TR6 69 TR6 gas tank/emissions
ichthos
I own a 69 TR6. I don't know if I should be starting a new post, but I am confused by a number of discusssions concerning emission equipment and venting of the gas tank. I currently have a strong gas smell in my trunk. I received a number of ideas from my last post on how to find the source of the gas leak in my car, but I admit I am as confused as ever at this point from some of the information. I completely took out everything in the trunk. I can see no evidence of fuel leaking at the filler neck, the line on the bottom going to the carburetors, nor the sending unit hole. I can find no vent tube that has been discussed that leads up to a carbon canister near the front of the car. Moss also shows no evidence of a carbon canister for a 69. Did a 69 have the carbon canister originally? Is there a vent tube on a 69 gas tank, and if so, what is the original pathway? I plan on pulling out the panel on the inside of the car and completely pulling the gas tank this weekend. Any help concerning a 69 would greatly be appreciated.
Kevin
DougF
The vent tube is located on the top front half of the tank.
You will have to remove the interior panel to access it.
I don't have any literature that is exclusive to you car.
My old '74 and my '72 had the line running up the left inside frame rail, parallel with the fuel line, onto the cross member and up to the canister that is bracketed at the right side radiator mount. Tubes from the canister then feed into the carbs.
Andrew Mace
ISTR that the carbon cannisters and overall evaporative emissions did not come along until the 1970 model year; at least that was the case with Spitfire and GT6. Before 1970, those cars had vented filler caps. Perhaps your '69 TR6 also did not have the evap. controls originally, but someone has put a later, nonvented filler cap on the car? Or some other vent is plugged?
Sorry to be guessing, since I'm not as familiar with the early TR6 as I am with the small Triumphs!
TR6oldtimer
As Andrew pointed out, your car did not come with the much discussed canister, or any other fuel vapor recovery system.
Also, you should be able to remove the tank without taking out the rear interior.
As I see it, you only have three potential problem areas.
1. The tank, pin holes, leaking fuel line hose on the bottom of the tank, leaking drain plug
2. The hose connection between the cap and tank. The hose is crack or not properly tightened
3. The tank level sender gasket leaks, or loose retaining screws.
T
Tinster
Icthos:
See if these photos help you a bit. Most of
my TR6 is a 1969. The dashboard is for sure.
My trunk has pieces of a non-functional,early
emissions system. I gutted them and am venting
to the street.
Here is a photo of my gas tank and I have highlighted
the components for you. The three items are your major
suspects for gas fumes in your trunk.
The tank is very easy to remove from the trunk.
15 minute job tops. Mine dumped all the gasoline down
my driveway so I did not have to drain it.
My advice is try the easy stuff first.
1. Remove the trunk liner cardboard in front of the tank.
2. Make sure both clamping bands on the filler pipe
extension are tightened. Is the rubber extension cracked
or split? Is it old and dried out?
3. Take a look and see if you have a small vent pipe on top?
Yes? Then see it it has a pipe connected to it. Trace
the plastic piping looking for breaks or splits.
4. Take a look at your float/gas gauge sending unit. Are
all 6 screws tight? Is there a gasket present? DPO Pedro
"forgot" to install a gasket on Crypty. If you don't have
one; even a non-mechanic guy like me was able to fabricate
and install one.
My advice: FWIW maybe a dime. Take the bloody tank out of
the car, dump out all the rust, sand, dead bugs and paint
flakes. Give the inside a good cleaning and reinstall it.
Hope this helps solve your smelly rear.
/bcforum/images/%%GRAEMLIN_URL%%/thumbsup.gif
Brosky
What's up with the "blue" tank? Does Crypty know about this color change from black to blue?
I'll bet that she ain't gonna be happy about this turn of events...............
T
Tinster
Hey Paul!
Yup, a blue tank. /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
If I can't have a functional TR6 at least
I can have a colorful TR6.
I am doing my best to rid this poor vehicle
of every vestige of PDO Pedro. I am changing out
every K-mart nut nut and bolt, removing all the rubber
bands and duct tape and for critical items (like gas tanks,
brakes, suspension parts) I am stripping DPO Pedro totally
down to bare metal and starting over.
I will rid this car of DPO Pedro, I swear I will!
d /bcforum/images/%%GRAEMLIN_URL%%/lol.gif
I
ichthos
Thanks for all the advice. I pulled the gas tank. It was leaking gasoline in two places: 1) at the sending unit and 2) at the opening at the bottom of the tank. They weren't bad enough to drip, but enough to sure stink up the trunk. In retrospect I am glad I took the suggestion to pull the tank. The rubber seal at the filler cap/tube was not completely seated correctly. Water was running down the side of the filler tube, down the middle seam, and then off to either side - both not visible until the tank is taken out. The pad below the tank was just wet enough to start to rust the bottom of the tank, but not bad enought to rot the body. Now I get to sandblast the tank, check it for leaks, paint it, and hopefully get driving in a week. One last question, there is definately no breather tube on the tank or any evidence of one anywhere on the car - is this normal for a 69?
Thanks, Kevin
TR6oldtimer
Yes, your tank is ok, your model vented through the cap.
T
Tinster
Hey Shawn-
I'm open for suggestions, buddy!
Brand new parts are failing with less than
200 miles on them.
Distance driven between major repair breakdowns
is now well under twenty miles.
On average, I'm now getting less than one hour drive for
each month sitting on jack stands being repaired. And
you know the amount of $$ sunk into this beast has not
been pocket change. And I don't cut corners.
That's gotta be an evil spirit at work in there
somewhere.
d
Ripper01 SOLD-TR6 Gas Tank Triumph Classifieds 3
A Wanted Gas tank for TR6 Triumph Classifieds 5
B TR6 76 TR6 gas separation tank - orientation? Triumph 2
BobbyD TR6 TR6 Custom Aluminum Gas Tank ~ 15 Gallons Triumph 1
hondo402000 TR6 TR6 Gas tank Sealing Triumph 5
hondo402000 TR6 Paint continues now the TR6 gas tank Triumph 9
R TR6 TR6 Gas Tank Outlet Gas Tank to Body Seal Donut Triumph 6
mrv8q TR6 TR6 gas tank removal Triumph 13
B TR6 Draining gas tank and lines TR6 Triumph 3
BierRunner TR6 TR6 Gas Pedal Triumph 4
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
D TR6 1976 TR6 Gas smell in Trunk Triumph 9
P TR6 Tr6 stromberg carb gas leak from starter valve bolt shaft Triumph 5
M TR6 TR6 Gas Leak From Front Carb Triumph 5
BobbyD TR6 TR4 & TR6 Gas Tanks Triumph 6
I TR6 75 TR6 rubber gas lines Triumph 6
I TR6 What glue for TR6 magnet in gas cap? Triumph 9
I TR6 TR6 gas line leak - please help Triumph 15
T TR6 TR4a and TR6 gas tanks interchangeable? Triumph 10
B TR6 TR6 gas gauge stopped working Triumph 10
I TR6 TR6 gas cap help Triumph 2
TR6oldtimer TR6 Central Coast Calif gas and ping in a TR6 Triumph 2
H TR6 TR6 Gas Cap Spring Tech Tip Triumph 4
I TR6 TR6 gas gauge not reading correctly Triumph 11
Paulus TR6 Gas cap fitting on TR6 [71] Triumph 8
bobh TR6 TR6 Gas Pedal Shaft Bushing Install Triumph 16
teeslounge TR6 TR6 Sputter and Gas Triumph 8
S TR6 What were the manufacturer's estimates on gas mileage for a TR6 Triumph 4
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
