switch Austin Healey 12
Gliderman8 Faded brake light lens Restoration & Tools 17
T TR6 TR 6 Brake light on Dash Triumph 4
D Spitfire MKII Spitfire brake light pblms Triumph 3
R more reliable brake light switch!?! Spridgets 13
AUSMHLY Stealth third brake light Austin Healey 26
BobbyD TR6 TR6 and other TRs - Brake Light Switch Alternative Triumph 7
tomshobby new brake light switch Spridgets 10
waltesefalcon Spitfire Spitfire brake light Triumph 3
K TR2/3/3A Generic TR3 Brake Light Switch? Triumph 3
