Cortina engine problems
basiltheblue
I have a '69 Ford Cortina and though it runs it does so poorly. Its overheating far to quickly and im not sure what to do. There is also a rattling that seems to be coming from the transmission.
What can I do?
All advice is greatly appreciated. /ubbthreads/images/graemlins/laugh.gif
Platinum
umm... Flush the cooling system, change out the thermostat for a 160-degree one, rod the rad, R&R the water pump... LOTS of things you ~could~ do, start with the LEAST expensive and work up.
A *bit* more information about engine type, etc. may be helpful for us to offer better (more specific) suggestions, y'know./ubbthreads/images/graemlins/rolleyes.gif
Tranny is a four speed, or a 'slushbox'?
TXCoyote
If it runs poorly (more specifics please) the first thing I would do is test compression.
AngliaGT
You might go by JAE in Goleta.
They sell Lotus,& Cortina parts,& Jeff knows
a lot about Cortina's.
Hope this helps.
- Doug
B
basiltheblue
hey thanks for all the the help! oh and the engine is a...1600GT xFlow with a 4 speed.
Ok the major problem is that the car has no power... it starts just fine... idles at about 10k with the choke fully off. Once you try and drive it has absolutely no power. when accelerating it takes a lot of power just to get it to move almost into the red. After about 10 minutes of "driving" the car wont run. It won’t start at all. we though it was out of gas but the same thing happens with about 4 gals in the tank.
Anyone know what this could be?
ANY help would be nice... if anyone needs more information let us know.
Thank you.
Oh BTW im saying WE because this is a joint project between a friend and me.
Platinum
What induction? Idle speed is a bit high. Air leaks around carb mounts? Broken/missing intake manifold take-offs?
"power" to move it into the red? Very confusing. Sounds like you mean the throttle position? Is it running a mechanical fuel pump or electric?
AngliaGT
Also,check your fuel line from the tank.
On one of my Cortinas,the PO had used some plastic ties
that would restrict the flow of fuel,& car would die.
Of course,you've tried replacing the fuel filter,if there's
one - (didn't come with any from the factory).
- Doug
B
basiltheblue
The fuel pump is mechanical... i had problems with the original and have since put a working one in. I also put in a inline clear fuel filter between the pump and the carb... i can see fuel through it when the car runs. I will check for air leaks around the carb.
After I have driven around for about 10 minuets I have to go into the "red" Or about 70,000 RPMs (I think that’s the red line) just to get the car to move.
Thank you for all your help everyone.
Platinum
heh. 7K or a turbine engine!
If you spritz WD-40 or other aerosol propelled high volitility stuff around the carb base, it will change idle speed if there's a leak. What carb is this thing running? Is this a "new" problem after it's been running fine in the past?
Check the coil for proper resistances, cold and hot after it's done the "trick" on you. It could be a coil breaking down, too.
B
basiltheblue
Haha 70,000 that would be something to see! yeah 7k.
Ok i will try that wd-40 thing once is stops raining.
Thanks for the tip.
This car sat for about 2 years and before that it was my sisters. She had it running but I think it always had problems. The coil sounds like something that she said is funky... any info on how to test the proper resistances?
B
basiltheblue
Wow that’s a sweet article! Thanks. I’m going to fix a few things and see if it works any better... Thank you for all your help.
Platinum
Report back so's we know what you find!
B
basiltheblue
Ok Sooo... electric system checked out.
after that we moved on to the carburetor. Removed it and found lots of yellow gunk and other nasty stuff. we had a replacement carb and we put it in... then the car would start fine and idle fine but after about 2 minuets it would die and nothing would help it. sooo i called my sister who works for Dave Bean Engineering (https://www.davebean.com/)
And owns 2 Cortinas... she said it sounds like there is lots of nasty stuff in the fuel tank and line... this is our next step. Going to pull the tank and clean the line... hope it works...
Wish us luck.
Luck!
Platinum
Sis works for Dave Bean?!?! Kewl! I've been buying bits from them for decades... Have Sis tell 'em she knows where one of the founding fathers of the "Western Pennsylvania Lotus Mafia" has wound up /ubbthreads/images/graemlins/wink.gif
When I left the region there were five or six Elans in proximity because of me and another friend.
That was thirty YEARS ago!! Durn' near had to take me sox off to figger it out.
/ubbthreads/images/graemlins/jester.gif
TypeRboy
Hey just my 2 cents.. Sounds to me like the valves might be adjusted too tight.. That would cause a severe loss of power, and over heating. Pretty much the same thing if the initial timing is heavily retarded. These are not a hot running engine, in fact you could normally run without a fan and still be cool enough in every day traffic.
Too bad you're not close, these things are easier to figure out in person.
B
basiltheblue
ah ha!
we just took off the gas tank and it is nothing short of stunning. there was an entire beach(of rust and gunk) camped out in our fuel filter and the bottom of the tank. we drained the tank and removed the filter. we are going to take the tank to get cleansed/relined and we are buying a replacement filter. does this sound like it may be the root of some of our problems? maybe? no!!!
and yes indeed, dian, is the sister of (lucas).
we will also check the valves, thanks for the tip.
C Wanted Wanted - Ford Cortina "bullet" style gearbox Other British Classifieds 1
Paul_1 Vintage Ford Cortina Spotted 12
Elva164 A new Cortina video AND a new Youtube channel! Racing 1
aeronca65t Cortina & Consul wrecked Other British Cars 2
AngliaGT Selling Off All My MKII Cortina Parts Other British Cars 2
Elva164 Help me fix the Cortina! Lotus 9
JPSmit Cortina - sort of. Other British Cars 3
AngliaGT The Cortina Estate Chronicles Other British Cars 43
AngliaGT My New Cortina - almost Other British Cars 14
AngliaGT Finally!! - Cortina Replacement!!! Other Cars 1
AngliaGT Cortina Replacement Other Cars 4
JPSmit Cortina on Ebay Other British Cars 3
AngliaGT Hey Doc - Did You See This Cortina? Other British Cars 1
J Brakes for a Mk2 Ford Cortina Other British Cars 4
J ford Cortina question` Other British Cars 7
L Lotus Cortina on ebay Lotus 7
AngliaGT Anyone Interested in a Cortina? Other British Cars 26
AngliaGT Got the Cortina RUNNING Today! Other British Cars 14
G Did anyone see what that Lotus Cortina is bid to Lotus 2
AngliaGT Looking For a New Cortina M/C Other British Cars 4
AngliaGT 1968 Ford Cortina GT for sale Other British Cars 0
aeronca65t Cortina #57 Other British Cars 4
MGA Steve Ford Cortina Other British Cars 24
eschneider Cortina 1500 pulley quandry Other British Cars 2
AngliaGT Cortina Transmission in - Finally! Other British Cars 11
AngliaGT Cortina Strikes Again! Other British Cars 5
Steve Nice Cortina GT on eBay Other British Cars 5
Sherlock For you Cortina/British Ford fans... Other British Cars 16
eschneider anyone have a cortina 1500 cast iron ex manifold Other British Cars 7
AngliaGT Thinking of Selling the Cortina Other British Cars 3
AngliaGT Wedge TR7 - Or Cortina MKIII? Triumph 10
AngliaGT Cortina - ARRGH Other British Cars 6
S Nice Cortina on E Bay Other British Cars 6
AngliaGT Cortina Almost Done Other British Cars 5
Don Lattimer Hillman Minx/ Ford Cortina FS Other British Cars 2
AngliaGT '67 Cortina GT For Sale Other British Cars 16
AngliaGT Cortina's Back Together Other British Cars 5
AngliaGT Cortina Head Bolts Other British Cars 5
TypeRboy Cortina steering box question. Other British Cars 14
AngliaGT Finally Worked on the Cortina Other British Cars 8
TypeRboy Anybody swapped a T5 into a Cortina or the like? Other British Cars 6
TypeRboy Cortina is finally going!! Other British Cars 15
A Stolen : MK1 Lotus Cortina , from Carmichael Calif Lotus 8
TypeRboy Help on paint code for my Cortina Other British Cars 3
TypeRboy Now I've done it, No Cortina this spring Lotus 4
A Wtd: MK1 Lotus Cortina Lotus 10
C 1967 Mk2 Cortina Colour Schemes Other British Cars 3
66LotusCortinaTX Howdy from North Texas and a long lost Cortina Other British Cars 8
aeronca65t Cortina@Speed Other British Cars 0
Sherlock Found a neat Cortina hat tonight Other British Cars 0
