TR6 TR6 Tire Size
Cain
What's the best tire size for a TR6? The LBC shop owner told me 195R75-15, but the guy I bought the car from (who owns two other TR6's) told me 205R75-15 because they 'handle' better.
I've found that the 205's are easier to find - i.e., cheaper.
TIA
G
Cain,
As I stated in a previous posting a while back, original sized (195) tires for the 6 are impossible to find at local tire dealers. Buying from a mail-order tire store is quick, easy and cost-effective. 205's on stock rims are about as wide as you can go with the wheel width. Actually, you are better off with 195's especially on a rainy pavement: less lateral sliding, believe it or not. Unless of course you go for an ultra-high performance tire that works well on wet pavement. Then that defeats the idea of "cheap".
Bill
G
I am running Pirelli P4000's on Panasports and my nuts draw up when I am running on slick, wet pavement. But let it be hot and dry and I can lift a wheel without raising my blood pressure.
Again, Bill
Bruce Hawkins
Cain: I've got a TR4A and a TR250. I've got the 205's on the TR4A without any problems, so my bet is that the TR6 will be fine. The only issue to be careful of is making sure that the rims you use are at least 5.5in. Some of the older rims are only 4.5in. and they won't handle the tire width.
Bruce
Steven
Why is it that the domestic stock tire for the TR6(in Britain) is a 165SR15....or more commonly known as a Volkswagen Bug Tire?
Dave Russell
Yoda - R.I.P
Steven,
I think that it is a matter of different cultures. People in the U.S. are used to seeing street rods & race cars with wide tires & tend to equate the same with performance no matter what the car is used for. Also it is cosmetic, wide tires just look cool.
TerrierCarrier
Last time I ordered red lines was from Coker Tire. They actually had Michelins at the time. I did a quich search and they don't list TR-6 stock tires but I'd give them a call anyway.
Don
tony barnhill
Great Pumpkin - R.I.P
Gary Pope
I did some research a while back and found that a 205x70x15 will have the same diameter as the original 185x80x15 and therefore you would have no speedometer calibration issues.
Although, 205x75x15 wouldn't give you too much problems.
T
Trevs1
I just bought a pair of the Michelin 185SR-15X for the '76 TR6 from Coker. These are the specified size per the Repair Operation Manual. The local garage was able to get teh inner tubes for them.
For all the ill press these tires get, I still prefer the look of these original Red Lines.
Besides, the first set has lasted 75,000 miles. The rear tires on the car are still the originals.
P TR6 What make and size tire was on the TR6 when it left the factory? Triumph 7
MTribe TR6 TR6 tire size photos? Triumph 30
N TR6 Opinions on 205-70R15 tire size for TR6 Triumph 11
YYCDave TR6 TR6 Rear Shock Conversion & Tire Size Triumph 2
B TR6 Yes.....another TR6 tire size question Triumph 7
B TR6 Question about tire size options on a TR6 Triumph 3
T TR6 TR6 Tire Pressures Triumph 2
J TR6 Tire Recommended for TR6 Triumph 3
Scot1966 TR6 Screws in TR6 spare tire well Triumph 12
sundown TR6 TR6 tire pressure Triumph 4
I TR6 69 TR6 spare tire lid Triumph 4
bcbennett TR6 TR6 Tire Clearance Triumph 3
B TR6 TR6 Tire Advice Triumph 6
B TR6 Putting a 205 75 tire on a tr6 Triumph 4
bcbennett TR6 TR6 Spare Tire Triumph 27
R TR6 TR6 Spare Tire Cover Needed Triumph 9
bigbadbluetr6 TR6 TR6 Spare Tire Triumph 1
I TR6 TR6 - uneven tire wear in rear tires Triumph 1
F TR6 TR6 Tire Recommendatios Triumph 12
AngliaGT TR6 TR6 Tire Replacement Triumph 6
R6MGS TR6 Another TR6 Tire Thread Triumph 21
SpannerMan TR6 TR6 jack minimum height for changing a tire? Triumph 5
Brosky TR6 Looking for tire advice for TR6 Triumph 17
T TR6 TR6 Tire Sizes - Modern Equivalent to 185 SR 15? Triumph 13
T TR6 Tire Preservation Question - 1976 TR6 Triumph 13
Z TR6 TR6 Tire Recommendation? Triumph 5
SCguy TR6 Tire suggestions for a TR6/Panasports Triumph 4
B TR6 My TR6 rear tire tilt inwards at top Triumph 9
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
