TR6 TR6 FRONT SHOCKS?
kodanja
In your opion, what are the best front shocks for a 71 TR6? /ubbthreads/images/graemlins/grouphug.gif
G
I put KYB's on the front of mine. They are the best cheap performance shock on the market IMO, I've run them on all my Mustangs and such, they perform far better than their price would indicate. They aren't quite as good as something like Koni, if you've got money to spend then something like that might be a better option. But if you're on a budget or just don't want to spend alot KYB's are a good choice. Also, you won't find a part number for KYB's for a TR6, you have to call them and tell them thats what it's for. The shock you get will actually be for a Mustang II, and you'll need to trim the bottom mount bolt tube down a bit since the Mustang uses a longer bolt. If you're interested let me know and I can dig up my receipt with the part #.
G
When you order front shocks from TRF, what you will get will be adequate shocks made in India. They're ok I guess. I now have Koni's on the front and Spax on the rear.
Bill
vettedog72
I would appreciate your effort in looking up that KYB number. I got the tube shocks on the back but need to replace the front shocks as they are the OE with 82k miles and 32 years of service.
kodanja
kodanja
Scott
if you could find that part # for the KYB's, that would be great!
do the Koni's need to be modified also?
thanks so much!
Bill
LastDeadLast
Bill,
I have Koni's also they installed with no modifications. I'm using Spax in the rear. I bought mine from Tire Rack for a huge discount from the big three parts houses. I'll try to look up the part number for you.
LastDeadLast
If you're interested in koni, give Tire Rack a call. Ask for Koni part number: 80-1784. They won't list our cars, they're too old, but they can get the shocks.
G
I will look up the KYB part number when I get home later tonight, it's somewhere in the Manhattan phone book sized folder of receipts I've got for this car. I contacted KYB directly to get the specs on the shock size and the part number, but order them from PST.
Performance Suspension Technology
Makes sense the Konis are drop in, since they are made specifically for the TR6. As I said, the KYB's are made for a Mustang II and require a slight bit of mounting point alteration to fit. Just measure the length of the bottom bolt tube on your existing shock and trim each side of the new one with a hacksaw or cutoff wheel to match.
kodanja
kodanja
great info thanx!
ballpark figure for the Koni's and for the KYB's??
ALLAN
My KYB also fit with no modification, they came from British Parts Northwest, Im sure it is the same as KYB from other British suppliers, sorry cant get to the number. I am going to change to spax shocks I have found the KYBs too stiff. My KYBs will be for sale when I get them off within the next month, they have 500 miles on them (like new). They sell new at BPNW for $42, will sell both for $50+shipp.
kodanja
kodanja
are the Spax that much better?
what would be the difference between Spax and Koni's?
ALLAN
The Spax have a variable adjustment and you can dial them in to your prefrence and they have always been known to be a very good shock but they cost twice as much. The KYBs are a good shock but non adjustable.
trfourtune
koni's have the best internals and are adjustable but you have to take them out to adjust.spax are externally adjustable but (as i have heard) not quite as good as koni's. koni's last longer. there are also avo shocks from britain. these are externally adjustable and used by revington tr. said to be better than spax and can order direct from avo for about 45 british pounds.
rob
Alan_Myers
Hi,
Koni shocks are also rebuildable, altgough the cost isn't a great deal less than buying new.
kodanja
kodanja
I think im going to go with the Koni's
Ill have to order them.
who is the best distibutor for this item?
G
Well, I found my receipt, I got the KYB's from PST as I thought. Unbelievable, the stupid receipt does not list the part number, sorry. However, I checked their website and the part number for a gas-a-just front shock for a 74-78 Mustang II is KG4511, which sounds familiar to me. Best to call KYB directly yourself and confirm that that shock # will also fit a TR6. Like I said, they knew what I was talking about when I asked so they should be able to confirm it. Funny, this is also the same shock as for a Pinto.
KYB catalog
Allan, you say you ordered KYB's from BPNW and they fit without modification, you are talking about rear shocks right? Like for the tube shock conversion? Thats the only KYB they list on their site for a TR6, as part of the conversion kit. That fit because it's some other model shock that happens to work with the conversion, it's not made specifically for the TR6.
ALLAN
I have the rear conversion with KYB and the front KYB both from British Parts Northwest. Their Front KYBs are listed as heavy duty gas shock--they are the KYBs-if you enlarge the picture you can see the KYB sticker.--------Considering the price for Konis I think they are an overkill for most, unless you are doing alot of racing, but they are the best.
swift6
I've also got KYB's on all four corners. When I installed the fronts there were no modifications needed. Bolted right in. Bought them through BPNW as well. I really like the performance of the KYB's. Of course I am also using them with shorter springs that have a higher rate as well.
D TR6 1976 TR6 Front Brakes & Shocks Triumph 3
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
M Wanted WTB Late model TR6 Front Brake Caliper Brackets Triumph Classifieds 0
R Wanted 75/76 TR6 front licence holder Triumph Classifieds 1
J Wanted TR6 Chrome Front License Plate Holder Triumph Classifieds 0
A TR6 '73 tr6 passenger front brake dragging Triumph 2
G TR2/3/3A TR6 Front Suspension A-Arms on a TR3A? Triumph 5
M TR6 TR6 Gas Leak From Front Carb Triumph 5
hondo402000 TR6 TR6 Heavy duty front Stub axles Triumph 12
K TR6 TR6 front end Triumph 2
W TR6 TR6 front wheels Triumph 7
hondo402000 TR6 TR6 front end alignment and wheel balancing Triumph 4
Coyote1 TR6 74 TR6 Front Turn Signal Alternative Triumph 9
davidk TR6 Information for front crank seal - TR6 Triumph 11
hondo402000 TR6 TR6 Front Wiring harness on its way Triumph 0
B TR6 TR6 Front Oil Seal Sleeve Triumph 3
R TR6 Front TR6 Suspension Question... Triumph 7
charlie74 TR6 TR6 front bearing cap Triumph 4
T TR6 TR6 front wheel bearing ? Triumph 5
L TR6 TR6 Front Suspension Resto Project Part One Triumph 11
N TR6 How to check TR6 front wheel bearings Triumph 1
hondo402000 TR6 TR6 Lower front valance section replacement Triumph 2
I TR6 TR6 - how to pack front wheel bearings? Triumph 8
I TR6 This can't be good. TR6 front suspension rebuild Triumph 25
R TR6 Late TR6 Front Fender Removal Triumph 5
I TR6 TR6 front shock help Triumph 2
I TR6 Tinster's TR6 front suspension restoration part 1? Triumph 7
I TR6 TR6 front suspension rebuild suggestions Triumph 19
T TR6 Question on TR6 lower front inner wishbone bracket Triumph 1
hondo402000 TR6 TR6 rebuilt the Front Calipers, second time Triumph 2
hondo402000 TR6 Front Brake issues TR6 Triumph 2
T TR6 Tr6 front suspension ? & downside of Cali cars Triumph 1
A TR6 TR6 Front lower wishbone mount [rear] broken Triumph 1
N TR6 TR6 Front Spring Height?? Triumph 3
T TR6 TR6 front suspension re-bushing question Triumph 18
T TR6 tr6 front wheel bearings Triumph 15
jjbunn TR6 TR6 Front Hood Seal Triumph 6
zekjet TR6 Longer Front Wheel Studs for a TR6? Triumph 3
N TR6 Clip wires on front brakes for TR6 Triumph 9
SCguy TR6 TR6 front sway bar on a TR4 Triumph 1
T TR6 Decided to repair TR6 front valance rather than... Triumph 4
C TR6 Proper way to adjust front hubs, TR6? Triumph 13
hondo402000 TR6 TR6 front glass question Triumph 4
2wrench TR6 Pictures of TR6 dash refinished front + back Triumph 22
A TR6 Motor mount position--front/back?? TR6 Triumph 2
E TR6 TR6 front engine seal leak Triumph 11
R TR6 Lowering TR6 front end Triumph 15
E TR6 TR6 Front Suspension... Is there a trick? Triumph 8
R TR6 TR6 front brakes Jack Drew Triumph 13
