Howdy all. In the latest saga of me vs. my brakes, I replaced my servo and master cylinder this weekend. I also rebuilt the rear cylinders and replaced the shoes. The front brakes bled out fine using Speed Bleed valves. The rear brakes, however, have been a nightmare. I've run at least three full containers of brake fluid through each of the rear brakes, and I keep getting air bubbles. It will be fine for a while, and I'll feel peddle pressure build, and then all of a sudden I'll get a lot bubbles. I let the car sit for a day, then tried again, same result, and only at the rear. I don't see any fluid leaks anywhere, so I'm not sure where air could be getting in. I suspect it's either the rear cylinders (which were heavily corroded). Could it be the new master cylinder? I have a new spare (forgot I ordered one, then ordered again, and both arrived within a day of each other).
Any and all advice would be helpful. The frustrating thing is that it's a *lot* of air that comes through all of a sudden. I've also been *very* careful to keep the portion of the reservoir that feeds the rear brakes (and front, for that matter) full.
Thanks!
Thanks!
