Painting wheels -powder coat vs conventional paint
ichthos
Hello All,
I am getting ready to paint the wheels on my TR6. I figure now is a good time since the tires are off. I have heard how powder paint is tougher than conventional paint, but that it can chip easier. My other options is to use expoxy primer followed by silver paint. I am going to sand blast them with a fine grit first in either case first. Any suggestions from those that have painted their wheels on what sems to hold up the best?
Thanks, Kevin
DNK
Re: Painting wheels -powder coat vs conventional p
Kevin , had mine PC'ed. Looks real nice. Also before I did this I took all five to a local wheel guy and he straighten and rebalanced all except the now spare which was in fairly bad shape. will work for a spare but not for long high speed running.
don
Bugeye58
Kevin, I much prefer powder coat over paint. It's a lot more durable, and will fill small imperfections in the wheel that paint won't.
Jeff
G
If you powder coat the wheels, make certain that whoever does your tire mounting is someone with the proper tools to mount tires on mags. Meaning, they will treat the powder-coated steel wheel with the same care that you should treat cast wheels. Usually they will have Teflon-coated tools or the likes. Jambing a tire on a coated wheel with a prybar will very probably chip the powder coating, much to your chagrin.
Jeff, what in the world are we doing up at such an ungodly hour?!
Bill
Bugeye58
Bill, I guess it's just force of habit! Now I suppose I'll have to go out for breakfast, and see if I can get something productive done today.
Happy 4th.
Jeff
G
Same.
Bill
Harry_Ward
I have a friend who builds wheels and he told me that powder coat is best. Of course that depends on who is performing the work like anything else.
Harry, CT
Time to mow the lawn before the next big thunderstorm washes the day away. 11.44 inches in June!
tomshobby
I have been doing some research on powder coatings over the last couple years for a product my company is bringing to market.
I have found a lot of information about product specifications and color choices from TIGER Drylac Powder Coatings
There is good information on type of use and durability of product choices.
I
ichthos
One of my biggest concerns was putting the tires back on the wheels. Obviously I don't want the wheels chipped or scratched during this process. I also don't want them to scrach when I put the rims back on. In any case, I think I will go ahead and powdercoat them and then take them to a Les Schwab by me and let them know my concerns. Thanks for all the information.
Kevin
Alan_Myers
Considering the cost and fancy "bling" of many wheels today, most tire installers can handle it and powder coating is actually less likely to be damaged than most paints (PC is considered about 5X more durable... but I don't know what they are comparing to).
Other considerations... don't bother sanding anything prior to powder coating... part of the process is media blasting the wheels to prepare the surface. Any sanding you do is a waste of time.
You can often get powder coating done a lot cheaper at an industrial coater, rather than an automotive specialist. *However*, if you use an industrial company (might coat garden furniture or computer cabinets or who knows what), be very sure to specify a UV-safe coating is used and to clarify how the coating will look in color and gloss. Some industrial PC is "interior" grade (like interior paints) and won't hold up very long outdoors, exposed to UV light.
Yes, PC can help fill small imperfections... it flows a little when it's cured in an over. Epoxy paints are pretty darned good, too, might be the choice if you were looking for a thinner coating or color unavailable in powdercoat.
mailbox
I have heard of a new powder coating that uses ceramics. Suppose to be a lot tougher than regular powder coating. Might be worth a look see. /ubbthreads/images/graemlins/grin.gif
G
That is the best way to finish a wire wheel. Just make sure that you get a UV resistant coating, not an industrial coating. Wire wheel specialist recommend powder coating.
Bill
drooartz General Tech Painting my Rostyle wheels MG 7
drooartz Painting wheels? Restoration & Tools 6
R Painting Rostyle Wheels? Spridgets 11
Nunyas Painting Wheels Restoration & Tools 14
G Painting Rostyle Wheels Spridgets 9
JPeter Painting Wire Wheels Triumph 4
N Wire Wheels [ Mediablasting & Painting ] Austin Healey 4
7 Painting Rostyle wheels?? MG 14
D Cleaning and painting old wheels? Austin Healey 8
timsgolf Center Dash Switch Plate Painting Austin Healey 5
LAW75 Painting the Grille Surround Austin Healey 12
J Shroud Painting ["Finally done with these"] Austin Healey 3
GeorgeC Painting the Battery Austin Healey 0
J Painting Underside of Shrouds Austin Healey 13
J Painting a Frame and Substructure Austin Healey 12
Jim_Gruber Bugsy IV - Painting, Cutting, Buffing is done Spridgets 20
S TR2/3/3A painting the floors of my tr3. Triumph 2
S Painting a BJ8 Radiator - any advice? Austin Healey 17
J TR2/3/3A Painting floor pans Triumph 2
S TR2/3/3A Painting the body tub exposed parts again Triumph 19
J TR2/3/3A Painting Triumph 11
S TR2/3/3A how to position pieces when painting Triumph 7
T TR4/4A Painting front hubs Triumph 2
S TR2/3/3A tr3 painting --spraying: vertical, horizontal ect... Triumph 8
69MGC T-Series MGTA Digital Painting 2 MG 0
B TR6 TR6 Painting/Restoration Triumph 2
69MGC MGC MGC Digital Painting MG 0
69MGC AH 3000 Digital Painting Austin Healey 0
69MGC Newest Digital Painting Aston Martin Other British Cars 0
B TR6 Painting a '74 TR6 Triumph 1
H Healey 100 Painting Austin Healey 5
KVH General Tech Questions About Painting Triumph 6
kennypinkerton General MG Rostyles. Painting question. MG 2
KVH General TR Painting the Engine Compartment with Spray Can Triumph 3
S TR2/3/3A painting the body tub “inside” Triumph 31
B Painting the Car - Corner Bead Advice Austin Healey 21
S TR2/3/3A I hate painting Triumph 8
J Final painting detail questions Austin Healey 16
dcoplan Suggestions for painting letters on dash knobs? Spridgets 6
Bob Claffie MGB Painting rubber bumpers MG 4
T TR6 Painting the car with the fenders on Triumph 7
B Painting underside of front and rear shroud - Original prep and color? Austin Healey 3
B Final painting of all body panels - with panels on or off car? Pros and Cons? Austin Healey 7
madhouse Painting Wheel Wells of my 100-6 Austin Healey 8
R TR4/4A Painting engine in the car Triumph 7
Lbp TR2/3/3A Painting Help Needed for Restored Steering Wheel Triumph 5
J Painting transmission Austin Healey 7
glemon New Painting Method Restoration & Tools 2
J Painting the car Austin Healey 8
Jim_Gruber Painting inside a BE Boot Spridgets 8
