Lots of Questions!
bravenrace
But I'll try not to ask them all at once!
1. What is the max HP one can expect from a still somewhat streetable and naturally asperated 2.5l TR6 engine?
2. Does anyone make performance parts for my 2500M? Like springs/shocks, sway bars, headers, exhaust, brakes, and anything else they might need?
3. Where can I buy the mouldings that go around the windshield and rear window?
4. Where can I buy window crank handles?
5. Where can I buy bumpers? How about chrome bumpers?
6. Does anyone offer a full wiring harness for this car?
I guess that's enough for now. Did I say how much I love this car? I might even sell my mustang some day if I can find a Griffith.
Thanks in advance for the help.
Jim
This month's Classic Motorsports has a TR-6 Tuning guide... lots of nice hop-up suggestions in there.
Deleted member 3577
[ QUOTE ]
[/ QUOTE ]
Speaking of them....
I saw an add for some place called Classic Motor Works.
www.cmw-tvr.com (540)400-8310
I have never heard of them before.
(BTW.....I think you can get 150 outta yer Rumph-lump if you lock yourself in the garage until spring)
/ubbthreads/images/graemlins/grin.gif
jessebogan
Not to pat a vendor on the head, but, I have known Marshall Moore for many years, and can assure you he is both OK, and a serious TVR guy.Ask him questions, and you will get answers that are based on fact. Well worth the phone call.
G
You can get more than 150hp out of a TR6 lump on carbs and still have it tractable for the street. It's just a question of money!
Platinum
mehheh.
One more reason to endorse BCF as the real place to aim the enthusiasts with less "time in service."
Marshall, I'll be sendin' ya a PM.
Deleted member 3577
[ QUOTE ]
[/ QUOTE ]
Yep.....I have heard that merely shaving the head, shortening the lift rods & getting a mild cam will give you 150.
But w/ a new cam.....You need new followers (& cam bearings?)
And with more lift, you should probably get new (possibly stronger) springs.
Then you might be inclined to match port and clean up the head.
Then maybe some ARP head bolts.
Then maybe modify your carb shafts.
OK.....So since you have the bottom end apart, why not wedge the crank, get some Carrillos, JE pistons & an aluminum flywheel etc etc.......
Yep......You will probably be over 150 by the time yer done. /ubbthreads/images/graemlins/grin.gif
Welcome to the the nut house. /ubbthreads/images/graemlins/crazyeyes.gif
Then people will stop riding w/ you because they are frightened.
And you won't be interested in anything other than talking cars, so people will avoid you.
And you'll hang out here while the paint falls off your house & your cat runs away.
bravenrace
bravenrace
[ QUOTE ]
[/ QUOTE ]
So things won't change much? /ubbthreads/images/graemlins/grin.gif
The hard part is going to be getting the power I want without being tempted to do an engine swap. There seems to be easier ways of making power than sticking with the Triumph engine, but none of them will sound like it.
swift6
[ QUOTE ]
[/ QUOTE ]
The TVR is lighter than and has much better suspension than a TR6. So even a 150hp engine in a 2500M can make it a WHOLE lot of fun. And your absolutely right, nothing else will sound like it. /ubbthreads/images/graemlins/grin.gif
bobh
Unfortunately the Classic Motorsports TR6 article is rather shallow. They mentioned a performance exhaust in the introduction, but apparently did not install one. Also there was no mention of new pushrods which I would expect to be needed with .150 shaved from the head.
Several months ago they ran an article on a TVR 2500 where the owner claimed to have a "special head" (factory installed!) that pumped the TR6 engine up to 190 HP. I've been looking for that head all my life. So far nothing. I mentioned the TVR article to one of the CMS guys at The Mitty last spring. He said it was written by someone who was not one of their regular writers.
The TR6 article has some good general information, but seemed more like a forum to put in a plug for a shop and some parts suppliers.
swift6
[ QUOTE ]
[/ QUOTE ]
/ubbthreads/images/graemlins/iagree.gif Sort of disappointing... The new Webers weren't even really that impressive.
aztvr
[ QUOTE ]
[/ QUOTE ]
If you really want chrome bumpers, and if you can't find them from the usual vendors, there is another way, but it would be a hassle. The bumpers are the exact same shape as the ends of a Triumph 2000 Mk2 front bumper with the middle cut out. The mounting points on the back are the same also, so, I assume that this is what TVR made theirs from. I don't know if a TR 2000 Mk1 front bumper would work, since it had overriders. I don't know if the overriders are simply bolted over the bumper. You can occasionally find a front bumper on eBay.co.uk . There happens to be a TR 2000 Mk2 bumper listed right now. You would have to get one from someone that would cut it up and send you the two ends. Then you would have to cut it correctly, weld end caps on, and then get them chromed. Probably more than most people would want to go through. You'd need two TR 2000 front bumpers to make 4 TVR 2500 bumpers from. It's much easier to buy the repro rubber bumpers from Marshall !
-- Jim
bravenrace
bravenrace
Would a later model Triumph 2000 front bumper work? It has holes for a rubber strip that I would have to weld up, but looks otherwise the same as the earlier ones. Am I right?
mrtvr
I am looking into the possibility of having some chrome bumpers for the early M-series cars reproduced, but I have to have a decent set to use as templates. I won't know until I get into it how cost-effective it will be to do this. You can purchase a stainless steel set of bumpers in the UK for aboaut $2,400 US.
bravenrace
bravenrace
Thanks Marshall, although it's not worth that much to me. If I can make or buy a set reasonably I'll do it, otherwise I'll use rubber bumpers. I'm pretty good at metal fab and have contacts where I can get them plated for a very reasonable price, so if I can make my own, I think that would be the way to go. That said, if I don't do anything in the meantime, I'd consider buying them from you, but it would depend on the price obviously.
Also, don't forget to let me know when you get those window cranks in. I want to order some other stuff too, but am waiting until those come in to get it all at once.
BTW, let me know if you need any design work done on these. I could easily model these up and provide drawings for you.
I take it they aren't the same dimensions as the rubber bumpers?
mrtvr
The shipment containing the window cranks is due here just any day. I'll drop you a line when it arrives and we'll go from there.
D Looking to get into racing, lots of silly questions Racing 18
JPSmit Lots of questions #1 Throttle Spridgets 2
C MGB 1974 MGB ready for lots of work and help with questions:] MG 6
UltimateQuestion For Sale 1972 GT6Mk3 Project Car and lots of parts -Package Deal Triumph Classifieds 1
UltimateQuestion For Sale Price Reduced! 1972 GT6Mk3 Project Cars and lots of parts Triumph Classifieds 0
Ljohns For Sale Lots of Bugeye Parts - CHEAP Spridgets Classified 8
jackq For Sale Numerous MGs and lots of parts MG Classifieds 0
T For Sale TR4 / 4A Parts Lot [or lots of parts...!] Triumph Classifieds 0
UltimateQuestion GT6 Lots of Bondo Triumph 2
Tr3aguy For Sale Lots of TR3 spares Triumph Classifieds 14
JPSmit Lots of choice! Spridgets 0
A Spitfire I've been lax on posting - Summer Events Photo Albums - Lots of Pics Triumph 2
J Lots of numbers on the Crown and Pinon pumpkin! Austin Healey 3
aeronca65t Lots of Shelbys, etc [Canada] Other Cars 2
aeronca65t Lots of stuff out today Spotted 0
alanjohnturner TR4/4A lots of useful 4/4A data on here Triumph 5
B Looking for passenger side rear marker light module-and lots of fixes/help needed pls Spridgets 13
Kleykamp TR2/3/3A TR3 Starter nose broke off, ring gear,lots of ??? Triumph 6
aeronca65t VWs. Lots of them! Spotted 6
A LOTS of wheel play Triumph 12
JPSmit Lots of cars today Spotted 0
Kleykamp Lots of stuff on ebay!!! Triumph 9
AngliaGT Wow! Lots of Old Cars Spotted Today Spotted 0
toysrrus TR4/4A TR4 Engine & Lots of Parts on Ebay. Check it out! Triumph 15
D British Union Car Festival *lots of pics of rare* Spotted 31
RickB Lots involved when fitting Bugeye to RB car Spridgets 16
W Lots of opportunities here Spridgets 11
C Lots to see here... Racing 1
regularman lots of little cars here Spridgets 20
J TR2/3/3A tr3 notchy steering in parking lots Triumph 12
jlaird Lots of good stuff here Spridgets 1
aeronca65t Saw lots of Minis last weekend British Motor Corp 1
PATR8 Lots of lookers, no bidders Triumph 11
UmmYeahOk I got a new car!!! [LOTS OF PICS!!!] Triumph 39
jackq LOTS of Bugs Other Cars 6
C Driving lots; be sure to... Triumph 15
Woodie lots of comments re guage brightness, Spridgets 2
PATR8 the body work to be done on the 8, lots of ?s Triumph 15
aeronca65t NJMP-Thunderbolt Historics-Lots of Brit-cars Racing 23
Brosky Wedge Nice TR8 for sale, 39K miles, lots of work done Triumph 1
jlaird 1000 Spridgets and lots of Bugeyes. hehe Spridgets 15
StagByTriumph Lots of Lotus's in Colorado Lotus 0
StagByTriumph Lots of "Spridgets!" :lol: in Colorado Spridgets 0
StagByTriumph Lots of MG's in Colorado MG 0
YankeeTR TR2/3/3A Lots of TR3 stuff for sale... Triumph 10
YankeeTR Lots of MG pictures...HUH? Triumph 2
Team_Sprite Lots to tell, but brain dead Spridgets 11
PATR8 The Roadster Factory Autocross pics [lots of LBCs] Triumph 10
Bret Sharks need lots of "GREEN" water! Other Cars 5
T Lots to do, 74 B , need help [advice] MG 30
