Aligning crossbar after fan belt change - argh!
tdskip
So I replaced the fan belt and installed a new water pump (thanks for the coaching on gasket sealer on my other post).
Per the manual I had to loosen the crossbar to change the belt and of course now the cross bar isn't lining up.
Anything to try except fiddling with with until it fits?
jerrybny
Re: Aligning crossbar after fan belt change - argh
What kind of car is it. I changed the water pump and fan felt on my 73 TR6 and didn't have to loosen the crossbar. /ubbthreads/images/graemlins/cheers.gif
T
tdskip
Hi Jerry, she is a 1971 stock TR6.
The belt wouldn't fit with the crossbar in place, so after some 'Googling' and checking the manuals I removed the bolt on one side of cross bars and gently jacked up one side of the car enough to let the old belt off and new one on.
R_Lyle
Member
When you go to remove/install the cross member on the TR6 you have jack the car up at the center of frame. Looking at the front of the car slide the jack directly under the center. One piece of the frame runs across the very front of the car. Lift the car up so that the weight of the car rests on the jack and the wheels are slightly off the ground. This will cause the frame to bend ever so slightly so that the cross member can be manuvered to align the holes. Bolt the cross member and then lower the car.
G
And, to carry that a bit further, you shouldn't have to do body work on the road to change a simple fan belt. If the belt doesn't fit between the cross bar and the engine, then the engine is too far forward. That is simple enough to remedy by loosening the two front engine mounts and the rear tranny mount and shove the whole thing back a hair till you can get a belt in there. There is enough play in both mounts and of course the drive shaft is splined so it will slide back. Your engine is too close to the crossbar. Best fix it before you throw a belt on the road and have to do body work to do a simple replacement.
Bill
swift6
If motor mounts are worn and sagged it can also cause problems with installing fan belts. But that is usally interference with the steering rack.
I'll get me coat. /ubbthreads/images/graemlins/grin.gif
T
tdskip
I don't think the mounts are sagged, but sounds like they are definitely a bit too far forward.
Hey Shawn - I like the color of your TR6. You have it listed as Auqa Marine Frost. Do you have the paint code?
Visitors most welcome, but it's been hot here as well...
swift6
Thank you so much. /ubbthreads/images/graemlins/savewave.gif
Unfortunately, the code has been misplaced. Though it is a Ford color. Although my particular hue is a blue variant of the Ford color.
A Aligning New half front wing, outer sil and rear wing Austin Healey 5
TR6oldtimer TR6 TR6 soft top frame not aligning with windows Triumph 1
Lukens TR2/3/3A Aligning steering wheel on TR3A Triumph 3
LearJeff Aligning Cam shaft and Crank...Suggestions? Triumph 19
T TR2/3/3A TR3 crossbar - body color or always black? Triumph 4
mctriumph TR2/3/3A Ultimate fan conversion Triumph 10
F Revotec Fan Austin Healey 2
S Installing a Radiator Fan Austin Healey 9
K TR2/3/3A " do not remove the fan as it is essential for establishing crankshaft balance" Triumph 9
jfarris For Sale TR3 Stock Fan used (1956) Triumph Classifieds 0
jfarris For Sale TR6 Yellow Fan - new Triumph Classifieds 0
tr6nitjulius General TR Fan Belt Replacement '72 TR6 Triumph 1
RJS TR4/4A Radiator Fan Shround Triumph 3
KVH General Tech Fan Not Backward — Balancers Triumph 5
A Spitfire Install fan Triumph 1
J TR6 TR6 Hayden Pusher Fan Wiring Triumph 2
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
R For Sale TR6 COOLING FAN / ADAPTERS Triumph Classifieds 0
R Cooling Fan Color Austin Healey 6
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
R Spitfire Electric Fan Triumph 2
R six bladed fan - bugeye Spridgets 2
Dnickels Spitfire Generator fan rubbing/scraping Triumph 3
G TR4/4A Radiator Fan and plates spanning bolts Triumph 6
Lin Fan belt for 1275 with alternator Spridgets 4
Tr3aguy TR2/3/3A Tropical Fan Triumph 19
G Thermo Fan Sensor Austin Healey 5
R TR6 fan shroud replacement Triumph 5
J BJ8 Radiator Fan Austin Healey 12
6TTR3A Wanted GT6 MK one engine fan Triumph Classifieds 0
longbridgehealey Electric Fan vs. Texas Cooler Austin Healey 21
C Wanted WANTED Heater fan motor and housing for 1964 MK3 Sprite Spridgets Classified 2
D Spitfire Electric fan Triumph 3
Zitch For Sale 8 Blade yellow Fan for triumph Triumph Classifieds 2
HealeyPassion Aftermarket heater/defroster with 3 speed fan Austin Healey 15
M TR6 Rimmer Bros. Electric Fan Conversion Triumph 0
M TR6 Dowel Pins, Pulley Adaptor, Revotec Electric Fan Kit Triumph 1
thibault 6 Blade cooling fan for 64 BJ8, advice? Austin Healey 25
T BJ8 Fan Belt Change Austin Healey 7
B Wanted FOUND. TR10 Fan mount Bushings Triumph Classifieds 3
S Heater and fan control replacement - any advice? Austin Healey 9
B Fan Blade Failure Austin Healey 6
D Fan Blade Austin Healey 11
B Revotec fan kit Austin Healey 4
B TR6 TR6 Fan Belt Triumph 4
K TR2/3/3A Volvo 122 radiator fan on a TR3? Triumph 3
S Fan blade bolts - torque setting and thread-locker? Austin Healey 4
FlyingCat Spitfire Electric Radiator Fan Triumph 10
N Bumper bracket and fan shroud color Austin Healey 5
FlyingCat Spitfire Radiator and fan Triumph 5
