COIL OVER SHOCKS
bravenrace
Does anybody make coil over shocks for TVR's?
If not, how about adjustable shocks and performance springs?
Where can they be bought?
Thanks,
Jim
bravenrace
bravenrace
[ QUOTE ]
The original shocks are coil over. I think the OEM shocks on the 2500M were made by Armstrong. I doubt they are still available. Koni also made shocks for the M series. They may still be available. Spax may be another source.
Check with David Gerald
https://www.davidgeraldtvr.freeserve.co.uk/
Classic Motorworks
https://www.cmw-tvr.com/
[/ QUOTE ]
Sorry, I was talking about coil over shocks with adjustable spring perches.
jessebogan
Just for you info, the Konis are a really poor choice for 2500 ms. They are too short with the springs mounted at full extension, and have too short a stroke. The end result is bent and broken control arms. KONI usually hits home runs, but they really missed on TVRs.
bravenrace
bravenrace
That's good to know, since I am in general a big fan of Koni's, and have them on 3 of my cars. So what's a better choice, Spax?
TXCoyote
Can't speak for M's but I put a set of Gaz on my wedge and wow! Totally adjustable for ride height and damping while on the car. It was easy to dial them in. Also, no dealer in the US (XK's sells them for Jags only), so I had to order them direct from the factory. A little bit of hassle but they were half of retail as they sold them to me at dealer cost!
bravenrace
bravenrace
Thanks Ross! I had never heard of Gaz before but looked on their website and inquired about the coil over setup. They quoted me £300 + £90 shipping. What currency is that, Euro, UK pounds, or? Did yours come with the springs, or just the shocks?
swift6
That is in pounds sterling (UK Pounds). Figure about $600+$180 shipping according to their quote. Though that is some spendy shipping.
bravenrace
bravenrace
Yeah, the price of the coil overs doesn't seem bad if they are good, but the shipping looks a little high for what I would expect. I'll ask why and see what they say.
thanks for the information.
Deleted member 3577
My Bro is using GAZ on the Vixen.
He really like em.
I was the one that got them but, I can't remember where.
(Yes they have a US dist.)
I use QA1 (formerly Carrera)
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
wkilleffer MGB Coil resistance MG 4
Cokerair TR4/4A Fried Ignition Coil Triumph 18
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
F Hot Ignition Coil Austin Healey 6
V MGB Thackery (double coil spring) Washer Substitute? What else works? MG 9
timsgolf Coil Wiring Austin Healey 20
K TR2/3/3A Front coil springs? Triumph 2
R TR2/3/3A TR3A Coil/condenser problem Triumph 22
PAUL161 T-Series MGTF Xpeg Ignition Coil MG 22
longbridgehealey Coil terminals Spridgets 1
P TR3B Coil Issue? Triumph 7
A Wedge Won't fire without jumper from coil to battery Triumph 6
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
JPSmit female spade tab - coil Restoration & Tools 13
M TR4/4A Dedicated front coil over shock absorbers. Triumph 5
Lin Lucas coil question Austin Healey 8
K What to do for coil bracket on upgraded generator? Austin Healey 8
K TR2/3/3A Coil nuts? The SW and CB nuts on a Moss gold coil? Triumph 3
JPSmit Daughter's VW - coil pack? Other Cars 2
S Intermotor or Lucas Sport Coil ? Austin Healey 14
FlyingCat Spitfire Spark to Coil Triumph 23
S TR2/3/3A Front coil spring recommendation? Triumph 7
S TR4/4A Coil-over suspension upgrade Triumph 4
JPSmit Bosch Coil question Spridgets 14
KVH TR4/4A Front Coil Spring Packing Piece Triumph 12
2 TR2/3/3A Coil issues Triumph 31
D coil spring finish Austin Healey 5
M TR4/4A Front coil springs.....Rating & Length? Triumph 1
M TR4/4A Rear coil springs for TR4A Triumph 4
Marla TR4/4A Pertronic coil Triumph 12
M TR4/4A TR4 front coil springs Triumph 0
M TR2/3/3A Why is my coil so hot? Triumph 6
Marvin Gruber Big healey coil springs Austin Healey 7
M Starter field coil for BN1 Austin Healey 17
KVH TR4/4A Front Coil Spring Spacers Triumph 1
S TR2/3/3A Coil wiring Triumph 4
wingsandwheels MGB 1979 MGB coil w/ altered wiring MG 6
JimTR4 TR4/4A Coil - easily confused... Triumph 6
T TR2/3/3A coil mounting bolt oil leak Triumph 2
2wrench TR6 What's for dinner? Fried Coil??? Triumph 4
Griz Coil Wiring Austin Healey 4
2billydavies TR2/3/3A dead battery... until i disconnect the wire from coil to distributor Triumph 10
J TR2/3/3A TR3 coil spring height Triumph 4
Y MGB 1977 MGB Ignition Coil and Wiring. MG 7
2 TR2/3/3A TR2 Coil choices Triumph 5
6 Coil Wire Terminations Spridgets 4
TulsaFred Ignition / Ignition coil problem Spridgets 10
