Overdrive Conversion
malexalex
Member
Hey, this may seem like a dumb question, but I was wondering if it is possible to convert a non-overdrive engine to an overdrive... and if it is possible, the pros/cons of such a conversion like the cost, difficulty, and benefits... I have a 1970 spitfire with the engine from a '78 spitfire 1500
Thanks,
Alex
heliguy
Its the transmission that is converted. It can be pricey unless you have a line on a overdrive tranny allready. Lower revs makes highway cruising very nice. Good for the resale value but as i mentioned before, unless you have an overdrive tranny ( or an overdrive mainshaft to convert your exsisting gearbox ) it tends to get expensive........
DNK
Alex Check the archives .There is probably enough info on this to fill the Library of Congress.
billspit
Yes it is possible. I did it with my MkI. I little harder because it was a 1500 OD unit and not the correct one for an 1147. It adds more weight and, as stated, can be pricy. I bought a no-title parts car that had the OD (thats why I bought it) for $250. It works fine so I got a pretty good deal. You will need the correct drive shaft and rear trans mount plate and rubber mount. I got all these from my parts cars.
The conversion helps immensely at cruising speeds and the resale value of the car. I also went with a 3.89:1 diff and am in the process of getting a 3.63:1 diff rebuilt. Then I ca really cruise with the big boys (if the engine will pull this load).
TheAssociate
I haven't converted a car to overdrive, but I have put a non-overdrive engine in an overdrive car and noticed a few differences.
The clutch is a completely different diameter(in my case the car was late model), you will need a flywheel and clutch to match the overdrive transmission. You are probably on your own for wiring, you may have to make your own small harness/wires. The drive shaft is a different length, and the trans mount is different.
Sounds like a lot, but it all comes together quite easily if you have the parts. Plus, if you are really anxious to drive, you can do it in stages, like refurbish the trans, and install. Then hook up the wiring when you have time.
Adam H.
______________________________________________________________________________
1973 Triumph Spitfire
kcbugeye1275
My son And I did the switch in a TR6 with an overdrive tranny out of a rustbucket car and it really makes it a better car. The key is the patience and desire to find an overdrive in a dead car, its less expensive.
2wrench TR6 Do the HVDA [Toyota overdrive conversion] or repair my existing J Overdrive? Triumph 29
O J Type Overdrive Conversion Triumph 19
deadair TR2/3/3A TR3A Overdrive Conversion Triumph 7
T TR4/4A TR4 Overdrive Conversion Triumph 8
T TR2/3/3A TR3A overdrive conversion - whats needed Triumph 6
A TR6 FREE, Manual Overdrive Shifter conversion [tr6] Triumph 1
C Transmission conversion for overdrive what to do? Austin Healey 15
RickPA Overdrive Oil Pressure Austin Healey 8
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
71TR6 TR6 Type-J Overdrive identification Triumph 4
T Wanted Working overdrive unit Austin Healey Classifieds 2
D Overdrive Stops Working After Oil Change Austin Healey 26
S TR2/3/3A overdrive does not function Triumph 45
T TR2/3/3A A type overdrive hard engagement Triumph 36
S Overdrive Throttle Switch Austin Healey 4
KVH General Tech Overdrive--Afraid it's Serious Triumph 45
M Overdrive Pressure Test Austin Healey 2
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
Fanch00 Non-Overdrive Benefits? Austin Healey 10
R TR6 J-Type overdrive will not disengage when warm Triumph 8
S Overdrive Relays Austin Healey 2
AUSMHLY Overdrive Buffer Pad Austin Healey 3
L Stuck in Overdrive Austin Healey 10
AUSMHLY Flushing the Transmission/Overdrive Austin Healey 7
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
P Overdrive Not Engaging Austin Healey 4
S BJ8 Overdrive Stays Engaged Austin Healey 35
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
AUSMHLY BJ8 Overdrive Pressure Loss Austin Healey 11
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
John Turney Overdrive Pump Austin Healey 6
S Removing Overdrive Shaft Lever Pin Austin Healey 7
nevets Reversing With Overdrive "On" Austin Healey 8
Healey Nut Overdrive Relay Austin Healey 1
T Clutch or Overdrive Slip Austin Healey 8
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
A TR4/4A TR4 Overdrive Solenoid Triumph 19
H TR4/4A A-type overdrive pump Triumph 4
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
Rob Glasgow New Fangled Electric Overdrive Austin Healey 9
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
J Transmission and Overdrive Rebuild Austin Healey 6
C Overdrive Failure Austin Healey 18
D TR2/3/3A Overdrive question. Triumph 49
ckeithjordan TR2/3/3A Overdrive Wiring Triumph 5
D TR2/3/3A Type A overdrive not engaging Triumph 0
