fordtrucks4ever
I have enough equipment in my possession to manually form up a one piece floorpan with all correct ribs, recess, edges, etc. Still working on a process to form the dropped footwells on each side. With 1 Bugeye, Sprite, and 2 Midgets to pull measurements from, may work out alright. I have made several early Bronco replacement floorpans with all ribs, bolt recesses that are idential to originals with exception to being thicker than stock. Should also be able to clone some of the straight frame sections and all flat panels, even with bent and stepped edges.(kick panels, front wheel wells, fill panels, etc) I dont think the rear wheel wells are within my reach, but can form repair pieces where usually rusted thru. Floorpan is large enuf to make awkward to work with, but if everything is close and outer edges measure correct, should work well. May need some measurements out there, if the rust pile patterns I have are missing too much to get repeative dimensions.
