TR4 Steering Arm For 2500M?
bravenrace
I was reading something that mentioned that the 2500M was plagued with terminal bump steer. It said that repacing the TR6 steering arm with one from a TR4 solves the problem.
Can anyone comment on this?
GoBritBaby
Looks like we are ready the same stuff. If true, it would be great to know what Moss part # they are referring to as it looks like there are 2 different styles for the TR4.
Cheers,
bravenrace
bravenrace
Well, if you buy one and I buy the other... /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
martx-5
I found this info on the internet...
"1. The stock 2500m suffers from terrible bump steer. Bump steer is a change in the direction that the wheel is pointing (with NO input from the steering wheel) during suspension travel. The main cause of the bump steer is the stock TR6 steering arms. They cause a steep angle between the steering rack and the tie rod end,. To cure, use the 'shallow droop' TR4 steering arms (not all TR4 arms are alike). It is likely that TVR designed the suspension geometry with the TR4 part in mind, then some clever soul changed to TR6 parts without consulting anybody..."
Which steering arm is the "shallow droop" one is anybody's guess. BTW, Moss lists THREE sets of steering arms for the TR4. The earliest set seems to end when Triumph went to the 3 deg caster, so that one would be the rarest. I guess you would need to see all three together. Also, Moss has all of them listed as not available.
bravenrace
bravenrace
Coincidentally, it was that website where I first read about this. I haven't even driven mine yet, so I'll wait until I do to decide if this is a real problem or not, although just looking at it my guess would be that bumpsteer would be a problem. If it is, someone here must have dealt with it before. If that's the case, maybe they can let us know which arm is needed.
martx-5
Perhaps you might want to post this over on the Triumph forum, as there a lot of knowledgable guys over there that might know which is the 'shallow droop' TR4 steering arm.
M TR6 EZ EPAS Steering Column Fitment to TR4-6. Triumph 0
M TR4/4A Triumph TR4/4A Steering Column spline size Triumph 1
KVH TR4/4A TR4 Steering--Just a Question I've Always Had Triumph 1
TRMark TR4/4A Strengthening early type TR4 steering rack mounts Triumph 4
glemon TR4/4A TR4-6 Steering Upgrades Triumph 15
B TR4/4A TR4 steering rack Triumph 2
H TR4/4A tr4-a steering parts Triumph 3
KVH TR4/4A TR4 Steering Rod Splines Triumph 2
T TR4/4A How do YOU fit steering rack bushings on TR4-6s? Triumph 6
M TR4/4A TR4 Steering Wheel Triumph 6
KVH TR4/4A TR4 Steering Rack and Alignment Questions Triumph 7
T TR4/4A TR4 Steering Up-date Triumph 0
thechileman TR4/4A Replacing TR4 Steering wheel Triumph 10
T TR4/4A tr4 steering column-replace rubber with u-joints? Triumph 9
T TR4/4A Early TR4 Steering Triumph 2
KVH TR4/4A TR4 Steering Rack Problems Triumph 0
T TR4/4A tr4 steering wheel-modifications Triumph 8
M TR4/4A TR4 Steering column coupler Triumph 5
T TR4/4A anyone have tr4 steering arms? Triumph 0
M TR4/4A TR4 Steering Racks Triumph 5
SCguy TR4/4A TR4 Steering Rack? Triumph 2
SCguy TR4/4A TR4 Steering column threads ? Triumph 1
SCguy TR6 TR4/TR6 Steering rack question Triumph 9
D TR4/4A tr4 steering - inner ball joints loose Triumph 14
KVH TR4/4A Bushing Torque and Steering TR4 Triumph 3
TR4nut TR4/4A Opinions on a TR4 steering wheel replacement? Triumph 12
M TR4/4A TR4 Steering Rack - play Triumph 4
Alan_Myers TR4/4A TR4 steering column bracket Triumph 7
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 0
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
E TR4/4A What Flare to put on a TR4 Brake Line Triumph 2
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level Opinion - Differential Gasket Replacement 62 TR4 Triumph 10
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
KVH General Tech Jacking Up The Rear of TR4 Triumph 5
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
