Poly Bushings and ?? about alignment
Devin
Has anyone put Poly bushings on a Spitfire? Does it make the ride too harsh?
Also, my front tires on my Spitfire are wearing bad on the outer edges. How can I fix this before I replace my tires?
Thanks,
Devin
aeronca65t
They're fine is a street Spridget....Spitfire should be similar. The bushings you *don't* want to run on a street car are the solid alumimum (racing) ones.
A side benefit to the polys is: they are *much* easier to replace when they're worn. The stock rubber/steel bushings seem to get fused into place.
Rob DeScherer
Devin -- My daily driver is a 1987 BMW, which I have had quite a bit of front end work done to. My suggestion would be to do the bushings first, replace the tires, and have an alignment done immediately. The alignment shops typically like to do the set-up with new tires as it gives you a true measurement on the machine. This is what I have always been told, and so far it seems to have worked very well.
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
Got_All_4 General TR Has anyone used these poly bushings Triumph 6
mt10flyer TR2/3/3A poly bushings - upper wishbone Triumph 2
J Poly Lower A-Arm Bushings - One easy question as I am confused Austin Healey 1
DanLewis New pair of Lower A-Arms, spring pans, poly bushings = $100 [NFI] Spridgets 4
R General TR Poly bushings long term results Triumph 4
Scotsman Rubber vs Poly bushings Triumph 9
S ride difference oem vs poly bushings Triumph 4
hymodyne rubber, poly vs solid steering rack bushings Triumph 12
T Question on Moss red vs. black poly bushings Triumph 11
N Spitfire Poly bushings for Spitfire Triumph 11
T Recommendation/source for poly bushings Spridgets 2
T Correct grease / lube for Poly bushings Triumph 10
Jayrz Poly Bushings MG 10
K TR2/3/3A TR3 front sway Bar....Poly Bushings? Triumph 1
M Winter Storage with Poly Bushings Triumph 2
19_again Poly bushings MG 11
T TR2/3/3A Poly bushings for TR3 front suspension Triumph 7
S Poly vs. rubber inner wishbone bushings Spridgets 21
J Poly suspension bushings MG 7
Taz Poly bushings Spridgets 18
T Installing front anti-rollbar poly bushings Triumph 4
A Lube for poly bushings ?? Triumph 5
C Newbie looking for Poly Bushings for a C MG 5
71TR6 TR2/3/3A Poly Bushing installation Triumph 6
B Poly bushes Austin Healey 11
B TR6 Should the poly diff mounts be snug to the studs? Triumph 2
Popeye TR4/4A Steering bushing: replacing rubber with poly, do I snug to 1/8" gap or...? Triumph 3
steveg Poly bushing broke after 1 month use Austin Healey 2
J TR2/3/3A Suspension choices, rubber vs poly Triumph 8
T Anyone use Poly-armour or Cunifer brake lines? Triumph 2
L Here's what I did this weekend. [Poly Susp] Spridgets 12
T TR4/4A TR4a metal trans cover - re-use or replace w/ poly Triumph 8
T Recommendations on front suspension poly Spridgets 1
davidk Poly Steering Rack Mounts Triumph 4
Lin Poly bushing lubrication Austin Healey 4
B TR6 Help! TR6 Diff Mounts - poly or rubber? Triumph 12
3 Solid vs. poly vs. stock rack mounts. Triumph 10
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
Racer-X- Metalastik Lower wishbone bushings and upper fulcrum pin bushings Other British Cars 6
KVH General Tech HS6 Carburetor Bushings Triumph 10
S TR2/3/3A steel bushings for the lower Arms Triumph 10
Hangtown Healey King Pin Bushings Grease Groove Austin Healey 8
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 7
R TR6 Lower A-arm trunnion bushings Triumph 18
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
Upland SuperPro trunnion bushings Spridgets 0
R TR2/3/3A Upper Wishbone Bushings Triumph 12
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
