overheating
dwnuk
1958 MGA. tuned, carbs rebuilt, timing fine, correct cap, installed shroud, added electric fan (when switched on doesn't seem to decrease temp) wetter water. took out therm. At 40-45 mph runs at 185-190. At 60 runs at 205 to 210. City stop and go runs 205-215 when stopped in traffic. The car is driven in a moderate climate usually between 75 and 85. When car is shut off after a run temp goes to 225 plus. Replaced radiator 3 years ago. Looking for any suggestions.
thanks
tony barnhill
Great Pumpkin - R.I.P
When was last time engine itself was back flushed?
Keoke
Dwnuk, Sounds like the added electric fan may actually be blocking the incoming cooling air.You did not say whether it is a puller or a pusher fan installation.---Keoke
Keoke
HI, Mounting the fan in front of the radiator constitutes a pusher configuration.If the fan has insufficient power to force a high volume of air through the radiator it will cause heating at speed by blocking the incoming cooling air.---Fwiw---Keoke
piman
Hello Dwnuk,
thermostat if you haven't already checked it, water pump effectiveness, which can be affected by old hoses but unlikely if you renewed the radiator. Correct specification radiator?
An electric fan, indeed any fan is not generally required when driving on the open road, forward motion gives more air than any fan.
Certainly circulation around the engine block is another valid area to check.
Alec
Rob_Edwards
How's your ignition curve? Retarded timing will cause excess heat, and if your springs are worn (i.e. timing advance comes in too early) and you set the timing at idle, you timing will be retarded at speed.
Never run without a thermostat. You might consider fitting a thermostat in conjunction with a blanking sleeve:
https://mgaguru.com/mgtech/cooling/cool_103.htm
There are other interesting pages on that site -- poke around a little! ;-)
BTW -- I don't like to see my engine run less than about 200ºF.....
HTH!
jsneddon
have you checked the actual coolant temp with a known good thermometer? Gauges have been known to be incorrect.
tony barnhill
The added fan - was that an aftermarket in addition to the MG fans or are you talking about them? If an addition, it'll do nothing except cause problems....the cooling system, when set up properly, doesn't need additional fans....problem now is getting everything set up.
JeffS
I second the comment about adding a thermostat with a blanking sleeve! That alone could cure your overheating! You need to slow the water own as it goes though the radiator or the radiator can't absorb heat fast enough for it to be removed!
Jeff
Deleted member 3577
[ QUOTE ]
[/ QUOTE ]
Really???......Mine doesn't like to idle well at that temp.
(And it makes me nervous) /ubbthreads/images/graemlins/eek.gif
A perhaps interesting footnote.....
I can almost tell what the ambient temperature is by looking at my gage and subtracting 100.
(for temps 65F and above) /ubbthreads/images/graemlins/yesnod.gif
jlaird
Think the good book says like 180-190 and that's hot enough thanks.
Rob_Edwards
Depends on which book you're referring to. You want to run the engine as hot as is practicable. Running it too cool makes it wear quicker, make less power, and burn more fuel. Peter Burgess (MGB tuning guru) in his book "How to Power Tune the MGB 4-Cylinder Engine" says "The ideal 'stat is 88 degrees Celcius (190F) ." The late, great Smokey Yunick says:
[ QUOTE ]
" It is easy to see how overheating can be a problem, but I think some racers overlook the fact that it is possible to 'overcool' the engine. Some guys go to great lengths to keep the engine temperature down to 180 degrees. And, though the engine doesn't overheat, they don't realize that they're putting energy (heat) into the cooling system that could be used to produce power at the crankshaft.
Running the engine at 180 degrees will drop the overall horsepower by 2%-3%. For max power the cooling temp should be at least 200 degrees...."
[/ QUOTE ]
With a 50/50 mix of coolant and water and a 16 psi radiator cap, you won't overheat until the other side of 265ºF....
Deleted member 3577
[ QUOTE ]
[/ QUOTE ]
Coincidently.....You can increase hp 2-3% by taking the fan off. /ubbthreads/images/graemlins/grin.gif
Keoke
/ubbthreads/images/graemlins/iagree.gif However Jeff, the blanking sleeve really does not slow the flow of water down in the cooling system.What it does is block off the bypass port so that all the water in the system is routed through the radiator for cooling.Lacking this sleeve, a portion of the coolant will be passed thru the pypass port and never gets processed correctly leading to higher runing temperatures.---Keoke
Jay_Nickell
Off the wall comment. These electrical fans are usually set up as pullers, that is to mount it between the radiator and the engine. To use the fan as a pusher, you reverse the fan and reverse the pos/neg wires. Are you sure both were done when you fan was mounted?
rulle7
Surely one 'pushes' from in front of the radiator and 'pulls' from behind it ... no?
Keoke
[ QUOTE ]
[/ QUOTE ]
-----Wakatai yo!---Keoke- /ubbthreads/images/graemlins/grin.gif
rulle7
Writer2022 GT6 Overheating after fitting air filters Triumph 4
S MGB-GT 1972 GBT overheating MG 10
G 79 Midget 1500 overheating Spridgets 2
Bob_Spidell Running hot/Overheating Austin Healey 44
M Coolant 'overflow' when not overheating.... what's up? Spridgets 34
W TR2/3/3A Overheating Bad Triumph 12
S Best Ethylene Glycol/Water Ratio to avoid overheating? Why? Informal Survey. Austin Healey 27
R TR2/3/3A Overheating 1957 TR-3 Triumph 13
R TR2/3/3A Overheating Triumph 0
F Overheating BJ8 Austin Healey 0
F Overheating BJ8 Austin Healey 20
C Healey BN6 water pump and overheating problems Austin Healey 11
R Honda Del Sol overheating Other Cars 6
B TR2/3/3A Overheating Problem Triumph 45
P MGB MGB overheating with a squealing noise from the engine MG 11
H oil cooler and overheating Austin Healey 12
J Spitfire overheating Triumph 2
mgedit TR2/3/3A Still Overheating ... Triumph 22
jlaird Overheating probs Spridgets 6
gubba TR4/4A TR4A overheating issue Triumph 4
P Overheating after shut down & recommendation on thermostat Austin Healey 3
M TR2/3/3A Overheating incident Triumph 18
Lotuswins BJ8 Overheating - Need dimension Austin Healey 43
DanLewis Overheating problem solved, or ... did you disconnect your vacuum advance? Spridgets 4
Norman Tri carb - overheating issue ???? Austin Healey 10
TR4nut TR2/3/3A Any thoughts on TR3A overheating struggle? Triumph 19
M Rough Running 99 XJ8 after Overheating Jaguar 42
histerical Overheating Spridgets 0
I Bugeye overheating - help please Spridgets 41
brgrmyster TR6 TR6 Overheating after being shut down Triumph 36
boeingpilot What is causing my overheating issue? Triumph 14
D TR2/3/3A Timing TR3A and Overheating Triumph 27
D 79 Midge overheating problem Spridgets 10
K TR2/3/3A Overheating TR3 - a few questions Triumph 34
regularman Pretty sure my overheating problems are gone. Spridgets 9
Monark192 Midget Overheating Problem - Continued Spridgets 10
Monark192 Midget Overheating Problem Spridgets 13
P Overheating Austin Healey 17
J Diagnostic [Overheating?] Question Austin Healey 7
KVH TR4/4A OverHeating TR4A Triumph 7
C TR2/3/3A overheating tr-3 Triumph 50
regularman Still with the overheating problem. Spridgets 45
T overheating Austin Healey 14
Webb TR6 Overheating TR6 Triumph 13
A T-Series Overheating light switch MG 5
kcbugeye1275 Overheating my story Spridgets 1
regularman Still trying to figure this overheating thing out. Spridgets 35
Webb TR6 Overheating TR6 Triumph 6
J '65 Sprite Overheating Spridgets 16
S overheating Spridgets 3
