Engine will not stop
Jim R. Walker
Ok - could someone help me? I have a 67 BJ8 that runs great except when I turn off the ignition the engine runs a few more moments and coughs, shakes before finally turning itself off.
I tried looking at the various manuals, Haynes etc but can not locate this problem or solution.
Thank you.
Steve
Platinum
Called "running on", I believe that this is an indication of the mixture being too rich. It could also be an indication of a buildup of carbon on the cylinder head, although I think the rich mixture theory is more likely. Adjusting the carbs may help, but always do the easy checks first. Is the air filter clogged up? If the engine isn't breathing right, that might contribute to the problem. If the choke is sticking on that might also cause problems.
P.S. Welcome to the forum!
[ 07-13-2002: Message edited by: Steve ]</p>
dwbening
Welcome to the forum.
I believe the problem is a combination of carbon buildup and timing that is a bit off.
dwbening
coldplugs
Platinum
As stated in earlier posts, this is usually due to carbon buildup that stays hot enough to ignite the fuel without assistance from the plugs. If it's a mild case, a higher octane fuel often eliminates it (it has a higher flash point). Of course, this isn't an option if you already use premium gas. Opening the throttle fully sometimes helps (after you switch off) by reducing temps but this may not work with SU's (pistons will block most of the bore).
"Running-on" like this sounds awful but doesn't hurt anything. However, cars that do this often are pre-igniting ("pinging") while driving which can burn valves. Retarding the timing a little and higher octane can help. A slightly richer mixture can sometimes work.
Eventually, the carbon should be removed. Older engines needed this done frequently (it was usually called "De-coking", one of my favorite maintenance expressions) probably due to the nasty fuels used back then.
John C
J
Jim R. Walker
Wow... thanks for all the help. Gee.... I just got involved with this forum. I appreciate the help, suggestions and acceptance from you experienced owners. I hope someday I can return the help.
Jim
aeronca65t
I agree with all other comments listed, but would also like to add: check idle speed. If it's too high, car will "run-on". Also, be sure it's not running hot (themostat, etc.)
For a varity of reasons, my car does this on occasion (carb/cam combo won't allow real low idle).....I "stall" the engine by letting the clutch out in 3rd gear immediately after switching off the ignition. Not exactly elegant, but it works (be sure you have right foot on the brake if you do this).
Re "de-coking"...there's a great section about this in the TR-3 owners manual (advised every 10,000 miles!). Fortunately, unleaded fuel mostly eliminates this problem.
[ 07-15-2002: Message edited by: aeronca65t ]</p>
John Turney
I've had this problem appear occasionally over the years. The last time it was a sharp corner on a spark plug electrode. It would get/stay hot enough to ignite the mixture. I've also found that running lean can increase the combustion chamber temperature and cause deposits to glow. It sometimes helps to give it a good run at speed
John
Ken G
On the subject of decarbonizing engines, some of you might be amused at the instructions for my 1925 Rover, to be found on pages 34-35 of the service manual. See https://mywebpage.netscape.com/rover1927/index.htm
(For the sharp-eyed, the car was built in 1925 as a 14/45 and upgraded in 1927 to a 16/50; the manuals are substantially identical).
Ken G, 1925 Rover 16/50
jjbank
Member
Jim R.,
I have had the same problem with my healey. You can try to adjust your carbs or your timing, that is if you know how or trust yourself to do it. I do not trust myself? I researched this problem " running on" and it is not uncommon. I also concluded that a higher octane fuel may help to clean out the cylinders. I have used a product called Bardahl's octane boost. I use it about every third or fourth fillup and then only 1/3 the amount specified. I have been doing this for approximately 2 1/2 years and I have not had a problem with "diesling" or " running on" since. Could some of the more experienced healeyists please comment on my solution?
GoBritBaby
I've been through this recently. So, here goes:
Use high octane gas. AH have hi compression pistons.
Use the proper spark plugs.
Check timing and adjust carbs.
Failing all the above, pull the head decoke and take the sharp edges off the head with a dremel. The sharp edges are hot spots and will ignite the remainging gas- run on.
Good luck
KVH TR4/4A I Can't Stop Burning Oil; Engine Missing at Take Off Triumph 5
PatGalvin The fun just won't stop [engine rebuild questions] Triumph 53
EastBoundJoe Engine runs rough then die's while at stop sign Spridgets 7
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 4
L Engine ID British Motor Corp 2
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
D A distributer question on the 1275 engine. Spridgets 7
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
kodpkd 1961 BT7 engine oil Austin Healey 31
S TR2/3/3A engine removal Triumph 12
R TR2/3/3A Engine stalling and backfiring Triumph 25
M Engine ID Austin Healey 2
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
KVH TR4/4A Engine Installation Triumph 28
P Spitfire Going up-Engine with my Herald Triumph 6
