TR2/3/3A TR3 windshield disassembly
griff
I need some advice.-- I started stripping down my windshield to take to a platter and have a couple of problems.
1) After removing the Stanchions, I found that I do not have Tenon-plates on mine is that normal for a pre-6000? (everything fit/worked fine just removing for platting)
2) I cannot seem to be able to get the frame off the glass. What is the solution to do so without damaging the frame?
Quick advice would be greatly appreciated as I have time off this week to drive the 1 1/2 hours to the plater's.
Griff
Geo Hahn
Yes you should have tenon plates. I suppose the windscreen is functional w/o them but not a air-tight for the side curtains. Also, the tenon plates are needed if you ever fit wind wings.
Sorry, have never had to separate the glass from the frame but am interested in what you find out.
MGTF1250Dave
Aloha Griff,
I concur with Geo, you car should have come with the tenon plates.
Regarding removing the glass from the frame, the original glazing strip is a tape. I suppose over time it has baked on to both the glass and frame. I have also seen cars where a sealer/caulking material has been used instead of the glazing tape. I would think that mineral spirits would loosen up what ever is holding the glass in the frame. I would suggest you start on trying to remove the bottom of the frame first. Also removing the Tenax pegs should give you a access to squirt some mineral spirits into the frame. Work slowly on a padded surface if you are trying to save the glass. A gallon of mineral spirits cost much less than windshield glass. Good luck.
NickMorgan
I agree with all of the above. Take care if you are replacing the Tenax studs. I went through the process of dismantling and cleaning my screen. When I fitted the new Tenax the threaded part was longer than the original and I cracked my windscreen.
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
K TR2/3/3A The Harley Davidson side mirror that mounts to the TR3 windshield stanchion? Triumph 11
N TR2/3/3A TR3 windshield Triumph 2
N TR3 Windshield FORUM Navigation Questions 0
Lbp TR2/3/3A Question about TR3 Rubber Windshield Seal Triumph 9
Tinkerman TR2/3/3A Windshield glazing TR3 A 1960 Triumph 7
D TR2/3/3A tr3 windshield Tenax fasteners Triumph 2
luke44 TR2/3/3A TR3 Windshield Rebuild and Assembly - Step by Step Triumph 20
luke44 TR2/3/3A TR3 Windshield Stanchion Short Screws Long Screws Triumph 2
6 TR2/3/3A TR3 windscreen/windshield glass Triumph 5
M TR2/3/3A My own TR3 windshield question? Triumph 5
J TR2/3/3A TR3 windshield angle and body shims Triumph 11
O TR2/3/3A TR3 Turn Signal Retrofit / Windshield Screws? Triumph 7
O TR2/3/3A TR3 Windshield to Scuttle Mounting Triumph 1
S TR2/3/3A windshield wipers tr3 Triumph 1
T TR2/3/3A TR3 Windshield washer pump Triumph 14
B TR2/3/3A TR3 Windshield Wiper Tubing Triumph 5
Marvin Gruber TR4/4A Windshield motors TR3 & TR4 Triumph 2
AngliaGT TR2/3/3A New Windshield for TR2,TR3 $150 Triumph 2
S TR2/3/3A windshield post 60k tr3 Triumph 10
O TR2/3/3A TR3 Windshield Glass Replacement Triumph 2
mountainman TR2/3/3A TR3 Windshield Center Support Triumph 1
G TR2/3/3A TR3 windshield corner finishers Triumph 4
O TR2/3/3A TR3 Windshield Replacement Triumph 4
G TR2/3/3A TR3 Windshield size question Triumph 2
G TR2/3/3A TR3 windshield isntall Triumph 11
B TR2/3/3A TR3 Windshield-[screen]? Holder on'r thingy remove Triumph 6
G TR2/3/3A TR3 windshield assembly sequence Triumph 9
mrv8q TR2/3/3A TR3 Windshield Stanchion Q Triumph 6
D TR2/3/3A TR3 post 60000 windshield stanchion guide plates Triumph 5
M TR2/3/3A TR3 Windshield Frame Triumph 2
bmurphy7369 TR2/3/3A TR3 Windshield Stanchion Guide Plates? Triumph 22
