Tips on installing a new turn signal switch
tdskip
I figured that the turn signal switch rod breaking off was a pretty good sign that it was time to install a switch.
So I've got he old switch mount loose but am thinking that one of you has done the recently and can provide some coaching on how best to run the new wires down the steering column.
Any tips for me?
Thanks!
DNK
Tour going to have to loosen everything up to do it right and have less hassles.
roofman
Make sure they do not get pinched when you retighten the bracket.
Andrew Mace
I agree with all the above. On any Triumph using that Herald-based steering column, I find it easiest to actually remove the "conduit" piece that runs under the column to conceal the wires. That can be done by removing the clamping nut/bolt on the lower part of the conduit and then loosening the bolts on the upper column support enough to slide the conduit downward and disengage the tab at the top.
Geo Hahn
Above is the correct way. OTOH, there is my way. I recently added an overdrive switch to the column and needed to feed the wires down thru that 'dagger'. I took a length of 1/4" irrigation tubing (the shiny black plastic kind), cut the end at an angle and fed it up thru the dagger until it appeared around the switch area. Then it was just a matter of attaching the wires to it (I think I pushed one bullet into the tubing and taped the other along side that wire) and pulling it down thru.
Well it worked and might save you some disassembly, otherwise taking it apart is the sure way to get there.
Flinkly
i lack the understanding as to why you wouldn't take it apart to begin with. i guess it's like climbing a mountain, just to see if you can do it.
kodanja
Taking it apart is the easy part, getting it back together correctly is the challange!
drooartz Installing front hubs, tips? Spridgets 15
I Tips for installing intake manifold plugs in a stock Bugeye? Spridgets 6
JodyFKerr Tips & tricks on installing upright air compressor Restoration & Tools 15
Jer Tips on Installing Stereo Spridgets 14
M Installing wire tips Triumph 24
I Tips or installing Bugeye bonnet needed Spridgets 14
B tips on re-installing trans on bj-8 Austin Healey 5
U Tips to installing K&N filters please MG 6
S TR2/3/3A tips for mig plug welding vertically? Triumph 11
J Tips for quarter elliiptic spring install Spridgets 3
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
PC DIY tips from Bo his self Other Cars 0
BoyRacer Need Tips on getting wiring harness through firewall Austin Healey 4
BoyRacer Tips on gluing new fabric to dash on my BT7 Austin Healey 10
HighAltitudeTR3 TR2/3/3A Leaky Carb Tips? Triumph 11
HighAltitudeTR3 TR2/3/3A Choke setting tips? Triumph 7
bugedd Bench bleed tips Spridgets 14
S TR4/4A Electrical wiring tips Triumph 2
TEM666666 Sprite MK1 Door liner rubber mat installation.. Need tips and recommendations. Spridgets 22
F Buying a 100.... tips Austin Healey 18
drooartz MGB Changing clutch hose - tips? MG 13
T Tips for Searching FORUM Navigation Questions 2
T TR4/4A Any tips on re-torquing TR4a head now that 500 are on the rebuild Triumph 7
T TR4/4A Tips on controlling heat coming up through shifter opening? Triumph 14
M tips please on removing starter motor on 100-6 Austin Healey 6
gbtr6 TR6 Rebuilding TR6 Engine, Tips? Triumph 7
bugedd Su adjustment tips Spridgets 7
B Seam Sealer/Caulking - Any Tips on When, Where, and What to Apply? Austin Healey 45
C Any tips on how to remove frozen pistons from drum brake Wheel Cylinders??? Austin Healey 11
PatGalvin TR2/3/3A Carpet Install Tips Triumph 12
Bob_Spidell Tips Austin Healey 6
Tinkerman TR2/3/3A Front Fender Installation Tips Triumph 3
Tinkerman TR2/3/3A Windscreen mounting tips 1960 TR3A Triumph 2
W Looking for tips: BJ8 roll up windows Austin Healey 10
I TR6 Any tips on removing flasher switch Triumph 3
M Radiator Hose tips? Spridgets 0
T TR4/4A Any tips on running the overdrive switch wiring down the steering column? Triumph 11
T TR4/4A Making an OD pressure gauge - any tips? Triumph 7
bugedd About to rebuild front end...any tips? Spridgets 5
B Spitfire Changing leaf spring bushing - any tips? Triumph 6
RedTR3 TR2/3/3A Tips for Breaking in a Rebuilt TR3 Engine Triumph 6
apbos Two Restoration Tips Spridgets 11
J Tips on Re-Assembling Lenses/Gaskets? Austin Healey 5
TulsaFred Rear Hub bearing and oil seal tips Spridgets 0
5 TR2/3/3A TR3 engine building tips needed Triumph 5
TulsaFred Bugeye rear wheel cylinder replacement tips Spridgets 10
Lbp Install l-t-d fasteners on new tonneau - Tips? Triumph 8
T Wheel cylinder fitting kit - any tips? Triumph 4
D Spitfire '65 Spit window regulator installation tips needed Triumph 0
J 67 IRS Exhaust Tips Triumph 2
