TR2/3/3A Front End Spec for TR3A
Mickey Richaud
Kenny -
TR3's are the ultimate in simplicity. There's really only one adjustment to be made, due to the design of the front end - toe-in. And that is basically zero. Moss Motors and The Roadster Factory sell a nifty device for setting toe-in. It's an aluminum gauge that you place at the front and the rear of the tires and compare the distance between left and right side. You adjust the tie rod ends until you get in tolerance (with the steering wheel straight ahead). I did mine myself and had it checked at an alignment shop (one that had a rack narrow enough!), and it was perfect.
Hope this helps you.
Mickey
TR3-2001SE
Thanks! This probably explains why I never had it adjusted over the years. I will look for the part in the Moss catalogue
TR3-2001SE
Time to align the front end of my 1960 TR3A. Don't believe it has ever been done before but just rebuilt all the front suspension. Anyone know the caster,camber and toe setup?
MGTF1250Dave
Aloha Kenny,
A long time member of my car club showed me a quick way to check and adjust toe-in/out. Take a stout string, longer than your car, and attach it to the the rear spring behind the rear wheel. Take it to the front of the car and tie it off to something handy (front sway bar or bumper bracket). Take all slack out of the string and position it so that it runs on the outside of the tires about 8 inches above the ground. Now sight down the string to see that it touches the front and rear of each tire and the string is a continuoius straight line. Adjust it up or down as required if spoke or wheel covers are in the way. Turn the steering wheel as necessary to get the front tire lined up and string straight from rear to front. Now do the same thing with another string on the other side of the car, but do not touch the steering wheel. If the string on this side is not a straight line, see which way the front tire needs to move to make it straight and adjust tie rods as necessary. The description of the process is more complicated than it is to do. I've used this several times with good results.
Safety Fast,
Dave
aeronca65t
Good suggestions above...I've used the "string method" and I eventually built a contraption similar to the device sold in the Roadster factory.
One added comment, if you dissasembled your front end.
1. Turn the steering wheel all the way to the left.
2. Then turn all the way to the right and count the exact number of turns.
3.Then turn exactly half way back to the left (half the number of turns)so that the steering wheel is exactly as it should be for "straight-ahead" driving.....and then adjust your toe in/out....this will insure that you have equal "limits" both left and right (it also insures that the "toe-out on turns" geometry that is built into your car will function correctly). You may wish to clamp the steering wheel or have someone hold it "straight ahead" while you are make the toe adjustment.
MDCanaday
Just to add 2 cents, my suggestion is to get it computer aligned, at a shop that can give you a printout of all the angles(SAI, IA, castor, camber
and toe)Granted there is no(easy) way to re-align the castor & camber, but if somehow there is a bent componet in the system(god forbid!!) this will reveal it. I have seen many tr's that have had curb damage that caused neg castor, this is not a good thing, and should be addressed.Camber problems are mostly crash related too, so its better to know than drive on in an unsafe manner.
MD(mad dog)
G MGB '71 MGB Front End Rebuild MG 2
X Front End Alignment Austin Healey 14
craigshealey3000 Front End Shake Austin Healey 31
B Bent frame rails near BE front end Spridgets 2
B 2013 Nissan Frontier front end mystery Other Cars 7
K TR2/3/3A Front wheel bearing adjust and end float?? Triumph 10
Michael Oritt Lube points on BN/BT7 front end Austin Healey 4
K TR2/3/3A Advise on previously botched front end lower fulcrum support bracket. Triumph 5
AUSMHLY BJ8 Front End Squeak Austin Healey 25
AUSMHLY 64 front end too high Austin Healey 14
thibault BJ8 plus 55mph Front end shaking Austin Healey 100
vette Effects of Lowering the Front End Austin Healey 21
G Front end Alignment - Total Toe vs. Individual Toe Austin Healey 3
R Front wheel bearing - end float Austin Healey 40
T For Sale For Sale: Bugeye Front End Spridgets Classified 0
K TR2/3/3A Front end woes... Triumph 18
S Wedge tr8 front end Triumph 0
B TR2/3/3A Front end alignment Triumph 23
Jim_Gruber Bugsy IV Front End Rebuild Spridgets 5
mcmillal TR4/4A Front End Vibration Triumph 9
K TR2/3/3A Front end Question.... Triumph 4
M front end alignment Austin Healey 12
T TR4/4A Front end alignment specs for lowered car Triumph 2
Joe Reed MGB Rattle under front end? MG 8
J MGB Project car done; front end clunk noise while braking MG 4
S TR2/3/3A Front end alignment and tire wear Triumph 9
aeronca65t Minor front end work Spridgets 12
RAC68 Calculating Front Hub End-Play Austin Healey 32
aeronca65t front end maintenance Spridgets 5
bugedd Front end rebuilt help Spridgets 6
BlueMax Front End Completed Spridgets 23
bugedd About to rebuild front end...any tips? Spridgets 5
K TR2/3/3A Using Moss front end alignment gauge? Triumph 6
K TR2/3/3A Front end reassembly: trunnion spindles and wishbone bushes??? Triumph 10
BillyB62 TR2/3/3A TR3 front end shake Triumph 24
BillyB62 TR2/3/3A TR3 Ball joints & front end Triumph 5
D XJ6 series III front end rattle Jaguar 5
Tr3aguy Front end rebuild questions>? Triumph 6
S Finally got my front end back together Triumph 5
O TR2/3/3A TR3 front End Alignment Triumph 8
RickB Box Spridget fiberglass front end - front mounting Spridgets 5
K TR6 TR6 front end Triumph 2
Burrell22 TR4/4A Tr4 front end help. Triumph 10
B Bugeye front end Spridgets 0
H Should I drop the front end down a little? Austin Healey 25
M Advice on doing a front end rebuild via kit? Spridgets 4
hondo402000 TR6 TR6 front end alignment and wheel balancing Triumph 4
S TR2/3/3A tr3 front end alignment Triumph 9
MY66AH Front end question Spridgets 9
regularman Has anyone here put a bugeye front end on a square Spridgets 2
