Question About 2500M Seats
bravenrace
My '74 has really flat seats with black and white plaid/ checkered insets. This is the only '74 2500M I've seen with this seat and upholstery. The car is documented to have only 9500 miles on it (I still have my doubts about that), so they should be original, but these seats are not the same style that's in every other 2500M I've seen. The driver's seat is ripped, and I'd like to replace these seats with something better, but they are so small that a lot of the aftermarket seats don't look like they'd fit. I made a post a while back asking about seats, and the seats in the picture I posted would be perfect if I could find them.
Can anyone enlighten me about this?
Deleted member 3577
I heard someone say that getting in a TVR was like crawling into a dog box.
Diet & exercise
(And maybe a little stretching)
bravenrace
bravenrace
Hey, I didn't say I didn't fit! /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
I also don't deny that it's not the easiest car to get in and out of, but once I am in it, I find the seats less than supporting. They are also ugly, and the one needs repaired. To me that says - Replace them! The question is, with what?
Deleted member 3577
My Bro's Vixen seats look very similar....
I really like them but, it takes a little getting used to.
They have much the same shape as real racing seats.
If yours are made like his, and I think they are, you can easily pull out the center section for recovering.
(In any colour you wish)
bravenrace
bravenrace
I don't think they are like your bro's. These look like they came out of a Vega.
mrtvr
Actually your seats Are different from those in the Vixen. Yours have the folding mechanism and the cars generally came in all vinyl. I guess it's possible your car was ordered with the checked cloth inserts, but most likely, it was done at some point after delivery.
I've heard some people say that Mazda Miata seats fit and there may be some of the aftermarket seat suppliers that offer a seat that will fit. If you have the dimensions, you might try Corbeau, Recaro, and other such suppliers to see if they have one that will be the right size to work in the M.
Deleted member 3577
Here are a couple of seat pics from the Vixen.
Plus an engine shot..........I really like this little mill.
(I can pick up the bare block w/ one little finger /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
bravenrace
bravenrace
Okay, below is a picture of the passenger seat in my car. As Marshall mentioned, it's not the same as the Vixen, although I personally like the Vixen seat better. So is this the correct seat for my car? Do you think the inset is factory or added later? I know one thing - It sure is ugly!
bravenrace
bravenrace
Steve,
Thanks for the link. I think that is the seat.
Jim
bravenrace
bravenrace
Is that a Midget engine? I helped my bro in law pull one once. We attached a strap to it and he pulled from one side and I pulled from the other! Not much heavier than the engine on my go-kart!
GoBritBaby
Your seat seems identical to my 2500M seats in terms of size, shape, and the hand lever. My guess is they "borrowed" some of that strange plaid pattern Triumph was using on the TR7 seats.
Cheers,
Steve
mrtvr
Seat in your photo is the correct seat for your M, except for the checkered inserts. Of course, you could go to a good upholstery shop and have them redo your seats with new foam, webbing, and upholstery of your choice, or you could go with a replacement seat when you find one that would fit the available space.
Grantura_MKI
Those would appear to be the correct seats with after market covering, as Marshal stated. I would go after a set of Sparco's as they make very nice fitting seats for small areas.
Cheers, David.
Twosheds
Not the best photo (I should have opened the door), but these are Cobra Classic seats. I think Corbeau makes a similar style. They fit my old TR3 with a little modification to the transmission tunnel using a BFH. Of course, the TR3 tunnel is nothing compared to a 2500! They are very light seats, too. The bolsters might make entrance to a TVR difficult, a problem I didn't have in the TR3.
bravenrace
bravenrace
Thanks for the picture, John. I've seen those and like the classic look of them. I'd be alittle hesitant to buy them without sitting in them first, because like you said, the side bolsters might be an issue when getting in or out. I'm pretty sure once in, I'd like them!
Deleted member 3577
Ford crossflow.
The first 12 S1 Vixens got the MGB engine.
The other 105 got the X-Flo.
117 S1 / 438 S2 / 97 S3 / 23 S4 That makes 675 total Vixens.
BTW.....The "M" in 2500M Stands for Martin as in Martin Lilley
Twosheds
WhatsThatNoise said:
The VERY FIRST Vixen ever made resides in one of my sheds
(I'm renting the shed to my friend). It has an MGB engine.
Deleted member 3577
Do you happen to know its registration number?
Any pics that your friend would agree to post?
I really like the S1 Vixen.....Doesn't matter X-flo or MGB.
I'm told the B is more torquey but, the ford is lighter & spools up faster.....Obviously better head design.
Ever thought about buying a TVR?
Your friend putting TVR pressure on you?
Twosheds
I know my buddy sent me the registration number, but I can't find it now. I thought I had a current photo, but I don't and I'm not going out to the shed right now! I do have this photo from a magazine article. I think it's from British Car about the history of TVR. Notice the hood scoop is kind of squared off.
I have thought about buying a TVR. Once was in 1979. But seein' as how I'm disabled, broke, and unemployed... Besides, I like getting the rent, as little as it is...
My Buddy had another Vixen that he started to put a Mazda rotary in. I brokered that one to Rich Rock less the Mazda, but with the Kent. The rotary is also in the shed. Anyone interested? 250 HP!
I'll try to get out to the shed tomorrow and take a photo, but the rotary will be in the way. And I'll look at the data plate.
B 2500M chassis tube question TVR 2
D TVR 2500M wheel question? Other British Cars 3
DonC1948 TR6 A "CLASSIC" question. Triumph 6
71TR6 TR2/3/3A A TR3A wiring question Triumph 17
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
scottkilpatrick TR4/4A Gear oil and choke question Triumph 4
B TR2/3/3A TR3A Gearbox fluid capacity question Triumph 7
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
K TR2/3/3A Brand new brake caliper question... Triumph 8
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
R TR6 question re: Engine Oil Triumph 3
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
Bayless Door seal question Spridgets 3
M T-Series TD/TF Steering Free Play Question MG 6
sail TR4/4A Piston Ring Question Triumph 6
B TR4/4A Basic Wiring Question Triumph 35
KLUTZ Wedge FASD wire question Triumph 1
T TR2/3/3A Brake system question - Triumph 4
drooartz MGB OD question - need to warm up? MG 8
J TR4/4A Sellers Reconcilliation Question Triumph 7
drooartz MGB Question on timing and vacuum MG 11
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
T TR2/3/3A TR3 Fuse Question Triumph 14
B TR4/4A Jaeger Gauge Question Triumph 16
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
