Convertible Top Replacement
Rick O.
Cheers all. I'm about to install my new canvas top on the six tomorrow and wanted to get your input on the sequence. Rivet to deck angle, then the sides, then the header bow? The PO didn't glue the top to the underside of the header rail; is that necessary?
Thanks!
Dale
Welcome to the forum and thanks for posting. Can't help you with the top install, but am very interested, as I will no doubt be needing to do this very thing on my 7 in the not too distant future. I had decided to have a top installed by professionals, but they do charge for it of course and it does look like something a do it yourselfer could handle. I'm sure someone with first hand will jump in here and give us the straight skinny. Will be watching, keep us informed of your progress.
MDCanaday
From hard experience, start with a first quality top, If you get the bargain top(or allready have it)seek professional help, and be prepared for poor results. The cheaper the top the worse it will fit& look.
Once you have a first rate top your life will be much simpler, it will go on easily.Start at the backand mount it to the body as before, then work your way to the front.Replace any padding that is falling off the bows(it prevents chaffing)
I like to use seatbelt matterial for the top webs, it is stronger than heck, and lasts forever.
Use a small nail & lighter to snell the screw holes into the material. I have found 3M weatherstrip adhesive(black) to be the hot trick for doing the front bow.Use it as a contact adhesive(a little on both surfaces partialy dried)
Get the canvas fairly tight,and then set the bows onto the windshield & latch it down. This glue is messy but forgiving, Goo gone will get it off of places you didnt intend to have it.Strech the top as much as you can, then finish up the gluing around the front bow. lastly poprivet the strip that holds the weather seal to the top.
The tr7 top is even simpler, but it is best to have 2 people for the job in either case
Good luck!!
MD(mad dog)
Rick O.
Rick O.
Thanks for the help. I got the rear on the deck angle using stainless screws with lock nuts instead of rivets. The webbing was in fine shape so I simply riveted it back to the bows. I've got the top glued to the header bow and will wait for it to set awhile before riveting the channels back. Since I'm dealing with canvas, I may have to reposition it (it's hard to latch it down to see the fit right now). Looks great so far!
F Spitfire Replacement Of Spitfire Convertible Top Frame Seal Triumph 6
V Mustang convertible top replacement Other Cars 3
delisaj TR6 TR6 Replacement Convertible Top Triumph 23
Sarastro TR4/4A Convertible top installation problem Triumph 12
B TR6 TR6 convertible top frame Triumph 0
L Do you have a picture of these convertible top details? Spridgets 4
Popeye TR4/4A Attaching convertible top to bows - interior Triumph 2
Overdrive45 Convertible Top Cover Fit Austin Healey 6
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
T BJ7 Trim Recession (Convertible Top) Austin Healey 2
Celtic 77 MGB B-pillar repair kit for convertible top MG 1
N MGB Convertible Top Frames MG 7
HealeyRick BJ7/8 Convertible Top Issues Austin Healey 5
Neil Z For Sale MG TC NORS Convertible top and Side Curtains MG Classifieds 0
7 For Sale Stainless trim for Herald Convertible top. Triumph Classifieds 0
Sarastro TR4/4A Source for good convertible-top snaps Triumph 6
S For Sale Triumph TR-3 Convertible Top Bows Triumph Classifieds 1
RAC68 Source - Metal Clips for securing Convertible Top and/or Seat Covers Austin Healey 11
TulsaFred Convertible Top Fitting problems Spridgets 29
Griz Convertible top installation Austin Healey 6
P TR2/3/3A Convertible Top Frame Missing Hood stick advice needed. Triumph 4
Griz Convertible top installation Austin Healey 8
aero3113 100-4 Convertible Top Austin Healey 9
RAC68 Cuts in BJ8 Convertible Top Austin Healey 5
RAC68 Repair Traditional Cuts in BJ8 Convertible Top Austin Healey 18
exfed12825 For Sale Brand New Convertible Top MG Classifieds 0
Marvin Gruber BJ8 convertible top recommendation? Austin Healey 0
Griz Wood for convertible top Austin Healey 3
B Advice on Wooden Header and Side Trim Rails for a BJ7 Convertible Top Austin Healey 9
C BT7 Convertible top stowage Austin Healey 1
wkilleffer MGB 1974 MGB convertible top anchor bar size MG 4
P TR6 Small tear in convertible top Triumph 6
J Need pic of BN4 Convertible Top Clamp Austin Healey 4
B replacing BJ8 convertible top Austin Healey 5
G MGB mgb convertible top frame width MG 5
H TR4/4A 4A convertible top rebuilding sequence Triumph 8
J TR2/3/3A Convertible Top installation instructions Triumph 19
J TR2/3/3A Convertible Top Frame question for tR3 &3A Triumph 7
HealeyRick Convertible Top Hook Question Austin Healey 3
L BJ8 Convertible top Austin Healey 5
T black snaps for convertible top Triumph 11
johnrip Wedge Convertible Top Glue TR7 Triumph 2
M MGB Looking for convertible top boot cover for 71 MGB MG 1
B TR4/4A Tr4A convertible top Triumph 2
Gerard Good source for Convertible top? Spridgets 4
Spriteman65 Convertible top frames for sale Spridgets 4
AUSMHLY BJ7/BJ8 Convertible Top Austin Healey 34
Spriteman65 Convertible Top Help Spridgets 9
R Convertible top Installation Triumph 9
A Cleaning convertible top Triumph 7
