Hi,
I think you are referring to a different Alan, DNK, but I'll jump in with a couple points anyway.
An aluminum radiator will provide better transfer of heat, i.e. better cooling. Original brass radiators are good, but aluminum is better. Assuming the rad is exactly the same design as the original, all the same capacities, etc., just the different materials, you should see approx. 15-20% better transfer of heat. Only pure copper would make for a better radiator in terms of heat transfer, but at considerably more expense and less durability.
Aluminum is also a lot lighter, probably about half the weight of the original brass. And, the far forward mounting location is a great place to reduce weight, if at all possible (both for improved front to rear balance, plus any weight reduction ahead of or behind the axle lines has a more dramatic effect than between the axle lines). Here, again, even if it were available a pure copper rad would be problem, since it would be quite a bit heavier than even the original brass rad.
One thing to watch for with aluminum rads is that they are welded, not glued/crimped/riveted toegether. The Ron Davis rad that Andy shows above looks to be well made.
Another consideration is the anti-freeze you use. Most available AF today is fully compatible with aluminum. But, some of the old stuff wasn't. Just read the fine print on the bottle, to be sure.
You also shouldn't run straight water in an aluminum rad for very long, but that's not a problem with most street cars that are using some sort of AF mixture anyway. The manufacturer of the rad can best advise what mixture, but I'd assume at least 25% aluminum-grade AF would be the minimum.
Another small consideration, any fittings that are used directly with the rad should be brass or aluminum, not stainless steel. I have been told S/S in direct contact with aluminum will cause problems. I'd sugggest using a thread sealer anyway, with any dissimilar metal, to prevent any possibility of metal-to-metal galling or corrosion.
I simply can't think of many downsides to an aluminum rad.
Most auto manufacturers use them now in modern cars, largely for the weight reduction and cost of materials (recycled soda cans!). However, many of today's cars rolling fresh off the production line use a plastic/aluminum assembly with all sorts of glue and crimped construction. That might be fine for a mass-produced part, but small volume production for special applications like our TRs calls for a higher level of work, IMHO.
I see in their latest catalog that TRF says they now have aluminum rads in stock for TR2/3/4/4A/250/5/6.
www.the-roadster-factory.com These look to be close to the original design and likely easy to fit, since they follow the same mounts, etc.
I've also seen discussed adapting a Corvette radiator, but haven't got the specifics.
Tony and Uncle Jack Drews' have a lot of info about using a relatibely inexpensive off-the-shelf radiator from Summit or Jeg's at
https://www.tonydrews.com/RadiatorPage.htm. Some fabrication is required and the installation shown is on a TR4, but certainly could be adapted to the other cars. In the past, they also offered a custom-made radiator, specific for TRs, but I don't see it listed right now.
