Need Opinions on Difference in Stromberg Manuals
bravenrace
I need to pick up a manual on Strombergs. So far I've seen two. One is a Haynes manual that deals only with Stroms and appears to be out of print. The other is also a Haynes, but it covers Stroms, Webers, and SU carbs and it's still in print. I don't mind getting the new one, but does it have as much information on the Strombergs as the old manual?
Thanks,
Jim
Steve
Platinum
I wish I knew the answer for you. It could be that the newer manual has all of the information of the older one, with the infor on Webers and SU carbs in addition, which would be a very useful book to have.
drooartz MGB The state of my engine -- need some opinions MG 12
B TR6 Need a few opinions on parting out/pricing for TR6 Triumph 8
TR4nut Need opinions on my gearbox rebuild.. Triumph 12
Wana Selling my Healey, need opinions Austin Healey 16
S '67 BJ8 Barn Find - need opinions Austin Healey 60
Dan_Pasta TR2/3/3A Need TR3A wire wheel opinions Triumph 7
T okay healey buffs - I need some opinions here Austin Healey 6
SeldomSeen Nice Mini - Need Opinions British Motor Corp 15
vping Need honest opinions. MG 29
B Need Opinions - Trumpet Repair MG 21
TR_JOE250 Spitfire Spitfire carb need help/opinions Triumph 6
H Sandblasted heat shield pic, need opinions MG 6
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 10
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
tinman58 TR2/3/3A Need super charger!! Triumph 7
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
John Turney Need a Better Demister? Austin Healey 5
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
