Spitfire repair soft top on Spitfire
deegeeguy
I have a bad feeling about this but ...
The convertible top on my 77 spit has developed major cracks in the side windows (the large rear one is still fine)
Is there a home-built solution to replacing these quarter panels. The actual plastic is ok but the seams where they joined to the fabric have let go.
I know I'm into replacing the top in a few years anyway (there's some wear on the front leading edge) but is that time sooner than later?
I did run some searches in these forums and on the Net in general but didn't come up with a diy solution.
Advice appreciated.
Doug
G
Doug,'
For what it's worth, I have seen an upholstery shop actually repair soft top vinyl windows by heat-sealing in new vinyl. The end result was quite impressive, and very cheap. Now, that said, the trick for you would be to find someone where you are to do the same. I know it is doable. Good luck.
Bill
deegeeguy
Bill - thanks for the thought. I've actually just come in from the garage where I had a really good look at the problem from the perspective of some dynamite coffee and the fact that the top was only going to last another year or 2 at the outside anyway. I removed one of the windows entirely - it separated from the fabric extremely easily - which tells me the vinyl was further along in degradation than I thought. Given the fabric is only good for another few years, (a few smaller tears on close inspection) I think I can epoxy a layer of vinyl on the inside of the top and it should be acceptable looking if not show quality. And as I rarely drive it with the top up - even in really cold weather (can you say "look at that idiot in the sports car") - it should suffice for the odd rain it finds itself in.
I will however take a look at heat sealing and see what kind of technology that will require - and if one of my buddies has anything that might do the trick easier than epoxy.
Thanks for the thought on heat-sealing. Appreciate it.
Doug
myspitfire
My thoughts here is SAVE THE PLASTIC you removed & use as templates for a similar plastic purchased at an auto upholstery shop & super glue inplace yourself.It would be a temporary fix until a perminate comes along.Thats whay i'd do......Those side window templates could be valuable. Ken
af3683 TR2/3/3A How to Repair Small Holes in TR-3 Soft Top Triumph 6
M Soft top repair MG 2
RobSelina Soft Top Repair Spridgets 4
KLUTZ Found the Soft Spots....Repair ideas? MG 14
B TR6 Thrust face repair Triumph 1
Hangtown Healey Cibie Z Beam Headlight Repair Austin Healey 0
C TR2/3/3A Frame repair and value Triumph 2
K TR2/3/3A head gasket repair wire Randall Triumph 1
B Windscreen Motor Repair Restoration & Tools 6
O Jaguar rear window trim repair Jaguar 1
G Smith's temp gauge repair Restoration & Tools 4
O TR2/3/3A Good Repair Shop In New Hamphire Triumph 2
Celtic 77 MGB B-pillar repair kit for convertible top MG 1
H TR4/4A Fender/Wing repair how to do Triumph 5
H TR4/4A Advise asked for front repair Triumph 1
Bayless How to repair broken vent window studs? Spridgets 1
AngliaGT MGB-GT Gauge Repair Recommendations? MG 4
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
D TR2/3/3A TR3 repair in Cincinnati Triumph 0
S TR2/3/3A Frame repair. Triumph 47
BritBite Transmission Repair Austin Healey 8
volunteer Wanted: Brake Master Cyl. Repair Kit for Daimler DS420 Other British Cars 18
M Capillary Tube repair Spridgets 4
D General TR Frame repair - recommendations for NJ area Triumph 3
S TR2/3/3A wire repair Triumph 7
SteveTheBrewer Spitfire More rust repair Triumph 1
M BJ8 Inner Body Panel Repair Austin Healey 2
Editor_Reid Leather Seat Repair Austin Healey 5
AngliaGT At a Local Repair Shop Spotted 1
humanoid For Sale - Haynes Trimumph TR7 (1975-1981) Automotive Repair Manual Triumph Classifieds 0
M TR2/3/3A Speedy Sleeve Repair Sleeves for Rear Axle Pinion and Half Shafts Triumph 1
J Steering Wheel Repair Austin Healey 32
F TR2/3/3A starting scuttle repair Triumph 27
L TR6 Rear Brakes Shoe Repair and Install Triumph 2
F TR2/3/3A Dash repair Triumph 7
D Steering Wheel Repair Austin Healey 2
Michael Oritt Trafficator repair and refinish recommendations Austin Healey 6
71TR6 TR2/3/3A Right Front Suspension Damage Repair? Triumph 50
T Speedometer Repair Problem Austin Healey 5
J TR2/3/3A TR3A gas tank repair Triumph 4
Upland Tonneau cover repair Spridgets 2
F TR2/3/3A Rear sheetmetal repair Triumph 73
Patrick67BJ8 HD8 Carb Repair Austin Healey 15
R Issue with odometer after repair Austin Healey 1
T TR2/3/3A Seeking advice on how to repair TR3 steering wheel broken spoke. Triumph 8
A Recommendations for body repair near NYC Restoration & Tools 2
R Windshield Washer Pump Repair Austin Healey 9
A Door hinge repair Austin Healey 2
R Wanted Rear-ended repair items Triumph Classifieds 3
Alfred E. Neuman For Sale Lot of TR4 repair books Triumph Classifieds 0
