john_j
May car, which isn't a P6 2200, has, because I put one in, a P6 2200 engine.
Now, it has a coil with no label, so I don't know what voltage it is, I will check the resistance to see if that helps, [edit - it's 1.7 ohms]I think the choice is to chuck this coil and buy a 12v one, but I don't know what spec to ask for - it's no good asking for a P6 2200, cos I will get a 7v one, so does anyone have a spec, or a model that has a suitable 12v one?
Alternatively I could get a ballast resistor, but I don't know the spec for that either, and if I can't identify the coil it probably doesn't help much.
[Edit] I decided that the easiest solution was to chuck the coil and buy another one, so you can ignore the question now!
Any suggestions?
Any suggestions?
